08-07-2008, 20:14 | #1 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Spain Age: 48
Member: 83104 Status: Offline Thanks Meter: 12 | Nokia E71 Flash Death HEEEELP!!! VPP is DISABLED. BB5 PM back Phone is in: Phone is not responding! Processing File: rm346_100.07.76_prd.c00 Boot... CONNECT PHONE to USB and Power ON phone! Pooling for phone... \\?\nmwcd#vid_0421&pid_0106&if_oth#6&14bcca51&1&00 #{4f919102-4adf-11d5-882d-00b0d02fe381} Sending ULO code Isa UPDAPP UPDAPP PASUBTOC Pooling for device removal... Device removed Pooling for ADL device... \\?\nmwcd#vid_0421&pid_0105&if_oth#6&1353fbe9&1&00 #{4f919102-4adf-11d5-882d-00b0d02fe381} Erase[155.88 MB]... erasing APE [00040000 to 007FFFFF] erasing APE [00A00000 to 0759FFFF] erasing APE [0F1C0000 to 0F8BFFFF] ERROR [0000010030430F81] IGNORE AND Continue!!! erasing APE [05420000 to 0759FFFF] in 22.77s Flash[59.83 MB]...in 82.81s * * Processed file in 146.39 seconds Processing File: rm346_100.07.76.02U Boot... Pooling for ADL device... \\?\nmwcd#vid_0421&pid_0105&if_oth#6&1353fbe9&1&00 #{4f919102-4adf-11d5-882d-00b0d02fe381} Erase[0.00 MB]... in 0.11s Flash[5.88 MB]... %%%%%%%% ERROR SENDING FLASH: Failed at address 00000000 phone dead no power on... help please my client i need for monday 11 please help... |
09-18-2008, 18:08 | #7 (permalink) |
Member: 83104 Status: Offline Thanks Meter: 12 | MTBOX: 00074fcfbf - Nokia Flash/Repair v1.52 Box: CR V 1.001 256 Code: NK V 1.001 1048 SN: 00074fcfbf Nokia Unlimited: 5583 times started SonyEricsson Unlimited: 96 times started Scanning files, please wait... Done Selected Highest installed version: 100.07.76 VPP is DISABLED. Using Tx2 Data line. Processing File: rm346_100.07.76_prd.c00 Boot... RAPIDOv11_2nd.fg RAPIDOv11_algo.fg Erase RAP3 [00040000 - 007FFFFF] Erase RAP3 [00A00000 - 0759FFFF] Erase RAP3 [0F1C0000 - 0F8BFFFF] Erase[122.38 MB]... Waiting response for 320 Sec...in 2.13s Flash[58.02 MB]...in 101.05s * * Processed file in 111.77 seconds Processing File: rm346_100.07.76.02U Boot... RAPIDOv11_2nd.fg RAPIDOv11_algo.fg Erase[0.00 MB]... Waiting response for 320 Sec...in 0.31s Flash[5.88 MB]...in 10.52s * * Processed file in 23.14 seconds No need to extract content. Processing File: rm346_100.07.76_prd.v05 Boot... RAPIDOv11_2nd.fg RAPIDOv11_algo.fg Erase RAP3 [05420000 - 0759FFFF] Erase[33.50 MB]... Waiting response for 320 Sec...in 0.84s Flash[24.06 MB]... Data Error!! Check TX2 line! %%%%%%%% ERROR SENDING FLASH: Failed at address 00000000 i have flashed with the cable described RJ48 MTBOX 10 PINS, y have buy in UNLOCKEXTREMADURA and ERROR FLASHING i have tested 10 |
09-20-2008, 08:08 | #8 (permalink) |
No Life Poster Join Date: Feb 2001 Location: ITALY Age: 51
Member: 3381 Status: Offline Thanks Meter: 1,171 | Mtbox have a lot of bug also using cable 10pin, open it and ceck resistor inside and change value also try to put ACP-12 into Mtbox this stabilize comunication, also ceck connector female 10 pin inside box that is ok (all pins up and not down). At the end if not work use another box. |
09-20-2008, 14:34 | #9 (permalink) |
Member: 83104 Status: Offline Thanks Meter: 12 | i have buy the cable new, if open lost the warantee, any other sugestion? fits perfectly, and fastened thing with the hands (sorry for my english), acp-12 ORIGINAL NOKIA is in the box, and have clean the 10 pin female of the box.... andy idea? |
04-27-2009, 03:34 | #10 (permalink) |
Junior Member Join Date: Jun 2007
Member: 532831 Status: Offline Thanks Meter: 0 | i have e71-2 Rm-357 i am having a problem that is i am not able to flash a E71 phone, bcz when i tried to flash the phone with fbus cable tx line automatically dissabled, even i tried to flash it with USB Cable it says cmt 17 error. pls help me my friend |
12-25-2010, 11:01 | #11 (permalink) |
No Life Poster Join Date: Nov 2008 Location: pakistan
Member: 898041 Status: Offline Sonork: 100.1593459 Thanks Meter: 549 | in automatic action while flashing select only 4 option 1.disable vvp. 2. use txt2line 3.slow erase bb5 4. default setting after flash. and use must 10 pin cable rj45, your problem solve. bro |
The Following User Says Thank You to shamshad quresh For This Useful Post: |
lost credits and death Nokia E71 | kaper1 | Universalbox | 17 | 04-24-2009 14:15 |
