09-15-2007, 08:29 | #4 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | ok resistor can be need to be little small like 8.1k diod is not a problem. At me work fine with 10k but may be this is a boarder for phone. DONT FORGET TO CONNECT CHARGER FOR NOKIA TO MT-BOX FOR A N95!!!!!!!!! |
09-15-2007, 08:40 | #5 (permalink) |
No Life Poster Join Date: Mar 2002 Location: AnyClient Age: 44
Member: 10485 Status: Offline Sonork: 100.66876 Thanks Meter: 396 | for me it is working, but seem N95 connector by Iphone is have small problem, the pins not correct position, so push hard from the right to left side so all pins can connect properly! |
09-15-2007, 21:38 | #9 (permalink) |
Major Poster Join Date: Aug 2007 Location: Berna-(Swiss)- Age: 46
Member: 561717 Status: Offline Thanks Meter: 0 | the cable is perfect with schematic..(confirmed by tester multimeter) 3 solutions: 1- the schematic cable don't work 100% max 50% 2- the problem is mt-box (corrupted of faulty) 3- the problem is the phone. |
09-16-2007, 05:54 | #10 (permalink) |
Member: 10485 Status: Offline Sonork: 100.66876 Thanks Meter: 396 | my recommendation that you still want to work with MTBOX NOKIA in future is to buy all BB5 10pins cable package from IPMART, i had already bought and work like a charm! |
09-16-2007, 11:25 | #11 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Quote:
Did u mean That we Have To conect External power Supply (Nokia Charger) To Mt Box Nokia????While Flashing a N95 Phone..and what is The Exect Configartion of Nokia N95 Cable..is 6 Pin N95 Cable can works with Mt Nokia??? | |
09-16-2007, 13:50 | #12 (permalink) |
Member: 409197 Status: Offline Thanks Meter: 75 | for good working with nokia n95 need to be 6pin cable with TX2Line connected.I use shematic who i am post to forum with diod and resistor and never have a problem.Diod can be any normal diod. Only for a N95 need to be connected charger to MT-BOX because power is too low and phoen cant stay in mode he restart alone without charger that all. |
The Following User Says Thank You to 911GT For This Useful Post: |
09-26-2007, 09:14 | #13 (permalink) |
Freak Poster Join Date: Jun 2004 Age: 44
Member: 68672 Status: Offline Thanks Meter: 6 | I have problem handset not booting while before Downgrade handset was in working condition I'm using same cable pinout MTBOX: xxxxxxxxxx - Nokia Flash/Repair v1_36 Box: CR V xxxxxxxxx Code: NK V 1.001 1047 SN: 006c9393d7 Nokia Unlimited: 10 times started SonyEricsson Trial: 10 left, each max 15min Scanning files, please wait... Done WARNING: THE VERSION YOU SELECTED: 10.0.018 is NOT the highest installed!!! the highest available is: 11.0.026 ============= Set Flash mode for info ============= VBat is 3.92V Vpp pin has 0.09V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 Boot... RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg Failed to boot send APE 2ND (bad APE) Phone Type: BB5 ------------------- SYSTEM ID Response: 11 blocks ------------- SYSTEM_ASIC_ID( APE ): 24200705 ASIC_MODE_ID( APE ): 00 PUBLIC_ID( APE ): F9F1943CB6514A187A010E1140B65541C2D66CC5 ROOT_KEY_HASH( APE ): BA8710A7E1CD5A2909B9A875DB27AA2400000000 SYSTEM_ASIC_ID( RAP ): 000000010000022600010006400C192101021103 EM_ASIC_ID( RAP ): 00000295 EM_ASIC_ID( RAP ): 00000B22 PUBLIC_ID( RAP ): 12100019256E0058DF326A75A7BB671991CC0E19 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): CAEEBB65D3C48E6DC73B49DC5063A2EE ROM_ID( RAP ): A8C1D6713E691FF8 --------------- Device ID Response: 3 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Amd, 0001 0035 0000 6921 Storage Device Contents: Owner Asic: RAP 0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ============= Set FBus mode for info ============= VBat is 3.92V Vpp pin has 0.12V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 ------------------- When try to flash handset ============= Set FBus mode for info ============= VBat is 3.92V Vpp pin has 0.12V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 BB5 PM back Phone is in: Phone is not responding! Processing File: RM-159_10.0.018_PR.C0R Boot... RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg %%%%%%%% ERROR BOOTING: Anybody can help me plz |
N95 8gb keypad don't work | Freshbol | Chinese Models & Cloned Phones | 5 | 08-29-2008 11:03 |
N95 Cable Modify MNI 5P Diagram !!! | Gsm Lab | MT-BOX | 8 | 12-21-2007 11:30 |
N95 ufs cable don't work | h&c | MT-BOX | 2 | 09-08-2007 17:36 |
P910 cable schematics, please help! don't work with V804 cable | GsmSoft_Team | UST Pro II | 1 | 12-24-2006 09:08 |
