Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > Griffin Products > MT-BOX
Old 07-27-2006, 10:13   #1 (permalink)
MicrostarGSM®'s Avatar
Member: 18855
**MT Box Siemens updates**- Motorola F3 added
Siemens S-Gold 0.200
27.07.2006
- AMD/Spansion ESN read corrected
- Amd erase BUG corrected
Old 08-07-2006, 20:30   #2 (permalink)
Member: 308774
**MT Box Siemens updates**- SGOLD ver 0.300(beta) Released! - 07.08.2006
As I promise...
07-08-2006 SIEMENS_sgold ver 0.300 (beta)
- New bootcore support - version 1.24 1.26
- Added Service/Normal/Burnin modes
- Added Reading info
- Alternative method of unlock.
- Added SKEY support
- Sending to phone
- Release from phone
- SKEY modes
- Added Writing security data via normal and service mode
- Added LCD maintence
- Test patterns
- LCD/Keyboard light test
- CONTRAST Read/Set/Write
- Display controller determination
- Added FFS formating
I. Alternative method of unlock - SLOW METHOD!!!
This method can be used for unlock phone via Service mode
when boot mode failed. (Bad RAM/FLASH soldering, bad connection between
phone and cable)
STEPS:
1. If Boot Method (Direct unlock failed) on tab "CODES" are filled
fields with technical data from phone - ESN/HASH/IMEI
2. On tab "CODES" press "Calc SKEY" to calculate SERVICE KEY
- Service key will be used to open BUS for full control of phone.
3. If SKEY is calculated will be filed into respective field.
4. Press "Send SKEY" to send SERVICE KEY to phone for opening
Now phone are into FACTORY MODE...
5. With Pressing "Write security data" will unlock phone.
6. With pressing "Close SKEY" can close BUS to CUSTOMMER MODE. (This step is not important)
THIS PROCEDURE ARE AUTOMATED WITH BUTTON "OTHER UNLOCK"
II. FFS tab
This function format "PARTITIONS" on phone. This will remove pictures,
melodies, photos etc...
After format need perform FFS_INIT or flash with XFS file to restore
content data.
WARNING!!! WARNING!!! WARNING!!!
BE CAREFULL WITH FFS_C FORMATING!!!
Old 09-02-2006, 11:40   #3 (permalink)
Member: 18855
02-09-2006 Siemens SGOLD Version 0.93 (alpha)
What's new:
– Flash maintenance
– Full flash Reading/Writing
– Custom region from flash – Reading/Writing
– Improoved unlock procedure
– Custom Speed support up to 1500000 bps.
– Simplyfyed interface
– New boot engine
– Multiflash devices support (SL75 flash chip.)
Old 09-14-2006, 16:13   #4 (permalink)
Member: 18855
**MT Box Siemens updates**- Siemens SGOLD Version 0.94 Released! - 15.09.2006
Siemens SGOLD Version: 0.94
- Small interface bugs corrected
- Optimized unlock procedure
- Into tab "SERVICE MODE" added button PHONECODE
after entering SKEY can read phonecode on phone.
Old 09-15-2006, 12:30   #5 (permalink)
Member: 18855
**MT Box Siemens updates**- Siemens SGOLD Version 0.94a Released! - 15.09.2006
Siemens SGOLD Version: 0.94a
- Minor bug fixed
"Invalid pointer operation" when use SLOW METHOD UNLOCK
Old 11-02-2006, 18:50   #6 (permalink)
Member: 18855
**MT Box Siemens updates**- SIEMENS SGOLD. Version 1.0.2.10 AL Released! - 03.11.2006
(C) 2006 Griffin Team
SIEMENS SGOLD. Version 1.0.2.10 ALPHA
What's new:
- NO TESTPOINT, NO DISASSEMBLY, NO JAVA Unlock for most models
- Unique unlocking engine - Unlock via testpoint 1 second
- Automated mode detection
- Custom network RELOCK
- Backup/Restore original lock state
- Repair BOOTPROTECTION if wrong BOOTCORE flashed into phone
- Full reconstruct on security zones
- Freeze OPERATION added.
- New interface
TP ON
Sgold detected...
JBOOT: preloader...
JBOOT: Started...
TP OFF
ASIC.....................PMB8875 V1.1B
Trademark................41
Specification revision...0
Architecture.............ARMv5TEJ
Part number..............926
Layout revision..........3
** General S-GOLD FLASH LOADER **
** Powered by Griffin team **
** version: 01B**
Detected flash devices...1
Device offset............0xA0000000-0xA2000000
Device ID................0089880D:00000000
size.....................32MB
EELITE...................0xA0FE0000
EEFULL...................0xA0220000
EEFULL2..................0xA0240000
Free memory in EELITE....78779 bytes
Free memory in EEFULL....0 bytes
Free memory in EEFULL2...105454 bytes
FACTORY ESN :A7773385
FACTORY IMEI :353541000584124
BC MANUFACTURER..........SIEMENS
BC MODEL.................CX65
BC IMEI..................353541000584124
FW VERSION...............50
FW MANUFACTURER..........SIEMENS
FW MODEL.................CX65
FW LANG..................lg5
Phone boot OK...
Repair imei ...
Remove locks...
Free memory in EELITE....78752 bytes
Free memory in EEFULL2...104937 bytes
Done!
Downloa it AT support AREA NOW.....Enjoy!!!!!
REgards,
Old 11-21-2006, 10:43   #7 (permalink)
Member: 18855
**MT Box Siemens updates**- SIEMENS SGOLD. Version 1.0.3.16 Released! - 21.11.2006
Minor bugs fixed
-Factory BCORE integration algorithm changed
-Added support for some AMD Flash-devices
-Added check-state function by writing EEP-Field
-Added Generic disable otp-check function supported all known and unknown SGOLD-firmwares
-Added possibility to set custom imei in eeprom
-Added possibility to format "EXIT" & "FM" sections via ServiceMode
new Field addet for set new IMEI and 2 check-box
If "Disable-otp check"is checked Mt software will analyse firmware and make changes to disable OTP imei . IF "Use factory OTP imei" is not checked software will set imei from IMEI field.
We recommend:
1. enter disiered digits on IMEI field
2. "USE factory OTP check" - Unchecked
3. "Disable OTP check" - Checked
4. "Locks + Phonecode" - Checked
5. "Repair IMEI" - Checked
6. "Recalculate boot-protection" - Checked
7. "Skip write hash in boot-core" - Checked
8. Press UNLOCK button and wait to finish
File is Ready at support area
BR GT
TP ON
Sgold detected...
JBOOT: preloader...
JBOOT: Started...
TP OFF
** version: 01D**
Detected flash devices...2
Device offset............0xA0000000-0xA1000000
Device ID................0001227E:22182200
size.....................16MB
Device offset............0xA1000000-0xA2000000
Free memory in EELITE....99290 bytes
Free memory in EEFULL....4 bytes
Free memory in EEFULL2...127222 bytes
FACTORY ESN :F965E45C
FACTORY IMEI :354926001925518
BC MODEL.................CX70
BC IMEI..................354926001925518
FW VERSION...............43
FW MODEL.................CX70
Phone boot OK...
Analyse firmware....
OTP-CHECK STATE..........ENABLED
Setting new data in proggress...
Write operation.........Done!
HASH: 0EFBDC8594133DD4378BACA4591808DA
BKEY: AB67B1F82091A316B3C7718AEA90A899
New public key...
[ 52][EEP_FIELD_WRITE_OK]
Reset master codes to *#000X*00000000#
[5121][EEP_FIELD_WRITE_OK]
[5122][EEP_FIELD_WRITE_OK]
[5123][EEP_FIELD_WRITE_OK]
Update hash.............Skip
Repair imei ...
[ 76][EEP_FIELD_WRITE_OK]
[5009][EEP_FIELD_WRITE_OK]
[5077][EEP_FIELD_WRITE_OK]
Remove locks...
[5008][EEP_FIELD_WRITE_OK]
Free memory in EELITE....98956 bytes
Free memory in EEFULL2...126560 bytes
Done!
Receiving info...
Manifacturer: SIEMENS
HWID: 322
Model: CX70
Software ver: 43
Language group: lg5
IMEI: 000000000000018
Phone mode: Service Mode
Security mode: FactoryMode
BFC full mode!!!
ESN: F965E45C
Old 02-02-2007, 16:25   #8 (permalink)
911GT's Avatar
Member: 409197
MT Siemens 1.0.4.26 release notes
1. IMPROVEMENT hardware detect function
2. fixed bug with freeze bcore
3. Allow edit Factory Service Profile
3.1 supported options:
-Allow Last 10 calls
-Allow Only Three Phone Code Attempts
-Airplane mode
-Add USSD to RedialList
-Allow Babysitter
-All Unanswered
-Allow Edit VOICEMAIL Number
-Browser
-Charge Rate
-Conceal ID for all calls
-Clear All Diverts
-Call VOICEMAIL With 1 Long press
-Divert Status Check
-Divert All Fax Calls
-Divert All Data Calls
-Evaluation Of CPHS Data Fields
-Evaluation Of CSP DataField
-Evaluation Of Operator Name From SIM
-Games
-Illumination
-Loan Phone
-List 8 Bit Sms As Data Message
-MO Charge Mode Only
-Network Barring
-NSLock And SPLock
-Restrict CFU Check On Startup
-Restrict VOICE Mail Softkey In Idle
-Restrict VOICE Mail Softkey In Menus
-Restrict BandSelection
-Restrict Direct Call Of Voice mailbox
-Restrict UDUB Signaling On Softkey
-Restrict Call Control By SIM
-Restrict Alternate Line Service
-Restrict Service String Table
-Restrict Automatic Reset Of VOICEMMAIL Flag
-Restrict Always Signal UDUB
-Restrict Show Own Number Via StarHash
-Restrict Short Barring Texts
-Restrict Negative Logic Of CSP
-Restrict TSCD1 For Aux Speech
-Restrict TSC11 For Speech
-Restrict Toolkit Empty Input As Null String
-Read 900 Before 1800 DataFields
-Restrict Evaluation Of Orange DataFields
-Restrict Patch Type Of Number
-Restrict GPRS Auto Attach At Startup
-Restrict Orange Moses
-Restrict Chinese Extensions
-Restrict Smsp Init By Flash
-Restrict Show USSD Immediately
-User Groups
-Use Conditional CF flag In Idle
-Specific Divert
-Show Welcome Text
-Suppression Of SMS Beep
-Show EEFULL Operator Bitmap
-Show SOS Softkey Without SIM
-SMS Prefered Storage Is ME
3.2 NOTE: in case of diferent models some options will not have afect !!!
4. interface minor bug fixed
AT THIS TIME CAN BE DOWNLOADED FROM TORRENT SERVER
The Following User Says Thank You to 911GT For This Useful Post:
Old 02-03-2007, 17:31   #9 (permalink)
Member: 18855
**MT Box Siemens updates**- SIEMENS SGOLD. Version 1.0.4.27 Released! - 04.02.2007
Bugs Fixed
SIEMENS SGOLD. Version 1.0.4.26 Released! - 04.02.2007
Kindly download it at support area
Old 03-13-2007, 17:04   #10 (permalink)
Member: 18855
**MT Box Siemens updates**- SIEMENS SGOLD. Version 1.0.4.30 Released! - 13.03.2007
1. What's new
- Added moore detailed security
analysis info before freezing.
- Improoved detection phonemode
- Changed modenames
Custommer mode = Security CLOSED
Repair mode = Security SERVICE
Factory mode = Security DEVELOPPER
Factory Mode = Security XDEVELOPPER
- Added button SECURITY STATUS to check post
freeze status
- Added button WRITE SECURITY VIA SERVICE MODE
for safety unlock NEWSGOLD serie phones (M81,C81, S68...)
2. UNLOCK PROCEDURE NEW SGOLD (M81, C81, EF71,
1. Prepare phone for testpoint operation
2. Boot phone to read data
3. Calc Skey
4. Send SKEY to phone
5. Press "Unlock phone via Service mode"
kindly download it at support area
Old 04-11-2007, 12:33   #11 (permalink)
Member: 18855
**MT Box Siemens updates**- SIEMENS EGOLD. Version 0.9.18.146 Released! - 22.05.2007
New Siemens EGOLD_0.9.12.130_Alpha.exe
- Flashing all known Original siemens files
*.xbi
*.xbz
*.ebb
*.xbb
*.xfs
- Writing original siemens *.map, *.clo files for better
phone calibration and repair.
- Read firmware and part from firmware
* BCORE
* EEPROM
* Full flash
* Language
* Dictionary-T9
* EEPromFileSystem
* FFS
* FFB
* FFSC
- Erasing user filesystem
- Read/Write contrast values
Please Downoad it at support area.
Please Post the Bugs or suggestion at this link
Click Here
Old 04-12-2007, 06:48   #12 (permalink)
Member: 18855
**MT Box Siemens updates**- SIEMENS EGOLD. Version 0.9.12.132_ Released! - 11.04.200
New Siemens EGOLD_0.9.12.132_Alpha.exe
- added support for AF51
- corected core version check for new boxes
Please Download it at support area.
Click Here
Old 04-16-2007, 10:04   #13 (permalink)
Member: 18855
**MT Box Siemens updates**- SIEMENS EGOLD. Version 0.9.14.134 Released! - 15.04.2007
New Siemens EGOLD_0.9.14.134_Alpha.exe
- Added support for A31A, A31C, A51, A55A, A57A, A76, AF5C, AF5M, C60A, C61, CF6C, M55, M56
- Added Drag&Drop file(s) support
Post bugs at below link
Click Here
Old 04-23-2007, 07:25   #14 (permalink)
Member: 18855
**MT Box Siemens updates**- SIEMENS EGOLD. Version 0.9.15.138 Released! - 22.04.2007
EGOLD_0.9.15.138_Alpha.exe
- Added AX72 support;
- Added Factory service profile menu;
- Added function Extract xbz file from winswup exe file;
- Improved Read function;
- Improved Identify function;
- Button [Clear file system] moved in section [additional];
Old 04-25-2007, 09:17   #15 (permalink)
Member: 18855
**MT Box Siemens updates**- SIEMENS EGOLD. Version 0.9.16.141 Released! - 25.04.2007
- New internal engine
- Improoved unlock logic algorithm
- Switched to beta state - Bug fixed.
- More stable communication
Cable Compatible For Motorola F3 For ET Box / Infinity Box / Vygis Box / Blue Box IPMART ipmart WebShop 0 05-15-2009 11:40
i-Pmart BX Series RJ45 Cable For Motorola F3 For ET Box / Infinity Box / Vygis Box / IPMART ipmart WebShop 0 05-14-2009 16:00
Unlock Motorola F3 without Box or code. quinho P2k Series 53 08-28-2007 08:22
03-01-2007 New Multi-box Installer released! Motorola L6i added into Mitsubishi tool! GSMtricks Multi-Box 4 01-18-2007 12:35
Page generated in 0.94106 seconds with 12 queries
