01-11-2008, 14:08 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: france
Member: 135019 Status: Offline Thanks Meter: 1 | No comunication between Mtbox and lite That is the problem. When i try to read phone with MTlite it's imposible. If i push boton ERR i obtain folowing log: Phone is in: Phone is not responding, power on phone! ============= Set Flash mode for info ============= VBat is 3.93V Vpp pin has 0.09V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 Boot... Invalid response from RAP3 boot( cable problem/damaged RAP3 chip/damaged phone power circuit ============= Set FBus mode for info ============= VBat is 3.94V Vpp pin has 0.09V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 May be this can give an indication to someone to help me Thanks |
01-15-2008, 12:19 | #3 (permalink) |
Member: 135019 Status: Offline Thanks Meter: 1 | Hi thanks for answer. Phone is ok (works perfectly with BB5box). With or without adapter, same result. MTbox works ok, to read ,unlock ,flash.....ī MTlite has two leds near service cable conection. This leds never light on. |
01-15-2008, 12:30 | #4 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2004 Location: MicroControllers:: Age: 43
Member: 78619 Status: Offline Thanks Meter: 297 | so something in wrong with ur light adaptor ............ check it or try to push its cable in mt box firmly ..... br khalid |
whats the different between ust pro2 lite version and ust2? | imran_bcz | UST Pro II | 1 | 08-02-2009 21:18 |
MTBOX not work anymore = No comunication with any phone at all , HELP!!! | crossings | MT-BOX | 5 | 07-15-2009 09:57 |
Difference Between Multibox And Multibox Lite | Amarbir | Multi-box LITE | 3 | 02-22-2008 01:10 |
DO Difference between MT PRo and Lite | Yashaka | MT-BOX | 9 | 09-22-2007 03:20 |
