Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > Griffin Products > MT-BOX
Old 02-12-2006, 00:09   #1 (permalink)
Member: 19689
NEW USER need help Please.
Hi i am a new user with MT-box, i was trying to flash a Nokia 8801 but always ASIC ID 0000 what is the problem with that? i can do unlock an everything normally but it's just i cannot flash.Also 6101 and 6020 cannot flash another LP into any 850MHZ phone. Can i flash LP from a 6101a phone to a 6101b Phone? And how to see the LP? which LP is for what language? Can anyone help me out. Thank you 10000000x
Cellunlock
Old 02-12-2006, 07:11   #2 (permalink)
Member: 11954
ASIC ID 0000 mean that the power not connect to the phone correctly
Old 02-13-2006, 03:58   #3 (permalink)
NKV
Member: 232316
Hello sir.
Processing File: nhm75504.530
Boot...
ASIC ID: 0120
DCT4
%%%%%%%% ERROR BOOTING:
I erased EEPROM Files in Custom Erase menu.What should I do?
Old 02-13-2006, 06:44   #4 (permalink)
Member: 11954
check the file in the flash folder
Old 02-13-2006, 17:19   #5 (permalink)
NKV
Member: 232316
Thumbs up Thanks.
SOLVED:
You are right.The problem was FIA files that are located in /FlashLoaders .Thanks.
Old 02-13-2006, 23:20   #6 (permalink)
Member: 19689
Asic 0000
So what can i do....i put in the phone with the cable and the phone can power up. So what power should i use?
Cellunlock
Old 02-14-2006, 00:33   #7 (permalink)
NKV
Member: 232316
Power.
The power isn't necesary.Connect the box at USB port.Without ACP-12 Power connected.Here, Windows don't detect the MtBox fine with the ACP-12 power inserted.Then,wait 10-20 second (let windows detect and install it) then start your Nokia Flash/Repair software.Red LED is ON.After that,you could connect the ACP-12.I didn't see any difference.Then,make sure that you use the MT-Box Adapter.Connect this adapter with your phone cable and phone to cable.Then Nokia MT-Box to MT-Box adapter (wich is already connected with phone via cable).The green LED on MT-Box Adapter is ON.Even if on your screen phone Local Mode isn't displayed you can flash-it.Here works like a charm.Look.
I hope that this help you.Sorry for my English.
P.S. GSM-Form Team or Griffin Team can use this images to make a useful tutorial for newbies like me.
Old 02-14-2006, 00:36   #8 (permalink)
NKV
Member: 232316
Power part 2.
new User, need HELP with new Update dmobile1 Cyclonebox 3 01-26-2010 04:46
Usb-smart New User Need Help makroud Others (USB-Smart) 7 05-08-2006 11:02
New user need help! Jimmoh Board, Server and Login Problems/Support 1 10-20-2005 06:39
New User need help C55!!! gentus E-Gold Based Phones 1 03-28-2003 19:37
Page generated in 0.50919 seconds with 12 queries
