Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > Griffin Products > MT-BOX
Old 10-17-2007, 13:11   #1 (permalink)
Member: 96950
N95 Wont unlock
i have an N95 to unlock, with mt nokia/ mt lite, i have done a 5200 and 6280 fine, but this fone will not see the test points at all, i even looked under the microscope to check tp were on good, anyone got any ideas on why this phone will not see test points?
thanks
jason
Old 10-17-2007, 13:42   #2 (permalink)
shaheen15's Avatar
Member: 137426
What cable do you use. I prefer USB cable (like V3), set MTBOX to USB mode, don't forget to put in local mode and unlock
Old 10-17-2007, 14:10   #3 (permalink)
snsoftkiller's Avatar
Member: 250468
Sonork: 100.110362
thanks
jason
Post your logs here !!! Dont forget to really check if you connect in the correct tp cause near them you have big contact that look likes to tp. Its also happen to me the 1st time I did an N95.
Old 10-17-2007, 14:36   #4 (permalink)
Member: 76937
my N95 not communicates nor for the USB nor for the handle fbus, some tip on this? I place the handle fbus and it binds direct, not enters in test mode
sorry , my english is very poor
Old 10-17-2007, 14:42   #5 (permalink)
Member: 250468
Sonork: 100.110362
Bro turn fully on your N95, after is starts connect usb cable and choose "Pc suite or Nokia mode". In MT soft choose "usb mode", if drivers already installes then you clic on phone info button. If drivers not yet installed wait till windows show message "drivers installed". You can know service your phone.
Old 10-17-2007, 15:09   #6 (permalink)
Member: 96950
i have tried all that, i even checked the tp under microscope, i feel the box is faulty, but i have sent it off to get it checked out, so i will see if it is faulty, someone has said it could be a bad connection to the Nokia MT Box
Old 10-17-2007, 15:19   #7 (permalink)
Member: 250468
Sonork: 100.110362
Try to reboot your pc and try again !!!
Old 10-17-2007, 17:24   #8 (permalink)
harim_1981's Avatar
Member: 243961
Sonork: 100.1591654
first check whether it is in test mode...
then give "info"
post log here...
without log..we cant help u more...
Old 10-17-2007, 21:46   #9 (permalink)
shaheen15's Avatar
Member: 137426
Have you installed Nokia PC Suite on your pc?
Old 11-01-2007, 06:45   #10 (permalink)
Member: 203445
Working Perfect
Auto backup SIMLOCK...
bb5bckup\3522xxxxxxxxxx.pm
134 : 0 0x1 bytes
134 : 1 0x2000 bytes
134 : 3 0x1 bytes
134 : 4 0x1 bytes
134 : 5 0xA bytes
134 : 6 0x1 bytes
134 : 7 0x1 bytes
134 : 8 0x1 bytes
134 : 9 0x28 bytes
V 06wk41v31/05-06-07/RM-159 (c) Nokia
IMEI: 3522xxxxxxxxxx
Operator: 0000000000000000
Profile bits: 2341500000000000
Closed on GID1: 23415F
Closed on Mcc Mnc: 23415F
Using Account: uMTPlitexxxxxx
Connect...
Resp:
o/0110/hello there
Login...
OK, available count
40;
busy, waiting...
Server Response OK.
CONNECT TPs
TPs OK
UNLOCK SUCCESSFULL
SUCCESSFULL
Open on GID1: 23415F
Open on Mcc Mnc: 23415F
Sim Status: Not locked
e-gsmshop
Old 11-01-2007, 07:30   #11 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
I Have Already Unlock Some 95 Without Any Problem And Tp Is So Easy Then 6280,73 , Check Carefully That Yours All Cables Are Attached In Good Condition After That Put Set In Local Mode (remeber Bsi Line For This Model Is Not At Same Place Like Othere Models ),check Simlock Status If Every Thing Alright Then No Problem To Unlock ,mt Is A Great Tool I Love It.
Br.
Asif Nawab.
Old 11-03-2007, 18:11   #12 (permalink)
Member: 76937
In handle USB now communicates correctly , but in the VBat linking, Groung and BSI the device is not communicated, does not enter in TEST MODE, nor nothing This that stops me is strange, therefore one puldo in power nothing only happens, but if to hold the button it binds, but not if exactly thus it is not communicated.
Old 11-04-2007, 02:55   #13 (permalink)
Member: 196494
use n95 clip with battery connected hold on to phone with band make sure green light shows on mtpro and then read phone works for me every time
n95 wont unlock mp3hot JAF No Tp Unlocker by Cinek 11 04-12-2009 10:26
New version wont unlock n95 THE CLASH Universalbox 5 11-25-2008 21:01
N95 - BB5Box wont unlock twisterfan BB5BOX 10 10-31-2007 19:18
Page generated in 0.65683 seconds with 11 queries
