NEW USER need help Please. Hi i am a new user with MT-box, i was trying to flash a Nokia 8801 but always ASIC ID 0000 what is the problem with that? i can do unlock an everything normally but it's just i cannot flash.Also 6101 and 6020 cannot flash another LP into any 850MHZ phone. Can i flash LP from a 6101a phone to a 6101b Phone? And how to see the LP? which LP is for what language? Can anyone help me out. Thank you 10000000x BR Cellunlock |
ASIC ID 0000 mean that the power not connect to the phone correctly |
Hello sir. Processing File: nhm75504.530 Boot... ASIC ID: 0120 DCT4 %%%%%%%% ERROR BOOTING: I erased EEPROM Files in Custom Erase menu.What should I do? |
check the file in the flash folder |
Thanks. SOLVED: You are right.The problem was FIA files that are located in /FlashLoaders .Thanks.:) |
Asic 0000 So what can i do....i put in the phone with the cable and the phone can power up. So what power should i use? BR Cellunlock |
Power. 5 Attachment(s) The power isn't necesary.Connect the box at USB port.Without ACP-12 Power connected.Here, Windows don't detect the MtBox fine with the ACP-12 power inserted.Then,wait 10-20 second (let windows detect and install it) then start your Nokia Flash/Repair software.Red LED is ON.After that,you could connect the ACP-12.I didn't see any difference.Then,make sure that you use the MT-Box Adapter.Connect this adapter with your phone cable and phone to cable.Then Nokia MT-Box to MT-Box adapter (wich is already connected with phone via cable).The green LED on MT-Box Adapter is ON.Even if on your screen phone Local Mode isn't displayed you can flash-it.Here works like a charm.Look. I hope that this help you.Sorry for my English. P.S. GSM-Form Team or Griffin Team can use this images to make a useful tutorial for newbies like me. |
Power part 2. 2 Attachment(s) The power isn't necesary.Connect the box at USB port.Without ACP-12 Power connected.Here, Windows don't detect the MtBox fine with the ACP-12 power inserted.Then,wait 10-20 second (let windows detect and install it) then start your Nokia Flash/Repair software.Red LED is ON.After that,you could connect the ACP-12.I didn't see any difference.Then,make sure that you use the MT-Box Adapter.Connect this adapter with your phone cable and phone to cable.Then Nokia MT-Box to MT-Box adapter (wich is already connected with phone via cable).The green LED on MT-Box Adapter is ON.Even if on your screen phone Local Mode isn't displayed you can flash-it.Here works like a charm.Look. I hope that this help you.Sorry for my English. P.S. GSM-Form Team or Griffin Team can use this images to make a useful tutorial for newbies like me. |
