02-10-2007, 12:13 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: malaysia Age: 40
Member: 149041 Status: Offline Sonork: 100.114578 Thanks Meter: 61 | need help imei ???????? 2610 but when i write RPL file from Andro still same ??????????????????? pls how to solve it!!!! Flashing LOG Processing File: rh86_87__04.51.mcusw Boot... ASIC ID: 3040 DCT4 u3_2nd.fia u3_amd.fia 8486CF92646763A94DA3BD3D6D66 Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2C7E 0035 7021, 11 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[9.87 MB]... erasing region [01000000 to 0101FFFF] erasing region [01020000 to 018DFFFF] erasing region [01EE0000 to 01FDFFFF] in 42.00s Flash[8.53 MB]...in 27.31s * * Processed file in 77.84 seconds Processing File: rh86_87__04.51.image_qb Low level format...OK Boot... ASIC ID: 3040 DCT4 u3_2nd.fia u3_amd.fia 84D06AAC65A28096488ACF356A38 Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2C7E 0035 7021, 11 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[3.37 MB]... erasing region [01B80000 to 01EDFFFF] in 14.69s Flash[1.94 MB]...in 6.41s * * Processed file in 41.75 seconds Extract content...OK Processing File: rh86_87__04.51.ppm_qb Boot... ASIC ID: 3040 DCT4 u3_2nd.fia u3_amd.fia 8478ECA109E3605A143A7969FAA6 Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2C7E 0035 7021, 11 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[2.62 MB]... erasing region [018E0000 to 01B7FFFF] in 10.94s Flash[2.42 MB]...in 11.83s * * Processed file in 31.89 seconds * * * Phone flashing done in 2:44 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... V 04.51/12-10-06/RH-86 (c) Nokia. IMEI: ??????????????? Factory Default Settings...OK Reset user code...User Code was: 12345 Successfull, code is 12345 Write RPL Rebuild FLASH and UEM for imei: 357057003318374 IMEI Sent successfully Unlock phone... Phone is in: Test mode Imei: ??????????????? Info OK USING ALREADY COMPUTED DATA Operator: 876D3DE614B6CE38 Profile bits: E47E41050101C6C3 Sim Status: Not locked FINISHED OK Original Imei set...IMEI: OK Completed IMEI Rebuild Pacth Sim Boot... ASIC ID: 3040 DCT4 u3_2nd.fia u3_amd.fia 8486CF92646763A94DA3BD3D6D66 Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2C7E 0035 7021, 11 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[0.12 MB]... erasing region [010A0000 to 010BFFFF] in 0.56s Flash[0.13 MB]...in 0.44s * * Processed file in 9.45 seconds Sending Unlock command ...Phone is in: Local mode Imei: ??????????????? =========== PATCH UNLOCK - FAILED =========== Restoring original flash!!! Boot... ASIC ID: 3040 DCT4 u3_2nd.fia u3_amd.fia 8486CF92646763A94DA3BD3D6D66 Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2C7E 0035 7021, 11 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[0.12 MB]... erasing region [010A0000 to 010BFFFF] in 0.58s Flash[0.13 MB]...in 0.42s * * Processed file in 9.55 seconds |
02-10-2007, 12:57 | #5 (permalink) |
Member: 149041 Status: Offline Sonork: 100.114578 Thanks Meter: 61 | Problem solve How to fix ----------------------------------------- Change new Flash Must Change New UEM too than full flash and write Asic-11 RPL than must hav griffin verser acc than it will unlock with credit and RPL ...... this i done it ================================================== = Phone is in: Local mode Scanning files, please wait... Done Selected Highest installed version: 04.51 Model: RH-86 ( 2610) V 04.51/12-10-06/RH-86 (c) Nokia. Production serial number KND658174 Product code 0540044 Module code 0202930 Basic production code 0530409 Flash code Order number Long production SN MCU SW V 04.51/12-10-06/RH-86/(c) Nokia. HW 0601 PCI UEM 1314 UPP 12352 RFIC 0500 DSP P05w45.v42 LCD ELBE PPM V 04.51/12-10-06/RH-86_87/(c) Nokia. /QB Content Pack Content: qb/V 04.51/12-10-06/RH-86_87/(c) Nokia. IMEI: 357057003318374 Sory i hav post ur Name in 1st post BRO!!! |
need help nokia 2610 rh 86(strange problem) | ar_memon2 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 03-17-2010 21:43 |
need help for 2610 rh-87 | parihar | Universalbox | 4 | 02-26-2009 10:15 |
Need urgent Help!!! Nokia 2610 Dead! | Za333 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 12-26-2007 07:29 |
2610 dead need help.... | tony84 | Universalbox | 4 | 08-22-2006 08:06 |
