12-30-2007, 14:55 | #1 (permalink) |
Junior Member Join Date: Feb 2004 Age: 45
Member: 54417 Status: Offline Thanks Meter: 1 | Nokia N93i F-Bus Cable scheme Actually I got into trouble in flashing N93i with Fbus cable. I have tried to upgrade it with Fbus cable but phone is dead after exctracting content package with Mt-Box. what I urgently need is to know the modification of BSI line resistor. Can you please help me? (pls note that the cable i used has the resistors BSI-GND->68k and BSI line->7.5k with the above problem) Thanks for your co operation in advance. Best regards |
01-01-2008, 14:13 | #3 (permalink) |
Member: 54417 Status: Offline Thanks Meter: 1 | I did the changes (10k & Diod) and made a 10 pin cable for this. but the phone dosnt stay on local mode firmly. phone blinks on local mode and fades. i checked with 3 phones and remain the same. can you pls help me in resisiters or ...? Br, |
01-03-2008, 11:21 | #5 (permalink) |
Member: 54417 Status: Offline Thanks Meter: 1 | thnx for the comment, now mt box can read the phone info well, but flashing procedure dosnt go through (boot failure at the begining: make sure phone is connected). vpp is disabled and tx2line is selected. any comment? |
01-03-2008, 14:50 | #8 (permalink) |
Member: 54417 Status: Offline Thanks Meter: 1 | Phone is in: Test mode Model: RM-156 ( N93i-1) V 06wk15v42.2/06-08-07/RM-156 (c) Nokia. Production serial number YJA497912 Product code 0540926 Module code 0203047 Basic production code 0535732 Flash code Order number Long production SN MCU SW V 06wk15v42.2/06-08-07/RM-156/(c) Nokia. HW 6209 PCI RFIC 17211721 DSP gundamshrink_2006wk14v49 Retu 15 Tahvo 22 IMEI: 353248011796107 Using Tx2 Data line. BB5 PM back Phone is in: Test mode IMEI: 353248011796107 Backup file: C:\Program Files\GriffinTeam\MT-Box\bb5bckup\RM-156_353248011796107.pm Processing File: RM156PE300013.C0 Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. --------------------------------------------- the problem is this. |
01-03-2008, 15:06 | #9 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | ****BOX: 0004e***** - Nokia Flash/Repair v1_42_3 Box: CR V 1.001 256 Code: NK V 1.001 1048 SN: 0004e4e63d Nokia Unlimited: 1075 times started SonyEricsson Unlimited: 362 times started ============= Set Flash mode for info ============= Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Boot... Using Tx2 Data line. rap3gv3_2nd.fg RAP3Gv3_algo.fg omap2420_m1_2nd.fg teflon_sam_nand_xsr_m1.fg BOOT OK... Phone Type: BB5 ------------------- SYSTEM ID Response: 11 blocks ------------- SYSTEM_ASIC_ID( APE ): 24200704 ASIC_MODE_ID( APE ): 00 PUBLIC_ID( APE ): DAAD0044A80EB2FE6FAF115B192DD2D5AF5235B0 ROOT_KEY_HASH( APE ): BA8710A7E1CD5A2909B9A875DB27AA2400000000 SYSTEM_ASIC_ID( RAP ): 000000010000022600010006010C192101003000 EM_ASIC_ID( RAP ): 00000294 EM_ASIC_ID( RAP ): 00000B21 PUBLIC_ID( RAP ): 25000116DD8900541D01AC9CDAA8B3B0C4BB2A24 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): BAF3A9C3DBFA8454937DB77F2B8852B1 ROM_ID( RAP ): 273F6D55DFAAF68F --------------- Device ID Response: 3 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Samsung, 00EC 22E8 0000 6921 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 ============= Set FBus mode for info ============= Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-55 ( N93-1) V 05wk47v28.2/03-07-06/RM-55 (c) Nokia. IMEI: 358842000308364 this is from n93 mate i dont have a n93i for a test now. this is for public board and i dont answer to you on a PM!!!!!!!!!!!!!!!!!!!!!!!!!!! Last edited by 911GT; 01-03-2008 at 15:22. |
01-03-2008, 15:26 | #10 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: Latvia-Riga Age: 44
Member: 88823 Status: Offline Thanks Meter: 26 | Quote:
hawe you tested whit other sw ? usb mode on mtbox ? | |
01-03-2008, 16:00 | #11 (permalink) |
Member: 54417 Status: Offline Thanks Meter: 1 | yes same for usb mode on mt and phoenix. N93i has a stacked ic name as Cebbo wich is integrated by rap3gs,0map,flash ics. so its completely different from N93. can you please review me the 10 pins modification for N93i? maybe i have still some mistakes in modification. Br. |
01-03-2008, 16:08 | #12 (permalink) |
Member: 409197 Status: Offline Thanks Meter: 75 | pinouts is the same with e90. can find it here:http:///vbb/showth...=249753&page=2 |
i-Pmart BX Series RJ48 10 Pin Cable Compatible For Nokia N93i For MT Box | IPMART | ipmart WebShop | 0 | 04-14-2009 08:50 |
NOKIA 5510 (3330) Data cable scheme needed!! | medicmomcilo | Nokia Hardware & Hardware Repair | 0 | 02-25-2005 18:59 |
sgh 600 ic2 bus cable scheme! | schmusli_one | VLSI, Conexant, Skyworks and Old Models | 2 | 08-02-2003 22:55 |
reset securecode 6310 whith f-bus/m-bus cable | view | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 05-23-2003 01:38 |
