01-15-2008, 15:33 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: algeria Age: 40
Member: 447609 Status: Offline Thanks Meter: 3 | MTBOXv1_43 problem Box: CR V 1.002 256 Code: NK V 1.001 1048 SN: 006b8aef66 Nokia Unlimited: 271 times started SonyEricsson Trial: 2 left, each max 15min Scanning files, please wait... Done VPP is DISABLED. BB5 PM back Phone is in: Phone is not responding! Processing File: rm140__004.510.mcusw Boot... Downloaded news update from GriffinTeam. Switching to Online news tab rap3gv3_2nd.fg RAP3Gv3_algo.fg %%%%%%%% ERROR BOOTING: |
01-15-2008, 15:34 | #2 (permalink) |
Member: 447609 Status: Offline Thanks Meter: 3 | Ok ============= Set Flash mode for info ============= VBat is 3.90V Vpp pin has 1.36V, Connected Pins: Mbus 1, Box Tx 0, Box Rx 0, Bsi 0 Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg BOOT OK... Phone Type: BB5 ------------------- SYSTEM ID Response: 7 blocks ------------- SYSTEM_ASIC_ID( RAP ): 000000010000022600010006010C192101003000 EM_ASIC_ID( RAP ): 00000295 EM_ASIC_ID( RAP ): 00000B22 PUBLIC_ID( RAP ): 04E00117349C0154648071C9DB6B00C2DB1ABBE8 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): BAF3A9C3DBFA8454937DB77F2B8852B1 ROM_ID( RAP ): 273F6D55DFAAF68F --------------- Device ID Response: 1 blocks ------------- ============= Set FBus mode for info ============= VBat is 3.92V Vpp pin has 0.09V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 |
01-15-2008, 15:41 | #3 (permalink) |
Member: 447609 Status: Offline Thanks Meter: 3 | and whit version v1_37 MTBOX: - Nokia Flash/Repair v1_37 Box: CR V 1.002 256 Code: NK V 1.001 1047 SN: 006b8aef66 Nokia Unlimited: 272 times started SonyEricsson Trial: 2 left, each max 15min Scanning files, please wait... Done VPP is DISABLED. BB5 PM back Phone is in: Phone is not responding! Processing File: rm140__004.510.mcusw Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00000000 - 000202BF] Erase RAP3 [00020300 - 000252FF] Erase RAP3 [00020000 - 0007FFFF] Erase RAP3 [00080000 - 000DFFFF] Erase RAP3 [00200000 - 0037FFFF] Erase RAP3 [00380000 - 0143DFFF] Erase RAP3 [0143E000 - 0143EFFF] Erase RAP3 [0143F000 - 0143FFFF] Erase RAP3 [00100000 - 001FFFFF] Erase[20.15 MB]... Waiting response for 320 Sec...in 0.66s Flash[17.82 MB]...in 46.69s * * Processed file in 55.34 seconds Processing File: rm140__004.51.image_a_128 Low level format...fail Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [02000000 - 03FDFFFF] Erase RAP3 [01C80000 - 01FDFFFF] Erase[35.25 MB]... Waiting response for 320 Sec...in 0.52s Flash[6.88 MB]...in 18.27s * * Processed file in 78.72 seconds Extract content...fail Processing File: rm140__04.51.ppm_b Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [01440000 - 01A3FFFF] Erase[6.00 MB]... Waiting response for 320 Sec...in 0.42s Flash[4.76 MB]...in 10.42s * * Processed file in 18.95 seconds * * * Phone flashing done in 3:56 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! |
01-16-2008, 10:46 | #4 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | i will check this and will answer correct on the question. but 1st you need to repair your cable to can change modes of phone!!!! try with 1.37 but uncheck DisableVPP. post log. |
01-17-2008, 10:02 | #6 (permalink) |
Member: 409197 Status: Offline Thanks Meter: 75 | see your 1st log!!! VBat is 3.90V Vpp pin has 1.36V, Connected after boot is: VBat is 3.92V Vpp pin has 0.09V, Not Connected this is 100% bad connection of cable.After change cable who you dont uncheck DisableVPP option?????????????????????????????? |
SERVER STATUS - USE Panel V 2.3.0.7 - Upgrade/Installation/Support Server Problems | GsmMunna | HWK | 1801 | 05-18-2023 13:08 |
s3650 problem [FIXED in SPT 8.7.8] | SonyBB5 | SPT BOX | 3 | 03-29-2010 22:32 |
POTATO interfeis problem | lipen | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 03-29-2010 17:01 |
acount id problem.help uregent plz [SOLVED] | dani2080 | PolarBox 3 | 2 | 03-29-2010 12:46 |
