07-23-2008, 20:23 | #3 (permalink) |
Freak Poster Join Date: Dec 2005 Age: 45
Member: 208643 Status: Offline Thanks Meter: 6 | ok.I ve been using search button for months now,download manual,read lots of threats but no luck to unlock anything.e.x. 5200 trying to unlock.I saw a picture of test point.Test point is under the batery.How to conect?? N95 same,6300 same.Is it anywhere to show which cables to use?usb?normal cable? To be stright...step by step procedures...Thanks in advance for help. |
07-26-2008, 22:39 | #4 (permalink) |
No Life Poster Join Date: Mar 2007
Member: 463420 Status: Offline Thanks Meter: 150 | before all operations the phone must be disassmbly because you must connect TP late. yes you must use specific cable from your pack (mt box) connect red cable- + to your connector ( look from battery) and BSI (green cable) in centre. the ground come from usb connector. After that when press power button you will see in your lcd -mocal or test mode and green diode from the box will work. After that open your software press power button pres 1-read phone, 2-simlock state (check your phone is damage is not? if you see operator is -FFFFFFFFFFFF or imei is 1236598 you will need from RPL, or your counter is 10/10 3/3 you can't unlock it because all counters is BLOCKED. Some phones is supported for counter reset but not all phones) 3. and last press UNLOCK and connect your TP (Look from picture where is the tp, and for some models you need from MIcrosopke) . After that in log you will see -status NOT LOCKED, for supported version and TP picture please search in Griffin team forum. it's frm me i'm just one stupid user. |
mt box and mt lite | bonez131 | Sell ur Old and Used Stuff | 2 | 11-29-2007 13:30 |
WHY the last mt box and mt lite dead speed | mbourtelephone | MT-BOX | 2 | 11-25-2007 13:13 |
SE CID52 Unlocking Solution, MT Lite, MT Box & More. | Networkunlock | Main Sales Section | 0 | 11-05-2007 12:32 |
Please fix N71 unlock problem with mt pro/mt lite! | hoang | MT-BOX | 4 | 09-22-2007 15:15 |
Whats the best price for MT-Lite and MT- Nokia? | The Repair Shop | Wanted Products | 18 | 09-17-2007 16:34 |
