Nokia 1209 RH-105 No Network after patch unlock! Hello, Problem with Nokia 1209 RH-105 No Network after patch unlock. 1. First I read full pm from phone 2. I downgraded to version 5.23 3. Apply patch unlock I try a simcard and the phone accepts it but no network. When you select 'simlock state' you see Default Test Operator, everything seems good. 4. I write full pm back to the phone, but again no network. Is there something else I can do? Thanks. Serkan |
flash with last setup file.tested by me |
Hallo, does unlock of 1209 work with flash unlock ? So easy ? without credit ? What is first step(1. First I read full pm from phone) needed for ? Thank's for your help `! |
no need read full pm.just unlock with another tool J-A-F. |
1209 net work broblem |
flu erase flash v.600 unlock _1000000000000000000000000000net work |
Yes full erase. flash , unlock and than write pm |
Problem Not Done Quote:
1209 no network Quote:
Problem with Nokia 1209 RH-105 No Network after patch unlock. 1. First I read full pm from phone 2. I downgraded to version 5.23 3. Apply patch unlock I try a simcard and the phone accepts it but no network. When you select 'simlock state' you see Default Test Operator, everything seems good. 4. I write full pm back to the phone, but again no network.:confused: |
