12-20-2007, 13:52 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Location: near you ...
Member: 43036 Status: Offline Sonork: 100.62160 Thanks Meter: 2,385 | Nokia 6085 RM-198 Problem I want to flash it but give this error : %%%%%%%% ERROR BOOTING: Using Tx2 Data line. Processing File: rm198b404.26.mcusw.bin Boot... rap3gv3_2nd.fg %%%%%%%% ERROR BOOTING: Using Tx2 Data line. Processing File: rm198b404.26.mcusw.bin Boot... rap3gv3_2nd.fg %%%%%%%% ERROR BOOTING: Processing File: rm198b404.26.mcusw.bin Boot... rap3gv3_2nd.fg %%%%%%%% ERROR BOOTING: VPP is DISABLED. Processing File: rm198b404.26.mcusw.bin Boot... rap3gv3_2nd.fg %%%%%%%% ERROR BOOTING: Any Solution to boot this phone ? Nokia 6085 RM-198\rm198b404.26 |
12-20-2007, 16:40 | #3 (permalink) |
Member: 43036 Status: Offline Sonork: 100.62160 Thanks Meter: 2,385 | Ok thnx for reply sir .. But what solution to revive this phone ? for more infos i flashed it by USB cable here the log : VBat is 3.93V Vpp pin has 0.09V, Not Connected Pins: Mbus 1, Box Tx 0, Box Rx 0, Bsi 0 VPP is DISABLED. Processing File: rm198b404.26.mcusw.bin Boot... CONNECT PHONE to USB and Power ON phone! Pooling for phone... \\?\nmwcd#vid_0421&pid_0106&if_oth#7&472eea3&0&00# {4f919102-4adf-11d5-882d-00b0d02fe381} Sending ULO code Sending UPDAPP code Sending PASUBTOC code Pooling for device removal... Device removed Pooling for ADL device... \\?\nmwcd#vid_0421&pid_0105&if_oth#6&6478c60&0&00# {4f919102-4adf-11d5-882d-00b0d02fe381} Erase[31.69 MB]... erasing RAP [00000000 to 000DFFFF] erasing RAP [00100000 to 0110FFFF] erasing RAP [015E0000 to 01FDFFFF] erasing RAP [01120000 to 015DFFFF] in 115.96s Flash[14.42 MB]...in 67.79s * * Processed file in 205.45 seconds Processing File: rm198b404.26.image_vg_es Boot... Pooling for ADL device... \\?\nmwcd#vid_0421&pid_0105&if_oth#6&6478c60&0&00# {4f919102-4adf-11d5-882d-00b0d02fe381} Erase[0.00 MB]... in 0.09s Flash[4.13 MB]...Content page size is 128K in 19.04s * * Processed file in 19.30 seconds Processing File: rm198b404.26.ppm_a Boot... Pooling for ADL device... \\?\nmwcd#vid_0421&pid_0105&if_oth#6&6478c60&0&00# {4f919102-4adf-11d5-882d-00b0d02fe381} Erase[0.00 MB]... in 0.08s Flash[3.28 MB]...in 15.21s * * Processed file in 15.46 seconds Restarting device... Pooling for device removal... Device disconnected. * * * Phone flashing done in 4:34 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! BR.douhal Last edited by DOUHAL; 12-20-2007 at 16:45. |
12-20-2007, 17:58 | #6 (permalink) |
Member: 43036 Status: Offline Sonork: 100.62160 Thanks Meter: 2,385 | I think Problem on Software Stanalone . Please OPEN Server & let use Unlock the phone !!! Example here I got Nokia 6131 Version6.10 SUPPORTED and Easy BUT .. F 06.10/16-02-07/RM-115/(c) Nokia. Auto backup SIMLOCK... ================================= bb5bckup\354566016448260.pm 134 : 0 0x1 bytes 134 : 1 0x2000 bytes 134 : 3 0x1 bytes 134 : 4 0x1 bytes 134 : 5 0xA bytes 134 : 6 0x1 bytes 134 : 7 0x1 bytes 134 : 8 0x1 bytes 134 : 9 0x28 bytes ================================= Using fixed version support !!! V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 TPs OK TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED FAILED, ALL ATTEMPTS USED! Sending SIMLOCK record... Restarting phone Finished Restarting phone V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 TPs OK TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED FAILED, ALL ATTEMPTS USED! Sending SIMLOCK record... Restarting phone Finished Restarting phone V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 TPs OK TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED FAILED, ALL ATTEMPTS USED! Restarting phone Finished Restarting phone V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 XV 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 TPs OK FAILED, ALL ATTEMPTS USED! Sending SIMLOCK record... Restarting phone Finished Restarting phone V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 354566016448260 TPs OK TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED FAILED, ALL ATTEMPTS USED! Restarting phone Finished Restarting phone No communication with phone. Delaying 5 sec No communication with phone. Delaying 5 sec Then also the first phone on Post#1 Killed by Software !!!!!!!!! |
12-21-2007, 09:54 | #7 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | No Problem Is Not In Standalone. When We Reliese Standalone Solution Just Move Data From Our Server To Your Machine ,nothing More Mate.now We Will See How Of You Have A Problem S With Their Pc's He He |
nokia 6085 rm 198 v6.01 | nepoleanl | Nokia Base Band 5 ( BB-5 ) | 0 | 12-29-2009 07:40 |
nokia 6085 rm-198 | iliralla | Nokia Hardware & Hardware Repair | 0 | 04-01-2009 21:32 |
nokia 6085 rm-198 phone restred & imi 123459855? | Wasim007 | Nokia Base Band 5 ( BB-5 ) | 3 | 08-31-2008 10:18 |
nokia 6085 rm-198? | lezwire | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 06-08-2007 15:27 |
nokia 6085 rm-198 | ayyoub225 | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 05-21-2007 07:52 |
