09-20-2007, 09:45 | #1 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Swansea, UK Age: 41
Member: 523318 Status: Offline Thanks Meter: 268 | N93 (RM-55) dead Phone let say flash OK but not power on. This is log: Vpp pin has 1.37V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg omap2420_m1_2nd.fg teflon_sam_nand_xsr_m1.fg BOOT OK... Phone Type: BB5 ------------------- SYSTEM ID Response: 11 blocks ------------- SYSTEM_ASIC_ID( APE ): 24200704 ASIC_MODE_ID( APE ): 00 PUBLIC_ID( APE ): 8BC21043B05563E41CDBEA8BB85E38A67A03FF25 ROOT_KEY_HASH( APE ): BA8710A7E1CD5A2909B9A875DB27AA2400000000 SYSTEM_ASIC_ID( RAP ): 000000010000022600010006010C192101003000 EM_ASIC_ID( RAP ): 00000294 EM_ASIC_ID( RAP ): 00000B21 PUBLIC_ID( RAP ): 2500010827900154871F7A1DBFFA7163442340B2 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): BAF3A9C3DBFA8454937DB77F2B8852B1 ROM_ID( RAP ): 273F6D55DFAAF68F --------------- Device ID Response: 3 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Samsung, 00EC 22E8 0000 6921 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 ============= Set FBus mode for info ============= VBat is 3.89V Vpp pin has 1.37V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 VPP is DISABLED. BB5 PM back Phone is in: Phone is not responding! Processing File: RM55PE200058.C0 Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg omap2420_m1_2nd.fg OMAP2420 UNISTORE-II-1.2.1 ALG teflon_sam_nand_xsr_m1.fg Backup: \GSM_35884200279414_9.r3c Erase RAP3 [00080000 - 007324DD] Erase RAP3 [00000000 - 0005FFFF] Erase RAP3 [00880000 - 00FEFFFF] Erase APE [00000000 - 0007FFFF] Erase APE [00080000 - 000DFFFF] Erase APE [00180000 - 049FFFFF] Erase[87.88 MB]... Waiting response for 320 Sec...in 1.60s Flash[47.65 MB]...in 107.28s * * Processed file in 122.16 seconds Processing File: rm55_8495429_V3.00.fpsx Low level format...fail Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg omap2420_m1_2nd.fg rap3gv3_2nd.fg RAP3Gv3_algo.fg omap2420_m1_2nd.fg OMAP2420 UNISTORE-II-1.2.1 ALG teflon_sam_nand_xsr_m1.fg Erase[0.00 MB]... in 2.58s Flash[17.37 MB]...in 59.94s * * Processed file in 130.50 seconds Extract content...fail Processing File: RM55PE200058.V06 Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg omap2420_m1_2nd.fg %%%%%%%% ERROR BOOTING: VPP is DISABLED. BB5 PM back Phone is in: Phone is not responding! Processing File: RM55PE200058.V06 Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg omap2420_m1_2nd.fg OMAP2420 UNISTORE-II-1.2.1 ALG teflon_sam_nand_xsr_m1.fg Backup: \GSM_35884200279414_9.r3c Erase APE [03500000 - 049FFFFF] Erase[21.00 MB]... Waiting response for 320 Sec...in 2.30s Flash[17.08 MB]...in 39.80s * * Processed file in 55.54 seconds * * * Phone flashing done in 1: 2 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! When I'm using modiffied cable with Tx2 line mtbox can't boot it. Vpp pin has 1.40V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 Boot... Using Tx2 Data line. rap3gv3_2nd.fg RAP3Gv3_algo.fg omap2420_m1_2nd.fg Failed to boot send APE 2ND (bad APE) Phone Type: BB5 ------------------- SYSTEM ID Response: 11 blocks ------------- SYSTEM_ASIC_ID( APE ): 24200704 ASIC_MODE_ID( APE ): 00 PUBLIC_ID( APE ): 8BC21043B05563E41CDBEA8BB85E38A67A03FF25 ROOT_KEY_HASH( APE ): BA8710A7E1CD5A2909B9A875DB27AA2400000000 SYSTEM_ASIC_ID( RAP ): 000000010000022600010006010C192101003000 EM_ASIC_ID( RAP ): 00000294 EM_ASIC_ID( RAP ): 00000B21 PUBLIC_ID( RAP ): 2500010827900154871F7A1DBFFA7163442340B2 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): BAF3A9C3DBFA8454937DB77F2B8852B1 ROM_ID( RAP ): 273F6D55DFAAF68F --------------- Device ID Response: 3 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Samsung, 00EC 22E8 0000 6921 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 ============= Set FBus mode for info ============= VBat is 3.87V Vpp pin has 1.39V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 And when I try flash with Tx2 line it olways stop after booting omap VPP is DISABLED. Using Tx2 Data line. BB5 PM back Phone is in: Phone is not responding! Processing File: RM55PE200058.C0 Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg omap2420_m1_2nd.fg %%%%%%%% ERROR BOOTING: What is going on?? Phone only blink 3 times. |
09-20-2007, 10:20 | #2 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | Vpp pin has 1.39V, Connected when you see that dont need to do that:VPP is DISABLED. have a problem with this cable may be resistor inside is small and need to be changed. TX2line is not correct connected for me!- Failed to boot send APE 2ND (bad APE) when is disabled all is ok - teflon_sam_nand_xsr_m1.fg BOOT OK... i thing you understand me. Nee uncheck 2 option - use TX2line and DisableVPP. also need to correct resistor in cable to can soft change state of phone from local to test and normal modes |
09-20-2007, 12:14 | #6 (permalink) |
Member: 409197 Status: Offline Thanks Meter: 75 | wait wait wait man! for whet model of phone we talk? n93 and n73 don't have a nothing same cables is different pinout is different(i thing) on a first post you talk for rm-55 (n93) on a last for n73 give real situation |
N93 rm-55 | Faheem Anjum | Nokia Base Band 5 ( BB-5 ) | 0 | 03-11-2008 07:53 |
N93 rm-55 pm needed urgently | .::Zafar Communication::. | MT-BOX | 0 | 01-26-2008 12:31 |
Nokia N93 - RM-55 - Flashes and Bulletins | mobilextreme | Nokia Base Band 5 ( BB-5 ) | 3 | 09-02-2006 18:37 |
