09-16-2009, 01:16 | #16 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: india
Member: 681945 Status: Offline Thanks Meter: 422 | brother if u dont have 10 pin cable then use universal f-bus cable i use 10 pin cables for 7210c and 5130,, i didnot get any type of problem there.. Quote:
09-24-2009, 17:03 | #17 (permalink) |
Insane Poster Join Date: Feb 2004
Member: 53369 Status: Offline Thanks Meter: 12 | I confirm it works using self made 10 pin cable like charm and it is faster than usb flashing an you will never get error like in usb flashing. You have to check "Use Tx2Line" before flashing and try to use same version that was on the phone then all wil be ok. Here log: Using Tx2 Data line. Processing File: rm495__06.65.mcusw Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00000000 - 000006BF] Erase RAP3 [000006C0 - 0001FFFF] Erase RAP3 [00040000 - 000BFFFF] Erase RAP3 [000C0000 - 0013FFFF] Erase RAP3 [00140000 - 0137FFFF] Erase RAP3 [01380000 - 0151FFFF] Erase[21.00 MB]... Waiting response for 320 Sec...in 10.02s Flash[18.14 MB]...in 165.48s * * Processed file in 190.17 seconds Processing File: rm495__06.65.image_el_red Content area page size is 128K. Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [01DC0000 - 0215FFFF] Erase RAP3 [02160000 - 03FBFFFF] Erase[34.00 MB]... Waiting response for 320 Sec...in 29.55s Flash[10.76 MB]...in 37.60s * * Processed file in 86.55 seconds Extract content...OK Processing File: rm495__06.65.ppm_el Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [01520000 - 01DBFFFF] Erase[8.63 MB]... Waiting response for 320 Sec...in 3.24s Flash[6.09 MB]...in 19.42s * * Processed file in 33.16 seconds * * * Phone flashing done in 5:44 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... V 06.65/01-04-09/RM-495 (c) Nokia IMEI: 355xxxxxxxxxxxxx Factory Default Settings...OK |
10-30-2009, 15:02 | #21 (permalink) |
Junior Member Join Date: Apr 2006
Member: 258727 Status: Offline Thanks Meter: 0 | MTBOX: 00b938e36e - Nokia Flash/Repair v1.60 Box: CR V 1.002 256 Code: NK V 1.001 1049 SN: 00b938e36e Nokia Unlimited: 44 times started SonyEricsson Unlimited: 0 times started Scanning files, please wait... Done Using Tx2 Data line. Processing File: rm495__05.80.mcusw Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00000000 - 000006BF] Erase RAP3 [000006C0 - 0001FFFF] Erase RAP3 [00040000 - 000BFFFF] Erase RAP3 [000C0000 - 0013FFFF] Erase RAP3 [00140000 - 0137FFFF] Erase RAP3 [01380000 - 0151FFFF] Erase[21.00 MB]... Waiting response for 320 Sec...in 5.05s Flash[18.10 MB]... Data Error!! Check TX2 line! %%%%%%%% ERROR SENDING FLASH: Failed at address 00000000 Using Tx2 Data line. Processing File: rm495__05.80.mcusw Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00000000 - 000006BF] Erase RAP3 [000006C0 - 0001FFFF] Erase RAP3 [00040000 - 000BFFFF] Erase RAP3 [000C0000 - 0013FFFF] Erase RAP3 [00140000 - 0137FFFF] Erase RAP3 [01380000 - 0151FFFF] Erase[21.00 MB]... Waiting response for 320 Sec...in 5.05s Flash[18.10 MB]... Data Error!! Check TX2 line! %%%%%%%% ERROR SENDING FLASH: Failed at address 00000000 Using Tx2 Data line. Processing File: rm495__05.80.mcusw Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00000000 - 000006BF] Erase RAP3 [000006C0 - 0001FFFF] Erase RAP3 [00040000 - 000BFFFF] Erase RAP3 [000C0000 - 0013FFFF] Erase RAP3 [00140000 - 0137FFFF] Erase RAP3 [01380000 - 0151FFFF] Erase[21.00 MB]... Waiting response for 320 Sec...in 5.05s Flash[18.10 MB]... Data Error!! Check TX2 line! %%%%%%%% ERROR SENDING FLASH: Failed at address 00000000 Using Tx2 Data line. Processing File: rm495__05.80.mcusw Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00000000 - 000006BF] Erase RAP3 [000006C0 - 0001FFFF] Erase RAP3 [00040000 - 000BFFFF] Erase RAP3 [000C0000 - 0013FFFF] Erase RAP3 [00140000 - 0137FFFF] Erase RAP3 [01380000 - 0151FFFF] Erase[21.00 MB]... Waiting response for 320 Sec...in 5.05s Flash[18.10 MB]... Data Error!! Check TX2 line! %%%%%%%% ERROR SENDING FLASH: Failed at address 00000000 |
02-21-2010, 22:38 | #24 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 237256 Status: Offline Thanks Meter: 91 | MXKey by Halim Ape does the flashing and unlocking. But you need to study how it is handled before use. The phone nokia 5130c has security/simlock protected areas that we should not play with. Search this forum for mxkey threads. |
02-24-2011, 04:13 | #26 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1292661 Status: Offline Thanks Meter: 4 | nokia 5130c flashing problem 1ST BOOT : C0,07 [Rm-495] [2.1.0.0] RAPx ID : 000000010000022600010006030C192101033000 EM 1 ID : 00000296 EM 2 ID : 00000B22 RAPx PBID : 138001033C87015651003B6B9C52BADC85C3DCDA RAPx MODE : 00 RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm495__07.97.mcusw 00000000: 04 00 00 00 00 B1 72 ......r ERR: CMT FLASH ERASE FLB_MSG_C2: STORE_CERT CER STO Process Failed, Repowering Mobile plz solution me |
NOkia 5130c Rm-495 Fbus piouts Need Urgent.? | communication_expert | Nokia Hardware & Hardware Repair | 11 | 04-09-2011 15:26 |
How to unlock Nokia 5130c RM-495 ? | gsm_unlock2 | MT-BOX | 6 | 02-16-2011 17:53 |
NOKIA 5130c rm-495 SD & SL NOT SUPPORTED DON'T TRY | Shahid_Toshiba0 | Griffin Products | 6 | 03-08-2010 18:43 |
Nokia 5130c rm-495 contact service | ramoon20 | Cyclonebox | 6 | 03-05-2010 12:58 |
***Here is New Nokia 5130 RM-495 v06.93 Flash Files Pack*** | rajinder1978 | Universalbox | 1 | 08-06-2009 12:45 |
