Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 10-31-2007, 18:03   #61 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
31.10.2007 - DB2020 inside v3.2
Whats new:
- Added new model T250 (flashing only)
- Added new model Z320 (flashing only)
- Added support for W810 CID 50 new PID phones
- User manual updated, please check it before start to do anything
New files in installer:
- db2020inside.exe v3.2
- Db2020Inside.pdf v3.2
- t250_z320_Reset User Lock.act
- t250_z320_Reset Total Call Timer.act
Users who have installed DB2020 inside v3.1 can download and install "DB2020inside_v3.2_for_v3.1_users_only.exe"
New users need to download full installation "DB2020 inside v3.2.exe"
Old 11-06-2007, 22:45   #62 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
07.11.2007 - DB2020 inside v3.3
Whats new:
- Added new model K770
- Added new model W300 (flashing only)
- Added new model Z530 (flashing only)
- Added support for Z310 CID 52 upgraded phones from CID 51
- Added read all info from Z310
Users who have installed DB2020 inside v3.2 can download and install "DB2020inside_v3.3_for_v3.2_users_only.exe"
New users need to download full installation "DB2020 inside v3.3.exe"
Old 11-27-2007, 19:07   #63 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
23.11.2007 - DB2020 inside v3.4 - Unlimited CID52 unlock
Whats new:
- Added DB2020 CID 52 unlimited unlock
Users who have installed DB2020 inside v3.3 can download and install "DB2020inside_v3.4_for_v3.3_users_only.exe"
New users need to download full installation "DB2020 inside v3.4.exe"
PS
This year Santa Klaus will come before the time
Old 12-05-2007, 10:15   #64 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
05.12.2007 - DB31xx inside v1.0 - DB31xx (A2) supported standalone
Whats new:
DB31xx is new software realize for MT box SonyEricsson for new SEMC platform called A2
The software can be used with all MT box SonyEricsson and upgraded MT box Nokia to MT box SE.
How to upgrade your MT box Nokia to MT box SonyEricsson unlimited see here.
The software are free upgrade for all MT box SonyEricsson users and work as standalone without logs and without limits.
Supported phone models:
  • K850
  • Z750
  • W910
Some software features:
  • Standalone software
  • Language change
  • Upgrade phone software
  • De customize phones
  • Customize phones to desired network
  • Convert phones from China to Europe market
  • Convert phones from Europe to China market
  • Repair dead phones
  • Reset total call timer
  • Reset user code to factory default 0000
  • Read phone software version information
  • Read phone customization info
  • Read phone language information
  • Read phone OTP “color” information
  • Read phone FLASH “color” information
  • USB support via DCU-60 cable (the same one from phone package)
  • USB multi flashing interface with support up to 256 phones at same time
  • Can operate with unlimited number of phones on one PC
  • Usage of PC CPU is 01% per connected box
  • All process is off-line
  • Auto detect function for new connected box
  • All actions are stored into the log file “db31xx.log” in software directory
  • Auto save login details for Griffin Server
  • All features can be used in TRIAL mode with other MT box models , MT box Nokia and MT Siemens
  • Very easy to use
  • Simple user interface
Flash files upload in progress...
Old 12-09-2007, 15:20   #65 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
09.12.2007 - DB2020 inside v3.5 - Z310 CID 51 unlock by patch supported
Whats new:
- Added Z310 CID 51 unlock by patch
- Added FLR files for Z310 CID 51
- Added Z310 CID 52 reset total call times
- Added Z310 CID 52 reset flip counter
- Added Z310 CID 52 reset user lock
Supported phone versions for unlock:
- R1JE001 prgCXC1250790_VODAFONE_AL
- R1JC002 prgCXC1250790_VODAFONE_AL
- R1JC002 prgCXC1250789_TELEFONICA_AL
- R1JC002 prgCXC1250739_TAIWAN_AL
- R1JC002 prgCXC1250737_CHINA_AL
- R1JC002 prgCXC1250594_GENERIC_AL
We recommend to all users to delete previous installation files from:
C:\Program Files\GriffinTeam\MT SonyEricsson\DB2020 inside\
then install new DB2020 inside v3.5 because of some structure changes in installer
How to unlock Z310 CID 51
Start software
Select phone model Z310
Connect phone to BOX CABLE to check what CID is inside, the info need to be:
CID in FLASH(dec):51
CID in FLASH (hex):33
Drag and drop “Z310 Unlock-Public.act” file to software window, this file Need to be first on the file list in DB2020 software.
Then need to add usually flash files MCU, DEC and CUS to files list
Press DO IT button
Power on phone after software finish and wait to make initialization
USE ONLY BOX CABLE FOR UNLOCK
Unlock cost you 5 credits on Griffin server
more to come from GT as usual ...
Old 12-17-2007, 11:14   #66 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
17.12.2007 - DB31xx inside v1.1
Whats new:
- Fixed flash bug on some phone models
- Added automatic news reader. It will inform you always about new realizes, new flash files on support etc
Old 12-17-2007, 11:16   #67 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
17.12.2007 - DB2020 inside v3.6 - T250 and Z320 unlock by patch supported
Whats new:
- T250 unlock by patch supported
- Z320 unlock by patch supported
- Added automatic news reader. It will inform you always about new realizes, new flash files on support etc.
- If during unlock or flash process "POWER ON THE PHONE" message appears, please press phone power switch manually then software will continue.
This option is added because some DB2020 phones have problem to be detected on cable then you cant unlock or flash it.
How to unlock T250 and Z320:
- Check phone battery and phone functionality before start to unlock it
- Select phone model T250 or Z320
- Add to software file list necessary file:
T250 Unlock.act if your phone is T250
Z320 Unlock.act if your phone is Z320
- Both files are available in:
C:\Program Files\GriffinTeam\MT SonyEricsson\DB2020 inside\Unlock
- Connect phone to box cable and press DO IT button
- Wait to software finish then power the phone
Users who have installed DB2020 inside v3.5 can download and install "DB2020inside_v3.6_for_v3.5_users_only.exe"
New users need to download full installation "DB2020 inside v3.6.exe"
Old 12-23-2007, 15:47   #68 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
23.12.2007 - DB2020 inside v3.7 - DB2012 CID 50 phones flash without credits
Whats new:
- DB2012 CID 50 phones can be flashed without EMMA CARD/Griffin server credits needed
Users who have installed DB2020 inside v3.6 can download and install "DB2020inside_v3.7_for_v3.6_users_only.exe"
New users need to download full installation "DB2020 inside v3.7.exe"
Old 12-26-2007, 19:30   #69 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
26.12.2007 - DB2020 inside v3.7a
Whats new:
- New file to update DB2020 CID 49 & 51 to CID52-071124.ee
- This file allows you to update DB2020 CID 49 and CID 51 phones to CID 52 and unlock it without server or emma card
Users who have installed DB2020 inside v3.7 need to download and install "DB2020_inside_v3.7a.exe"
New users need to download full installation "DB2020 inside v3.7.exe" then download and install "Download and install DB2020_inside_v3.7a.exe"
Old 01-10-2008, 11:05   #70 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
10.01.2008 - DB2020 inside v3.8
Whats new:
- Corrected bug when unlock some Z320 phones
- Corrected boot bug on Lacosto phones
Users who have installed DB2020 inside v3.7 need to download and install "DB2020_inside_v3.8_for_v3.7_users_only.exe"
New users need to download full installation "DB2020 inside v3.8.exe"
Short manual how to unlock T250 and Z320:
All future news and support will be available only on Griffin Team support forum
**MT-box SE updates** 04.06.2008 - DB2020 inside v4.8 - JAVA UNLOCK ADDED irfanamin2 MT-BOX 6 07-19-2008 14:23
**MT-box SE updates** 05.07.2008 - DB2020 inside v4.9a babbu Service Products News & Updates 0 07-05-2008 09:46
**MT-box SE updates** 04.06.2008 - DB2020 inside v4.8 - JAVA UNLOCK ADDED irfanamin2 Service Products News & Updates 0 06-04-2008 08:40
**MT-box SE updates** 30.05.2008 - DB2020 inside v4.7a - JAVA UNLOCK ADDED irfanamin2 MT-BOX 0 05-30-2008 18:36
**MT-box SE updates** 30.05.2008 - DB2020 inside v4.7a - JAVA UNLOCK ADDED irfanamin2 Service Products News & Updates 0 05-30-2008 18:32
Page generated in 0.37959 seconds with 8 queries
