02-27-2008, 22:49 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Age: 42
Member: 69113 Status: Offline Thanks Meter: 5 | N95 problems - few good questions F 06wk41v31/05-06-07/RM-159/(c) Nokia Auto backup SIMLOCK... ================================= bb5bckup\356996018354000.pm nBackup file already exists! SKIPPING backup ================================= Using fixed version support !!! V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 356996018354000 V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 356996018354000 IMEI: 356996018354000 V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 356996018354000 TPs OK not UNLOCK SUCCESSFULL SUCCESSFULL IMEI: 356996018354000 Operator: 0000000000000000 Profile bits: 2600300000000000 Closed on GID1: 26003F Closed on Mcc Mnc: 26003F Failed to locate SX4 on PC. Connecting server Connect... Login... login FAIL Failed to login, terminating authorization procedure! Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 356996018354000 e/400/command execution error; Server error Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 356996018354000 e/400/command execution error; Server error Phone has counter 10/10 0/3 1-st question - what does it mean TP OK, unlock not sucesfull??? After this phone is not unlocked, i use wersion 1.45 whitch schod unlock this phone 2 - How can i write pm backup? Go to eeprom tak, chose pb backup with imei from my phone and write with marked all fields? is it sawe? 3 - why cant i make sx4 auth? when i see login window i schud enter login and pass tah i gett from my reseller? i enter this login but i see serwer error why? Do i have to make sx to write pm backup? 4- How can i unlock my phone? |
02-27-2008, 22:58 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Where money is made Age: 33
Member: 390642 Status: Offline Sonork: 100.1573430 Thanks Meter: 2,476 | All attemps for unlocking by F-bus cable are used if u want to unlock it u must write PM308 back up and if u dont hace it u need to Ask an RPL thats the unic way to unlock ur N95...if u have back up make sure u write back up that is from this fone is u wirte other fone back up this will kill ur fone and u are write u must go to eeprom tab and select file and press write...try and post reuslt... P.S:u need F-bus cable and BR, Tito Millo |
02-28-2008, 05:16 | #3 (permalink) |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | already posted many times before.... for N95 you are intended to connect the ACP-12 charger to the MT nokia and test point should be kept while time...inorder to send the triggers..to it. and Sx4 will be available if you keep on trying.... |
02-28-2008, 22:33 | #6 (permalink) |
Member: 69113 Status: Offline Thanks Meter: 5 | Ok so now i will make sx4, but? What is mean not unlock SUCESFULL??? phone has 10/10 and 0/3 i schud be unlocked wuth 14.5 and 14.5.1 but still no sucess.... A can i write safe all fields from pm backup? Mark all fileds when write after make sx4? |
02-29-2008, 16:20 | #9 (permalink) |
Member: 69113 Status: Offline Thanks Meter: 5 | V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 356996018354000 TPs OK not UNLOCK SUCCESSFULL SUCCESSFULL V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 356996018354000 Operator: 0000000000000000 Profile bits: 2600300000000000 Closed on GID1: 26003F Closed on Mcc Mnc: 26003F V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 356996018354000 Operator: 2600300000000000 Operator Name: IDEA Centertel;Poland Profile bits: 0000000000000000 Closed on GID1: 26003F Closed on Mcc Mnc: 26003F Counters 10/10, 0/3 Cant unlock this phone, with 145.1, still not unlock sucessfull, and cant write pm, still cant conect to serwer, i send pm to mr 911 and waiting |
02-29-2008, 16:30 | #12 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | mate we have a smal bug on unlock n95 and we will fix in a few days but with some try need to will ok.restore simlock and try again ,hold TP more time,dont disconnect it fast after you see TP OK |
02-29-2008, 18:52 | #13 (permalink) |
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | here is the log... which i have done ... F 06wk41v31/05-06-07/RM-159/(c) Nokia Auto backup SIMLOCK... ================================= bb5bckup\358998010752700.pm 134 : 0 0x1 bytes 134 : 1 0x2000 bytes 134 : 3 0x1 bytes 134 : 4 0x1 bytes 134 : 5 0xA bytes 134 : 6 0x1 bytes 134 : 7 0x1 bytes 134 : 8 0x1 bytes 134 : 9 0x28 bytes ================================= Using fixed version support !!! V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 358998010752700 V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 358998010752700 V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 358998010752700 V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 358998010752700 V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 358998010752700 V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 358998010752700 TPs OK UNLOCK SUCCESSFULL SUCCESSFULL V 06wk41v31/05-06-07/RM-159 (c) Nokia IMEI: 358998010752700 Operator: 0000000000000000 Profile bits: 2342000000000000 Open on GID1: 23420F Open on Mcc Mnc: 23420F Open on GID1: 23594F Open on Mcc Mnc: 23594F Sim Status: Not locked i think you need to keep the TP for a time...(few seconds) |
A few software Questions/Requests for MotoQ9M | hammerhead13 | HTC & PDA WM( With Touchscreen) | 0 | 04-21-2008 21:49 |
A few good word | GSM_MARSHALS | Redbox | 1 | 06-30-2006 13:22 |
Few V3r questions... | cellcenter | Motorola P2k | 3 | 06-25-2006 12:48 |
Few newbie question about usb smart, thanks | redsword | SonyEricsson (USB-Smart) | 4 | 11-28-2005 08:19 |
Few neeb questions | Beaujolais | Motorola P2k | 0 | 03-31-2004 02:46 |
