01-13-2008, 15:14 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: U A E
Member: 50511 Status: Offline Sonork: 100.109684 Thanks Meter: 307 | N73 unlock failed .. again have problem sing fixed version suppo IMEI: 358634015942778 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 358634015942778 TPs OK TESTPOINT FAILED why what shouls i do |
01-14-2008, 08:46 | #4 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | We do nothing mate,only stay and see how small people of our customer cant work with tool and come to cry.This work on a 30000 boxes but only with your dont this is very very funny |
01-14-2008, 09:28 | #5 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 51
Member: 107172 Status: Offline Thanks Meter: 3 | with do all respect for GT-911, new update(mtb_nk 1_43.exe) has some problem . for some phones like 6300 and luna 8600 it gives me 10 times faile ( some versions) and then my pc goes so slow, but when i try with the old version of mt box software , it works perfect as before. for 10 times fail i made short cable as well but it did not work with new software but old one works good. |
01-14-2008, 09:55 | #6 (permalink) |
Member: 409197 Status: Offline Thanks Meter: 75 | mate this is not from soft! just disconnect all another tools from usb and all will be ok. if not then uninstall all mt box and drivers and install it again all will be ok. sorry but we cant repair bugs in windows drivers. many of tools use same driver and windows crash.Sorry but this is not our problem. |
01-14-2008, 15:31 | #7 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 49
Member: 88410 Status: Offline Thanks Meter: 1 | Oh come on 911GT you can't just automatically pass the blame over to drivers without properly investigating people's problem! The new version HAS a bug end of story - lots of people are reporting problems and when using an earlier version there is no problem - this cannot be down to windows drivers - this is a VERSION RELEASE problem. No drivers were changed yet all unlocks that had TP FAILED problem unlock first time. Please treat us with a bit more respect than that before blaming windows drivers! FWC |
01-14-2008, 15:49 | #8 (permalink) |
Member: 409197 Status: Offline Thanks Meter: 75 | Phone is in: Local mode Imei: 359568010331265 F 05wk47v38.1/19-01-07/RM-133/(c) Nokia. Auto backup SIMLOCK... ================================= bb5bckup\359568010331265.pm nBackup file already exists! SKIPPING backup ================================= Using fixed version support !!! V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 TPs OK UNLOCK SUCCESSFULL SUCCESSFULL V 05wk47v38.1/19-01-07/RM-133 (c) Nokia. IMEI: 359568010331265 Operator: 0000000000000000 Profile bits: 2343000000000000 Open on GID1: 23430F Open on Mcc Mnc: 23430F Sim Status: Not locked |
01-14-2008, 16:03 | #9 (permalink) |
Member: 88410 Status: Offline Thanks Meter: 1 | Fair enough it may work on yours but people are finding problems with whatever 1.43 is doing. Earlier versions are working perfect. I'm sure anyone having problems will be glad to help find what's causing it but it's not 100% working for some. Any software developer has installations that won't work with certain setups without code modification. You see it all the time. Assuming that if it works there then it will work anywhere is not the best way of product testing, deployment is the best bug fixer. Maybe start a thread for people having issues and get logs or whatever you need to find out if there is a common setting/hardware/driver configuration that is causing the problem. With respect FWC |
01-14-2008, 19:15 | #11 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 40
Member: 76598 Status: Offline Sonork: 100.1575982 Thanks Meter: 47 | V 05.01/21-05-07/RM-237 (c) Nokia. IMEI: 355523017398100 V 05.01/21-05-07/RM-237 (c) Nokia. IMEI: 355523017398100 V 05.01/21-05-07/RM-237 (c) Nokia. IMEI: 355523017398100 V 05.01/21-05-07/RM-237 (c) Nokia. IMEI: 355523017398100 V 05.01/21-05-07/RM-237 (c) Nokia. IMEI: 355523017398100 V 05.01/21-05-07/RM-237 (c) Nokia. IMEI: 355523017398100 V 05.01/21-05-07/RM-237 (c) Nokia. IMEI: 355523017398100 V 05.01/21-05-07/RM-237 (c) Nokia. IMEI: 355523017398100 TPs OK TESTPOINT FAILED TestPoint Failed V 05.01/21-05-07/RM-237 (c) Nokia. IMEI: 355523017398100 Operator: 8000000000000000 Profile bits: 2343300000000000 Closed on Mcc Mnc: 23433F Closed on Mcc Mnc: 23486F |
01-14-2008, 22:59 | #14 (permalink) | ||
No Life Poster Join Date: Jun 2002 Location: UK/Espaņa Age: 54
Member: 12578 Status: Offline Thanks Meter: 60 | Quote:
You guys should accept that there IS a problem with latest software and tell us that you are working on a solution instead of making out we are all idiots that do not know what we are doing! I will ask all my customers to come here and make post about this software if you like and then you can tell them they are all funny because there is nothing wrong with your latest updated software shall i? WBR yeldar | ||
01-14-2008, 23:07 | #15 (permalink) | |
Member: 50511 Status: Offline Sonork: 100.109684 Thanks Meter: 307 | I THINK griffin team is sleep who can solve my problem ..??? Quote:
new software 1.43 have a bugs u can see lot of custumers have a same problem and can't say 30000 box sale and u have a problem i am not also to many people . http:///vbb/...eply&p=3014714 http://forum.gtibox.net/showthread.php?p=1869#post1869 http://forum.gtibox.net/showthread.php?p=1860#post1860 http://forum.gtibox.net/showthread.php?t=290 | |
N73 unlock failed again 2nd times | DaWizard | BB5BOX | 10 | 01-19-2008 09:42 |
N73 unlock failed | celluniversal | UID - Box | 10 | 10-29-2007 16:28 |
n73 unlock fail | KARIM GSM-ZONE | BB5BOX | 22 | 10-19-2007 22:50 |
N73 Unlock fail. Please try again. | ChouChou | BB5BOX | 0 | 09-26-2007 19:36 |
N73 unlock failed help griffin team | genciletisim | MT-BOX | 2 | 07-25-2007 19:16 |
