02-07-2007, 09:28 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: www.sw-box.com Age: 19
Member: 152573 Status: Offline Thanks Meter: 58 | nokia 6233 Phone Restricted BB5Erase_16MBrap.bin BB5Erase_EE_8MBrap.bin BB5Erase_EE_16MBrap.bin phone imei become 1234567890 , after that creat bb5 ask and get bb5 rpl. After write bb5 rpl to phone, now phone is ok but no network. when i use manual network search it show 3 operator. i didnt backup any pm.. how to use sx4 auth?? Code: To restore PM of phone, after eeprom is eerased: 1.Connect phone. 2.Make sure it has serial communication ( recommend to see it responds to phone info in local mode). 3.Load the PM file ( load file, in Eeprom controls page). 4.Mark Section( resource) 308 (0x134) and press Write Selected. 5.Restart phone. Either disconnect and reconnect phone to MT, or change mode to Test. 6.Press SX4 button, and wait for it to display that authorization was successful. 7.Press Write All button. P.s : i didnt backup any pm b4 erase .. Hope can get reply soon .. thanks Best Regards alex |
02-07-2007, 11:08 | #2 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | oooo dont write 308(134)field he is in rpl!!!!!! skip section 4 "4.Mark Section( resource) 308 (0x134) and press Write Selected." you need to write only 1,135 fields from another phone if you dont have it about sx authorization enter username and pass in mt-box then click on sx4 buton and then write 1,135field. READ THE MANUAL FIRST BEFORE QUEST!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1 |
02-07-2007, 11:46 | #3 (permalink) | |
Member: 152573 Status: Offline Thanks Meter: 58 | Quote:
thanks for reply, will try and post the result With Best Regards alex | |
02-08-2007, 03:31 | #4 (permalink) |
Member: 152573 Status: Offline Thanks Meter: 58 | hi still cant use sx4 auth.. Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 359727005XXXXXX busy, waiting... Connect... Login... busy, waiting... PMM Authorize FAILED |
02-08-2007, 04:05 | #5 (permalink) |
No Life Poster Join Date: Feb 2003 Location: HUR / R.S Age: 39
Member: 21750 Status: Offline Sonork: 100.62509 Thanks Meter: 73 | same proplemw ith n70 i can't use sx4 always busy, waiting... Connect... Login... busy, waiting... PMM Authorize FAILED and when i use it many times as manual said i get busy, waiting... e/311/Authorization limit exceeded in current period; plz little clear about authorize ppm useing sx4 if always failed this means server proplem ?> i am sure my cable 10000% connect well and phone can move from normal mode to local mode to test mode plz little clear |
02-08-2007, 08:03 | #6 (permalink) |
No Life Poster Join Date: Sep 2004
Member: 82423 Status: Offline Thanks Meter: 1,203 | read this thread about server problem http:///vbb/showthread.php?t=373733 |
02-08-2007, 14:19 | #7 (permalink) |
Member: 21750 Status: Offline Sonork: 100.62509 Thanks Meter: 73 | this was 6/2/2007 we r in 8/2/2007 still same just test again now Connect... Login... IMEI: 357xxxxxxxxxxxxxx busy, waiting... Connect... Login... busy, waiting... PMM Authorize FAILED |
nokia 6233 phone restriction code | kachman | UFS2 + UFS3-Tornadoflasher | 4 | 09-15-2008 16:45 |
NOKIA 6233 phone restricted. | gnigga4you | Nokia Hardware & Hardware Repair | 5 | 01-30-2008 03:53 |
6233 phone restricted | riznix | Phone Unlocking Codes & Maps | 4 | 01-20-2007 07:37 |
