01-20-2007, 21:29 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: London, UK
Member: 178513 Status: Offline Thanks Meter: 109 | Nokia 6280 Locked after flash PLS Help!!! i have 2 pcs nokia 6280, 1 pcs is flashed from someone after flash IMEI is: 12345610654321? i need to repair it, i have another one wich i flash, was unlocked before after flash i get it lock, maybe 308 is not saved as back up? i am use MT-Box, and pls if have any solution pls support. WBR; Albelektronik TEAM |
01-21-2007, 14:38 | #3 (permalink) |
Member: 178513 Status: Offline Thanks Meter: 109 | Hi Friend, here are all logs and procedure as descript in sticky topic: Check: Phone is in: Local mode Model: RM-78 ( RM-78) V 05.92/07-09-06/RM-78 (c) Nokia Production serial number SDF712497 Product code 0520042 Module code Basic production code 0520041 Flash code Order number Long production SN MCU SW V 05.92/07-09-06/RM-78/(c) Nokia HW 1002 PCI RFIC 17191719 DSP pb05w46v31 LCD SHARP PPM V 05.92/07-09-06/RM-78/(c) Nokia/C Retu 32 Tahvo 52 Content Pack Content: c/V 05.92/07-09-06/RM-78/(c) Nokia IMEI: 357603005933841 V 05.92/07-09-06/RM-78 (c) Nokia IMEI: 357603005933841 Operator: 8000000000000006 Profile bits: 2342000000000000 Closed on Mcc Mnc: 23420F ============= Set Flash mode for info ============= VBat is 4.02V Vpp pin has 1.36V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg BOOT OK... Phone Type: BB5 ------------------- SYSTEM ID Response: 7 blocks ------------- SYSTEM_ASIC_ID( RAP ): 000000010000022600010006010C192101003000 EM_ASIC_ID( RAP ): 00000232 EM_ASIC_ID( RAP ): 00000352 PUBLIC_ID( RAP ): 1F70010F8C7C00547BA844561D21E15C5C7C3A23 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): BAF3A9C3DBFA8454937DB77F2B8852B1 ROM_ID( RAP ): 273F6D55DFAAF68F --------------- Device ID Response: 2 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Amd, 0001 002F 0000 0121 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 ============= Set FBus mode for info ============= VBat is 4.00V Vpp pin has 1.36V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-78 ( RM-78) V 05.92/07-09-06/RM-78 (c) Nokia IMEI: 357603005933841 Phone Info: Phone is in: Local mode Model: RM-78 ( RM-78) V 05.92/07-09-06/RM-78 (c) Nokia Production serial number SDF712497 Product code 0520042 Module code Basic production code 0520041 Flash code Order number Long production SN MCU SW V 05.92/07-09-06/RM-78/(c) Nokia HW 1002 PCI RFIC 17191719 DSP pb05w46v31 LCD SHARP PPM V 05.92/07-09-06/RM-78/(c) Nokia/C Retu 32 Tahvo 52 Content Pack Content: c/V 05.92/07-09-06/RM-78/(c) Nokia IMEI: 357603005933841 Read Ask Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg BOOT OK... -------------------------------------- Ask created successfully. Write RPL: IMEI: 357603005933841 Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg BOOT OK... Phone Type: BB5 ------------------- SYSTEM ID Response: 7 blocks ------------- SYSTEM_ASIC_ID( RAP ): 000000010000022600010006010C192101003000 EM_ASIC_ID( RAP ): 00000232 EM_ASIC_ID( RAP ): 00000352 PUBLIC_ID( RAP ): 1F70010F8C7C00547BA844561D21E15C5C7C3A23 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): BAF3A9C3DBFA8454937DB77F2B8852B1 ROM_ID( RAP ): 273F6D55DFAAF68F --------------- Device ID Response: 2 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Amd, 0001 002F 0000 0121 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 ----------------- RPL Restore Certificate Status -------------------- RPL RAP3 Certificate sent SUCCESSFULLY Delay for 20 seconds... ============= Set FBus mode for info ============= VBat is 4.01V Vpp pin has 1.36V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-78 ( RM-78) V 05.92/07-09-06/RM-78 (c) Nokia IMEI: 357603005933841 Simlock send - SUCCESSFULL!!! SuperDongle send - SUCCESSFULL!!! Phone Info: Phone is in: Local mode Model: RM-78 ( RM-78) V 05.92/07-09-06/RM-78 (c) Nokia Production serial number SDF712497 Product code 0520042 Module code Basic production code 0520041 Flash code Order number Long production SN MCU SW V 05.92/07-09-06/RM-78/(c) Nokia HW 1002 PCI RFIC 17191719 DSP pb05w46v31 LCD SHARP PPM V 05.92/07-09-06/RM-78/(c) Nokia/C Retu 32 Tahvo 52 Content Pack Content: c/V 05.92/07-09-06/RM-78/(c) Nokia IMEI: 357603005933841 Lock Status: V 05.92/07-09-06/RM-78 (c) Nokia IMEI: 357603005933841 Operator: 8000000000000006 Profile bits: 2342000000000000 Closed on Mcc Mnc: 23420F Phone still lock after write rpl, no lock back, phone was unlock before flash. Same with other phone wich have imei demaged, repair IMEI but not same as was writeback after write rpl imei was diffrend and phone still lock,. i lost 60 credit and not done one phone. |
01-21-2007, 15:00 | #5 (permalink) | |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Quote:
If in sim lock status the phone is locked, then will be locked after write RPL. If in sim lock status the phone is unlocked then will be unlocked after write RPL. Using BB5 ASK to RPL service you can't unlock the BB5 phones. | |
01-21-2007, 15:04 | #7 (permalink) |
Member: 178513 Status: Offline Thanks Meter: 109 | Hi Friend! Yes i am clear for procedure, i know in this mode i can't unlock BB5 Phone, but i can repair imei or get simlock back as before, because i told You, phone before flash was unlock... Pls give me solution! WBR; AT |
6280 Lock After Flash | denard | HWK | 6 | 09-21-2007 23:11 |
6280 Lock After Flash | DEHGHAN | MT-BOX | 2 | 08-20-2007 07:16 |
6280 Lock After Flash | denard | Nokia Base Band 5 ( BB-5 ) | 0 | 08-19-2007 08:59 |
Nokia 7650 dead after flash pls help??? | proxy_gsm | WD2 & APE (Symbian Phones) | 7 | 11-10-2004 10:11 |
