Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 09-17-2007, 11:35   #1 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
N95 Flashing error
Phone is in: Local mode
Model: RM-159 (Aalto (EU) )
V 06wk41v18.4/13-03-07/RM-159 (c) Nokia
Production serial number SHF690919
Product code 0547869
Module code
Basic production code 0537959
Flash code
Order number
Long production SN 0
MCU SW V 06wk41v18.4/13-03-07/RM-159/(c) Nokia
HW 5650
PCI
RFIC 17141714
DSP ibusal_aalto_06wk41v20
Retu 15
Tahvo 21
IMEI: 3522550**405283
WARNING: VPP pin is not connected, disabling VPP.
Using Tx2 Data line.
BB5 PM back Phone is in: Local mode
Backup file: C:\Program Files\GriffinTeam\MT-Box\bb5bckup\RM-159_3522550**405283.pm
Processing File: RM-159_10.0.018_PR.C0R
Boot...
RAPIDOv102_2nd.fg
RAPIDOv11_algo.fg
omap2420_m1_2nd.fg
RAPIDOv102_2nd.fg
RAPIDOv11_algo.fg
omap2420_m1_2nd.fg
%%%%%%%% ERROR BOOTING:
always this error.Cable is fully modified 10k and diode in4001 as 911Gt describe..any idea to solve the problem.
Note phone show only NOKIA logo..caused by a wrong PPm file.
Old 09-17-2007, 12:02   #2 (permalink)
..::Mobile Smoker::..'s Avatar
Member: 170380
Sonork: 100.1577994
Thanks Meter: 3,022
Module code
Flash code
Order number
HW 5650
PCI
RFIC 17141714
Retu 15
Tahvo 21
Boot...
RAPIDOv102_2nd.fg
RAPIDOv11_algo.fg
omap2420_m1_2nd.fg
RAPIDOv102_2nd.fg
RAPIDOv11_algo.fg
omap2420_m1_2nd.fg
bro flash ur set with dead usb & post result
Old 09-17-2007, 12:15   #3 (permalink)
Member: 134761
Thanks Meter: 40
try to check vPP disable and if can use 10 pin for solution N95 , I have already flash many times and all ok wiht mt 137
Old 09-17-2007, 12:19   #4 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
phone not Take usb mode...and also Jaf not supported his phone....
Old 09-17-2007, 12:19   #5 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
reinstall your setup and dis Vpp
The Following User Says Thank You to maplegsm For This Useful Post:
Old 09-17-2007, 12:43   #6 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
i did it.....but same problem....
The Following User Says Thank You to ..::AppleLinks::.. For This Useful Post:
Old 09-17-2007, 12:44   #7 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
m useing 10 pin cable and vpp is diblae u can check in info....
Old 09-17-2007, 13:22   #8 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
please check all wires from shematic is go to correct place.
I thing have a anything wrong. If all is ok don't need software to say VPP not connected!!!
need to b connected to can be flashed this phone but for boot is not needed.
The Following User Says Thank You to 911GT For This Useful Post:
Old 09-17-2007, 13:35   #9 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
i think all i sok.bcz cable is new..it have 6 pins at bottom which touch te phone pcb serface.this cable is called 6 pin or 10pin?and i modifi by u r methode 10k and diode in4001.
Old 09-19-2007, 06:51   #10 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
Diode is realy not mandatory, but there is important to have Rx, Tx, M-Bus and TX2 line, use 7,5k up to 10k resistor in BSI line to achieve Local mode after flashing ( BSI value do not affect over flashing, but is good to make it) ... In some cases / like N95 with big consumption / is good to support MT-Box with additional power from ACP-12. Best way is to not use crapy NK adapter, but make 10-pin cable direct for MT-Box plug.
The Following User Says Thank You to debeliamark For This Useful Post:
help pls n95 flash error phisi Chinese Cocktail 8 06-16-2008 13:20
N95 flashing error lgman MT-BOX 2 12-27-2007 21:58
n95 flash error hamid123 Universalbox 7 08-19-2007 08:24
Page generated in 0.20394 seconds with 9 queries
