11-10-2005, 11:52 | #1 (permalink) |
No Life Poster Join Date: Dec 2000 Location: uk
Member: 2899 Status: Offline Thanks Meter: 6 | mtbox flashing any nokia error im using the leads successfully on nokia 660 and 3100 with ufs,but with mt on info works when u flash it always say,%%%%%boot error,is it the adaptor problem?cos these leads have been tested with ufs,i wish i hadnt bought this crap(empty box),i will apreciate yr help. br farry |
11-10-2005, 13:20 | #3 (permalink) |
Member: 2899 Status: Offline Thanks Meter: 6 | thnx m8 just tried the slow from the menu,still the same,but how do we suppose to know the vpp pin of each data lead so we can disable it,another stupid design so it can confuse even more people!! any more suggestion m8? br farry |
11-10-2005, 13:38 | #4 (permalink) | |
No Life Poster Join Date: Dec 2002 Age: 47
Member: 18855 Status: Offline Thanks Meter: 1,938 | Quote:
have you connect the adaptor ? | |
11-10-2005, 14:20 | #6 (permalink) | |
anyway here is the schematic http://forum.gsmhosting.com/vbb/show...45&postcount=2 | |
11-10-2005, 17:03 | #8 (permalink) | |
Member deceased !! Join Date: Mar 2002 Location: www.griffinteam.net Age: 54
Member: 10248 Status: Offline Thanks Meter: 25 | Quote:
First think after conect phone to box you try power ON local mode or normal click on phone info you must get fulll details for phone. BR GT | |
11-11-2005, 12:36 | #9 (permalink) |
Member: 2899 Status: Offline Thanks Meter: 6 | hi andro when i connect and power on phone,its soft version and imei number is only displayed,but after pressing flash it gives me %%error booting message,i have also disabled vpp and put the setting on slow dct4,what could be the problem?the phones that im trying are 3100 and 660 both r giving boot error message both leads r working with my ufs also,please help . farry |
11-11-2005, 13:08 | #10 (permalink) | |
your problem definetily connection problem check your cable and phone connection here is the result for 3100 with mtb_nk 1.10 Phone is in: Normal mode IMEI: 35151xxxxxxxxxx Generated RPL file from resource 208 C:\Program Files\Nokia\Phoenix\Products\RH-19_351535151xxxxxxxxxx.rpl Processing File: rh19__06.110 Boot... ASIC ID: 1120 DCT4 u_2nd.fia u_amd.fia Configuration Info (9F): Number of Flashes: 2 01000000: Samsung, 00EC 22F2 0000 00E2, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[8.00 MB]... request erase [01000000 to 0100FFFF] request erase [01010000 to 0154FFFF] request erase [01680000 to 017EFFFF] request erase [01EB0000 to 01FEFFFF] Waiting response for 300 Sec...in 35.52s Flash[5.27 MB]...in 26.23s * * Processed file in 69.75 seconds Low level format...OK Processing File: rh19__06.11.ucp_xs1 Boot... ASIC ID: 1120 DCT4 u_2nd.fia u_amd.fia Configuration Info (9F): Number of Flashes: 2 01000000: Samsung, 00EC 22F2 0000 00E2, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[1.19 MB]... request erase [01550000 to 0167FFFF] Waiting response for 300 Sec...in 7.26s Flash[0.50 MB]...in 2.80s * * Processed file in 16.47 seconds Extract content...OK Processing File: rh19__06.11s Boot... ASIC ID: 1120 DCT4 u_2nd.fia u_amd.fia Configuration Info (9F): Number of Flashes: 2 01000000: Samsung, 00EC 22F2 0000 00E2, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[1.19 MB]... request erase [01550000 to 0167FFFF] Waiting response for 300 Sec...in 7.31s Flash[1.17 MB]...in 5.97s * * Processed file in 19.87 seconds * * * Phone flashing done in 2: 5 minutes Pooling mode for full factory set... V 06.11 /17-05-05/RH-19 (c) Nokia. IMEI: 35151xxxxxxxxxx Factory Default Settings...OK Pooling mode for profile update... RH-19\apac.pp Sending Profile to Phone...OK Unlock phone Phone is in: Test mode Imei: 35151xxxxxxxxxx SIM Unlock Successfull | |
11-11-2005, 13:25 | #11 (permalink) | |
HI 1. flash folder whit loaders 2. corect flash file 3 send me PM whit you ICQ or sonork to fix problem BR GT | |
11-11-2005, 15:34 | #13 (permalink) |
Member: 2899 Status: Offline Thanks Meter: 6 | hi m8 i dont know!!maybe im using the bootloader from my ufs,can u tell me where they should be?thnx again.andro iwill send u my icq later,i have it on my home pc. br farry |
11-11-2005, 16:19 | #14 (permalink) |
Member: 2899 Status: Offline Thanks Meter: 6 | guys i sortedout the problem!!thnx to savic he just gave me an idea,i just run the mt nkexe from somewhere on my c drive not from my desktop ,this time it worked what a fast cool soft,thnx andro and other guys who helped me,so from now on if u have any problems make sure u run the exe from yr c drive (if it gives an error)not from the short cut on the desk top,im so happy now,thnx again. br farry |
11-11-2005, 16:36 | #15 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | This problem can be solved very easy: When install MT box Nokia software , do not install it to same directory where you have installed other Nokia boxes (Griffin, UFS, JAF etc...). Because in this way you will mix files (flash loaders etc..) then software cant work correctly. This mean install MT box to separate folder and you cant have problems. |
use fls-5 flash any phone error | songyang119 | Genie Universal | 6 | 05-16-2009 11:58 |
can,t flash any nokia phone help plzzz | .:M@ster:. | Universalbox | 2 | 07-10-2007 16:53 |
can flashing any nokia with use dku2 cable | fouadalg | MT-BOX | 1 | 04-23-2007 11:13 |
I can not flash any Nokia Phone of the dct3 and dct4 series.... | klaus4 | Twisterflasher | 1 | 03-21-2005 00:36 |
