02-13-2007, 14:08 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | my mt-box will make me crazy!!!!!!!!!!!!!!!!! Phone is in: Phone is not responding, power on phone! "the phone did not boot untill i press pwr key" Processing File: NHL105270.C1 Boot... ASIC ID: 1081 WD2 BT2 w3_2nd.fia w3_st_i.fia 843C2F82F8726A0A351A53335982 w3_cbusb.fia Configuration Info (9F): Number of Flashes: 4 00000000: SGS, 0020 88C0 0000 0121, 10 02000000: SGS, 0020 88C0 0000 0121, 10 04000000: SGS, 0020 88C0 0000 0121, 10 06000000: SGS, 0020 88C0 0000 0121, 10 ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Erase[22.44 MB]... erasing region [00000000 to 0000FFFF] erasing region [00010000 to 007FFFFF] erasing region [04000000 to 046FFFFF] erasing region [06000000 to 0673FFFF] erasing region [047C0000 to 047EFFFF] in 3.53s Flash[22.42 MB]... Bluetooth data is 187796 bytes long BlueTooth flash sent in 72.61s * * Processed file in 91.69 seconds ...FAILED only failed , failed in what? ........ we need more clear ERROR messages ... pls mt box team, consider it in next update... |
02-13-2007, 15:38 | #5 (permalink) |
Member: 39208 Status: Offline Thanks Meter: 152 | @tolski @irfanamin2 @softMobile this is the log after skip BT Phone is in: Phone is not responding, power on phone! Processing File: NHL105270.C1 Boot... ASIC ID: 1081 WD2 BT2 w3_2nd.fia w3_st_i.fia 843C2F82F8726A0A351A53335982 Configuration Info (9F): Number of Flashes: 4 00000000: SGS, 0020 88C0 0000 0121, 10 02000000: SGS, 0020 88C0 0000 0121, 10 04000000: SGS, 0020 88C0 0000 0121, 10 06000000: SGS, 0020 88C0 0000 0121, 10 ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Erase[22.44 MB]... erasing region [00000000 to 0000FFFF] erasing region [00010000 to 007FFFFF] erasing region [04000000 to 046FFFFF] erasing region [06000000 to 0673FFFF] erasing region [047C0000 to 047EFFFF] in 3.48s Flash[22.42 MB]... Lower send speed for Bluetooth flashing Restoring to fast speed in 93.28s * * Processed file in 110.31 seconds ...FAILED what I'm saying is that FAILED error message dees not describe the real problem in phone, why shall we guess ....? why we do not have clear error message in mt- box like other boxes? |
02-13-2007, 16:42 | #6 (permalink) | |
Freak Poster Join Date: Sep 2004
Member: 81657 Status: Offline Thanks Meter: 0 | Quote:
B.R. | |
02-14-2007, 11:59 | #9 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | this phone is WETED!!!!!! this is hardware problem - dont find a quarrel in a straw!!!!!! first repair your hardware problem then quest about box. if you dont believe me flash with another box and post the log. |
02-14-2007, 13:47 | #10 (permalink) |
Member: 39208 Status: Offline Thanks Meter: 152 | [QUOTE=911GT;2264594]this phone is WETED!!!!!! this is hardware problem - dont find a quarrel in a straw!!!!!! first repair your hardware problem then quest about box. if you dont believe me flash with another box and post the log. [ Let's say HARDWARE, FAILED....., failed in what? i'm asking for clear error messages....!!!! So we can find out the problem ? |
02-14-2007, 15:54 | #11 (permalink) |
Member: 409197 Status: Offline Thanks Meter: 75 | this error cabe from many problems 1.hardware 2.bad flashIC 3.bad UEM 4.wet thelephone and if i think more time will take to you may be some another problems with this error of box but i repair phones from 10year and i see many many strange problems and if you work hard with phones dont write this bullsheet open phone see inside carefully and then say what you see. i think when you open phone you will understand the error, when you see "the hand of 2-3 technician inside" who try to repair software rpoblem with hardware and now you try to repair problem who reverted from soft to hardware this is the true in more of phones |
02-14-2007, 16:44 | #12 (permalink) |
Junior Member Join Date: Feb 2007
Member: 448308 Status: Offline Thanks Meter: 1 | 911 is right... no BS here Code: Lower send speed for Bluetooth flashing Restoring to fast speed in 93.28s * * Processed file in 110.31 seconds ...FAILED Restoring to fast speed > ERROR: its so clear for people with deep thought Stucked while trying to write flash chip. It could be so many reason. The chip it self, vflash, upp, etc.... Most case is flash0 If you use UFS you will see "write error hDat 14" sorry, but you may kick me if im wrong |
02-14-2007, 17:37 | #13 (permalink) |
Member: 409197 Status: Offline Thanks Meter: 75 | no i dont kick you but you dont know what is the problem. problem is hardware? or i mistake? who you need more messages this is not a book this is soft -small for little bugs small soft small bugs , soft work or not? your box dont make you crazy, phone make you crazy how problem like this you have before? and he is not a hardware ? have nice day man |
02-14-2007, 20:01 | #14 (permalink) | |
Member: 39208 Status: Offline Thanks Meter: 152 | Quote:
what i'm say again and again, is that 'ERROR BOOTING', or 'FAILED' ...., these error messages does not describe the real problem in phone if u consider CLEAR error messages for advanced users this will be helpful for mt-box users for ex., 1. error flashing BT, 2. error booting phone, 3. error writing at adress xxx 4. error in checksum 5. error in getting flash id 6. error in APE flash 7. error in CMD flash 8. error in RAP flashing at address xxx 9. error unknown flash ic flash id xx 10. error bad responce from 'UPP' 11. error bad response from 'RAP3g' 12. error bad responce from 'omap' 13. error bad responsw from 'tiku' etc etc etc ..... pls do not use bad words in this forum, we r discussing some problem in order to find some solution.... and also to improve the mt-box, Thank u, | |
02-14-2007, 20:34 | #15 (permalink) |
Member: 448308 Status: Offline Thanks Meter: 1 | BTW mr.Byte, what is your reason to buy MT box? Provocate by your rival, advice from friend, or decission by your self? You dont need to complain about those feature above. MT got it all. It just the matter of time. Just learning by doing And you will find what kind of error message that MT told you. Small soft, small bugs. Thats it! |
e52 rm-469 will make me crazy | tatoo | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 02-23-2010 21:12 |
my first 6600 make me crazy | dr.lolo | Nokia Hardware & Hardware Repair | 10 | 07-17-2008 09:36 |
MY C2-2 unlock make me CRAZY!! | denard | SAGEM JTAG UNLOCKER | 4 | 03-29-2008 17:26 |
My MT-Box is dead and send back for replacement. How to make ask files? | doctormike | MT-BOX | 0 | 05-29-2007 13:47 |
My MT-Box problem...help me | harim_1981 | MT-BOX | 7 | 10-06-2006 11:10 |
