01-11-2008, 19:11 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: EVERYWHERE U GO Age: 46
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | n95 pm backup resored |
01-13-2008, 15:28 | #8 (permalink) |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | but i think there is problem in restoring in N95 see the link... http:///vbb/...d.php?t=486145 supporter should test and give us a correct procedure... thanks sir... |
01-14-2008, 08:47 | #10 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2004 Location: MicroControllers:: Age: 43
Member: 78619 Status: Offline Thanks Meter: 297 | but in n95 schema need to use 10 in groung to bsi and in line u need to use diode.................. thats what in support site too,,,, br khalid |
01-14-2008, 10:44 | #11 (permalink) |
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | yes i have modified cable only.... but we are waiting that supporter should test this N95 with 20 version erase-->flash --> restore and tell the result... |
01-14-2008, 11:46 | #12 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | We start with this phone: Phone is in: Local mode Scanning files, please wait... Done Selected Highest installed version: 12.0.013 Model: RM-159 ( N95) V 06wk41v43.1/15-10-07/RM-159 (c) Nokia Production serial number SJG339828 Product code 0536076 Module code Basic production code 0530865 Flash code Order number Long production SN 0 MCU SW V 06wk41v43.1/15-10-07/RM-159/(c) Nokia HW 5640 PCI RFIC 17141714 DSP 06w41pb_07w39 APE Variant 20.0.01505.01 APE Test rm159_ENO_x_2007wk02v0.070 Retu 15 Tahvo 21 APE HW 1 APE ADSP SW 256 APE BT HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. IMEI: 352255010144834 V 06wk41v43.1/15-10-07/RM-159 (c) Nokia IMEI: 352255010144834 Operator: 2440700000000000 Profile bits: 0000000000000000 Sim Status: Not locked Erase full phone: KEBi BOX: 0004e4**** - Nokia Flash/Repair v1_42_3 Box: CR V 1.001 256 Code: NK V 1.001 1048 SN: 0004e4e63d Nokia Unlimited: 1120 times started SonyEricsson Unlimited: 363 times started VPP is DISABLED. Using Tx2 Data line. BB5 PM back Phone is in: Phone is not responding! Processing File: BB5Erase_UNI_rapido.bin Boot... RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg OMAP2420 UNISTORE-II-1.5.1 ALG teflon_sam_nand_xsr151_m1.fg NPC 0x1C0 HWC 0x100 CCC 0x180 Backup: \GSM_35225501014483.r3c Erase RAP3 [00000000 - 007FFFFF] Erase RAP3 [00800000 - 00FFFFFF] Erase RAP3 [01000000 - 01FFFFFF] Erase[32.00 MB]... Waiting response for 320 Sec...in 37.70s Flash[0.00 MB]...in 0.00s * * Processed file in 51.72 seconds * * * Phone flashing done in 0:59 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! We flash phone with latest version: KEBi BOX: 0004e4**** - Nokia Flash/Repair v1_43 Box: CR V 1.001 256 Code: NK V 1.001 1048 SN: 0004e4e63d Nokia Unlimited: 1122 times started SonyEricsson Unlimited: 363 times started Scanning files, please wait... Done Selected Highest installed version: 20.0.015 VPP is DISABLED. Using Tx2 Data line. BB5 PM back Phone is in: Phone is not responding! Processing File: RM-159_20.0.015_PR.C0R Boot... RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg OMAP2420 UNISTORE-II-1.5.1 ALG teflon_sam_nand_xsr151_m1.fg Erase RAP3 [00080000 - 007AB531] Erase RAP3 [00000000 - 0005FFFF] Erase RAP3 [00880000 - 00FDFFFF] Erase APE [00000200 - 0000AFFF] Erase APE [0000B800 - 000AFFFF] Erase APE [00000000 - 00001000] Erase APE [0000D800 - 0000EA00] Erase APE [00080000 - 000BFFFF] Erase APE [000E0000 - 0045FFFF] Erase APE [004C0000 - 0073FFFF] Erase APE [00A40000 - 0633FFFF] Erase[110.86 MB]... Waiting response for 320 Sec...in 3.38s Flash[69.43 MB]...in 126.19s * * Processed file in 138.42 seconds Processing File: RM159_20.0.011_030_U01_uda.fpsx Boot... RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg OMAP2420 UNISTORE-II-1.5.1 ALG teflon_sam_nand_xsr151_m1.fg Erase APE [06340000 - 0FA3FFFF] Erase[151.00 MB]... Waiting response for 320 Sec...in 2.88s Flash[24.49 MB]...in 46.13s * * Processed file in 59.84 seconds Extract content...OK Processing File: RM-159_20.0.015_PR.v05 Boot... RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg OMAP2420 UNISTORE-II-1.5.1 ALG teflon_sam_nand_xsr151_m1.fg Erase APE [04C40000 - 0633FFFF] Erase[23.00 MB]... Waiting response for 320 Sec...in 0.59s Flash[17.49 MB]...in 30.53s * * Processed file in 39.92 seconds * * * Phone flashing done in 4:23 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... IMEI: 12345610654321? Factory Default Settings...OK V 06wk41v43.1/15-10-07/RM-159 (c) Nokia IMEI: 12345610654321? Failed to Read We now have a flashed phone with bad IMEI and simlock data. KEBi BOX: 0004e4**** - Nokia Flash/Repair v1_43 Box: CR V 1.001 256 Code: NK V 1.001 1048 SN: 0004e4e63d Nokia Unlimited: 1123 times started SonyEricsson Unlimited: 363 times started Sending to phone Resource:134 Warning: Failed to write 134:0000, 1bytes. Use SX4 button to authorize Sending SIMLOCK record... Boot... Using Tx2 Data line. RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg teflon_sam_nand_xsr151_m1.fg BOOT OK... Send NPC Certificate Send HWC Certificate Send CCC Certificate RAP3 Certificate sent SUCCESSFULLY ============= Set FBus mode for info ============= Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-159 ( N95) V 06wk41v43.1/15-10-07/RM-159 (c) Nokia IMEI: 352255010144834 V 06wk41v43.1/15-10-07/RM-159 (c) Nokia IMEI: 352255010144834 Operator: 2440700000000000 Profile bits: 0000000000000000 Sim Status: Not locked now we can restore and all another fields from Pm backup: KEBi BOX: 0004e4**** - Nokia Flash/Repair v1_43 Box: CR V 1.001 256 Code: NK V 1.001 1048 SN: 0004e4e63d Nokia Unlimited: 1124 times started SonyEricsson Unlimited: 363 times started V 06wk41v43.1/15-10-07/RM-159 (c) Nokia IMEI: 352255010144834 Operator: 2440700000000000 Profile bits: 0000000000000000 Sim Status: Not locked Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 352255010144834 busy, waiting... Connect... Login... busy, waiting... PMM Authorize SUCCESSFULL Sending to phone Resource: 36 Sending to phone Resource: 58 Sending to phone Resource: 60 Sending to phone Resource: 6B Sending to phone Resource: C1 Sending to phone Resource: D0 Sending to phone Resource: D9 Sending to phone Resource: EF Sending to phone Resource:123 Sending to phone Resource:135 Sending to phone Resource:142 Sending to phone Resource:149 Sending to phone Resource:14E Sending to phone Resource:155 Sending to phone Resource:162 Sending to phone Resource:164 V 06wk41v43.1/15-10-07/RM-159 (c) Nokia IMEI: 352255010144834 Operator: 2440700000000000 Profile bits: 0000000000000000 I dont see any problem with good cable. |
01-14-2008, 12:31 | #15 (permalink) |
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | Phone is in: Local mode Model: RM-159 ( N95) V 06wk41v31/05-06-07/RM-159 (c) Nokia Production serial number MAI205348 Product code 0547709 Module code Basic production code 0530865 Flash code Order number Long production SN 0 MCU SW V 06wk41v31/05-06-07/RM-159/(c) Nokia HW 5900 PCI RFIC 17141714 DSP dsprap_pb06w41v34 APE SW Core 12.0.013 APE Variant 12.0.01349.01 APE Test rm159_eno_2007wk16v0.170 Retu 15 Tahvo 22 APE HW 1 APE ADSP SW 256 APE BT HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. IMEI: 358998010198292 Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 358998010198292 busy, waiting... e/640/command execution error; Server error superdongle authorisation procedudure failed |
how to create a dejan free backup from mt pm backup | scutarus | Nokia Base Band 5 ( BB-5 ) | 6 | 09-21-2008 12:55 |
make CRT and PM backup | adnanali | Nokia Base Band 5 ( BB-5 ) | 3 | 06-12-2007 09:40 |
6230i RM-72 FULL PM backup wanted SOS | crusher | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 04-27-2005 22:45 |
