Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 04-24-2009, 10:13   #1 (permalink)
svchost's Avatar
Member: 841080
Thanks Meter: 174
Nokia 5130c rm-495 error whilw flashing , how to solve phone dead???
i try to change language of phone 5130c rm-495 flash started but show error here is the log, and after this error cannot start again flash ecery time show flash error::
\\?\nmwcd#vid_0421&pid_0106&if_oth#6&3046ff25&1&00 #{4f919102-4adf-11d5-882d-00b0d02fe381}
Sending ULO code
Sending UPDAPP code
Sending PASUBTOC code
Pooling for device removal...
Device removed
Pooling for ADL device...
\\?\nmwcd#vid_0421&pid_0105&if_oth#6&3072a693&1&00 #{4f919102-4adf-11d5-882d-00b0d02fe381}
Erase[63.63 MB]...
erasing RAP [00000000 to 000006BF]
erasing RAP [000006C0 to 0001FFFF]
erasing RAP [00040000 to 000BFFFF]
erasing RAP [000C0000 to 0013FFFF]
erasing RAP [00140000 to 0137FFFF]
erasing RAP [01380000 to 0151FFFF]
erasing RAP [01DC0000 to 0215FFFF]
erasing RAP [02160000 to 03FBFFFF]
erasing RAP [01520000 to 01DBFFFF]
in 242.02s
Flash[18.12 MB]...
%%%%%%%% ERROR SENDING FLASH:
Failed at address 00000400
The Following User Says Thank You to svchost For This Useful Post:
Old 05-02-2009, 13:27   #2 (permalink)
Member: 2800
Thanks Meter: 44
Hi i got same problem,exactly same now everytime i try to flash i get error booting.
I try with GNP cable and nothing.
Did you resolve the problem?
Old 07-12-2009, 13:52   #3 (permalink)
Member: 66863
Thanks Meter: 18
i have the same probleme
any have the solution ?
thx
The Following 2 Users Say Thank You to Atlas_marc For This Useful Post:
Old 08-05-2009, 23:10   #4 (permalink)
jmillado's Avatar
Member: 413462
Sonork: 635477
Thanks Meter: 7
5130c RM-495 flashing problem... Where's the MT-Box team support?
I flashed 5 pcs. identical models phones with no problems and 10 pcs. DEAD AFTER FLASHING. 10 pcs. all with same results. What a waste. Any help from Mt-Box guys? Thanks
MTBOX: 003f5b9068 - Nokia Flash/Repair v1.59
Box: CR V 1.002 256
Code: NK V 1.001 1049
SN: 003f5b9068
Nokia Unlimited: 633 times started
SonyEricsson Trial: 10 left, each max 15min
Scanning files, please wait...
Done
Using Tx2 Data line.
Processing File: rm495__06.65.mcusw
Boot...
FAILED TO BOOT PHONE!!!
Make sure that phone is connected.
FAILED to find USB Device.
Attach phone to usb port!
Switched to USB BUS
Boot...
CONNECT PHONE to USB and Power ON phone!
Pooling for phone...
\\?\nmwcd#vid_0421&pid_0106&if_oth#6&1a93e1d7&0&00 #{4f919102-4adf-11d5-882d-00b0d02fe381}
Sending ULO code
Sending UPDAPP code
Device removed
%%%%%%%% ERROR BOOTING:
Old 08-05-2009, 23:35   #5 (permalink)
Member: 152547
Sonork: 100.1586021
Thanks Meter: 140
if you have ub , just click on simlock repair
Old 08-06-2009, 01:25   #6 (permalink)
Super Moderator
rmarconcini's Avatar
Member: 394257
Sonork: 100.1583308 temp.disabled
Thanks Meter: 885
Mate try with good 10 pins FBUS cable.
wbr
Old 08-06-2009, 01:30   #7 (permalink)
Super Moderator
Member: 394257
Thanks Meter: 885
Box: CR V 1.002 256
SN: 003f5b9068
Done
Boot...
Switched to USB BUS
Boot...
Sending ULO code
Sending UPDAPP code
Device removed
Mate install last Nokia Connectivity cable driver and try again.
Best you try with good 10 pins FBUS cable.
wbr
Old 08-10-2009, 18:47   #8 (permalink)
Member: 591049
Thanks Meter: 3
Question Have the Same problem
I have the same problem with 5130c-2 (RM 495). A phone comes to me with white display hang problem when playing video continously for almost 20 minutes. I flash it with mt box by USB. First time , the MCU flashing is ok, but after that when phone is rebooted it shows ...ERROR BOOTING .......... After that everytime it shows pooling for ADL devices .....ERROR BOOTING. i tried with the latest version 6.93 . looking at Griffin support forum i saw that mt box has 5130 usb flash support from version 1.58 but i,ve the latest version 1.59 with latest flashing cable drivers.
***** ONE DOUBT : as for mt box 5130c-2 is rm -496 but their is no flash file for rm-496 at mt support. Another thing, in the phone, the mentioned model is 5130c-2 RM-495!!!!
Old 08-12-2009, 19:34   #9 (permalink)
Member: 591049
Thanks Meter: 3
No reply ????? moderators please Can i ask it in a new thread??? URGENT
Old 08-16-2009, 08:24   #10 (permalink)
alis's Avatar
Member: 206532
Sonork: 100.1622270
Thanks Meter: 858
Box: CR V 1.002 256
SN: 003f5b9068
Done
Boot...
Switched to USB BUS
Boot...
Sending ULO code
Sending UPDAPP code
Device removed
"""""""""if u hav hwk try on this 100% ok"""""""""""""
Old 08-16-2009, 08:30   #11 (permalink)
haji rahim's Avatar
Member: 723410
Sonork: 📱 100.1592732
Thanks Meter: 2,805
flsh with other tool ..............jaf or ufs.................
ur problem will solve
Old 08-16-2009, 20:06   #12 (permalink)
reaz.com's Avatar
Member: 310155
Thanks Meter: 1,280
@ alis
@ haji rahim
plz dont forget that's a MT-box section.
anyway !! use original MT (10 pin) cable for perfect resualt.
The Following User Says Thank You to reaz.com For This Useful Post:
Old 08-18-2009, 02:16   #13 (permalink)
Member: 543935
Thanks Meter: 58
baaaaadddd mt box
with mt box I could never flash sl2 (
killed more than 3O phone with mt
I was saved by j.a.f. but I left without IMEI
i wait solution if someone knows, please say il
mt not flashing sl2 - sl3
Old 08-31-2009, 21:30   #14 (permalink)
Member: 591049
Thanks Meter: 3
In forum.gtibox.com i found that the the flash file must have the same productcode!!!! no upgrading poss
ible ???????????
Old 09-14-2009, 00:16   #15 (permalink)
Member: 95476
Thanks Meter: 184
try with latest rm495__06.93.mcusw in usb with out content
NOkia 5130c Rm-495 Fbus piouts Need Urgent.? communication_expert Nokia Hardware & Hardware Repair 11 04-09-2011 15:26
How to unlock Nokia 5130c RM-495 ? gsm_unlock2 MT-BOX 6 02-16-2011 16:53
NOKIA 5130c rm-495 SD & SL NOT SUPPORTED DON'T TRY Shahid_Toshiba0 Griffin Products 6 03-08-2010 17:43
Nokia 5130c rm-495 contact service ramoon20 Cyclonebox 6 03-05-2010 11:58
***Here is New Nokia 5130 RM-495 v06.93 Flash Files Pack*** rajinder1978 Universalbox 1 08-06-2009 12:45
Page generated in 0.42843 seconds with 8 queries
