Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 12-30-2007, 14:55   #1 (permalink)
Member: 54417
Nokia N93i F-Bus Cable scheme
Dear Sir,
Actually I got into trouble in flashing
N93i with Fbus cable. I have tried to upgrade it with
Fbus cable but phone is dead after exctracting content package
with Mt-Box. what I urgently need is to know the modification
of BSI line resistor. Can you please help me?
(pls note that the cable i used has the resistors BSI-GND->68k
and BSI line->7.5k with the above problem)
Thanks for your co operation in advance.
Best regards
Old 12-31-2007, 15:17   #2 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
make cable like for a N95 with resistor and diod and he need to work fine.
!st you can try to put 10k resistor
Old 01-01-2008, 14:13   #3 (permalink)
Member: 54417
I did the changes (10k & Diod) and made a 10 pin cable for this.
but the phone dosnt stay on local mode firmly. phone blinks on
local mode and fades. i checked with 3 phones and remain the same.
can you pls help me in resisiters or ...?
Br,
Old 01-02-2008, 11:36   #4 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
connect nokia charger to mt-box .phone need more power!!
Old 01-03-2008, 11:21   #5 (permalink)
Member: 54417
thnx for the comment, now mt box can read the phone info well, but flashing
procedure dosnt go through (boot failure at the begining: make sure phone is connected).
vpp is disabled and tx2line is selected.
any comment?
Old 01-03-2008, 14:13   #6 (permalink)
Member: 54417
Hello 911Gt
Any idea?
Old 01-03-2008, 14:14   #7 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
yes , connect vpp correct and uncheck DisableVPP
Old 01-03-2008, 14:50   #8 (permalink)
Member: 54417
Phone is in: Test mode
Model: RM-156 ( N93i-1)
V 06wk15v42.2/06-08-07/RM-156 (c) Nokia.
Production serial number YJA497912
Product code 0540926
Module code 0203047
Basic production code 0535732
Flash code
Order number
Long production SN
MCU SW V 06wk15v42.2/06-08-07/RM-156/(c) Nokia.
HW 6209
PCI
RFIC 17211721
DSP gundamshrink_2006wk14v49
Retu 15
Tahvo 22
IMEI: 353248011796107
Using Tx2 Data line.
BB5 PM back Phone is in: Test mode
Backup file: C:\Program Files\GriffinTeam\MT-Box\bb5bckup\RM-156_353248011796107.pm
Processing File: RM156PE300013.C0
Boot...
FAILED TO BOOT PHONE!!!
Make sure that phone is connected.
the problem is this.
Old 01-03-2008, 15:06   #9 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
****BOX: 0004e***** - Nokia Flash/Repair v1_42_3
Box: CR V 1.001 256
Code: NK V 1.001 1048
SN: 0004e4e63d
Nokia Unlimited: 1075 times started
SonyEricsson Unlimited: 362 times started
============= Set Flash mode for info =============
Pins:
Mbus 1, Box Tx 1, Box Rx 1, Bsi 0
Boot...
rap3gv3_2nd.fg
RAP3Gv3_algo.fg
omap2420_m1_2nd.fg
teflon_sam_nand_xsr_m1.fg
BOOT OK...
Phone Type: BB5
------------------- SYSTEM ID Response: 11 blocks -------------
SYSTEM_ASIC_ID( APE ):
24200704
ASIC_MODE_ID( APE ):
00
PUBLIC_ID( APE ):
DAAD0044A80EB2FE6FAF115B192DD2D5AF5235B0
ROOT_KEY_HASH( APE ):
BA8710A7E1CD5A2909B9A875DB27AA2400000000
SYSTEM_ASIC_ID( RAP ):
000000010000022600010006010C192101003000
EM_ASIC_ID( RAP ):
00000294
EM_ASIC_ID( RAP ):
00000B21
PUBLIC_ID( RAP ):
25000116DD8900541D01AC9CDAA8B3B0C4BB2A24
ASIC_MODE_ID( RAP ):
00
ROOT_KEY_HASH( RAP ):
BAF3A9C3DBFA8454937DB77F2B8852B1
ROM_ID( RAP ):
273F6D55DFAAF68F
--------------- Device ID Response: 3 blocks -------------
Storage Device:
Owner Asic: RAP
Type: NOR Flash
Index: 0
Flash: Samsung, 00EC 22E8 0000 6921
Storage Device Contents:
Owner Asic: RAP
000000000000000000000000000000000000
============= Set FBus mode for info =============
Pins:
Phone is in: Local mode
Model: RM-55 ( N93-1)
V 05wk47v28.2/03-07-06/RM-55 (c) Nokia.
IMEI: 358842000308364
this is from n93 mate i dont have a n93i for a test now.
this is for public board and i dont answer to you on a PM!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 01-03-2008, 15:26   #10 (permalink)
RRRRR's Avatar
Member: 88823
Thanks Meter: 26
Module code 0203047
Flash code
Order number
Long production SN
HW 6209
PCI
RFIC 17211721
Retu 15
Tahvo 22
Boot...
hawe you tested whit other sw ? usb mode on mtbox ?
Old 01-03-2008, 16:00   #11 (permalink)
Member: 54417
yes same for usb mode on mt and phoenix.
N93i has a stacked ic name as Cebbo wich is integrated by
rap3gs,0map,flash ics. so its completely different from N93.
can you please review me the 10 pins modification for N93i?
maybe i have still some mistakes in modification.
Br.
Old 01-03-2008, 16:08   #12 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
pinouts is the same with e90. can find it here:http:///vbb/showth...=249753&page=2
Old 01-03-2008, 16:34   #13 (permalink)
Member: 54417
hi mate, the resistors for e90 are 68K gnd-bsi & 7.5k bsi line but i used 10k for bis-gnd and diod for bsi line.
which one is the correct one?
Old 01-04-2008, 09:20   #14 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
yes with resistor and diode need to work more stable! check for correct polarity of diode!
Old 01-05-2008, 13:40   #15 (permalink)
Member: 54417
No success, problem persisits
Mt can read the phone info in local mode but says" make sure phone is connected" while flashing.
i-Pmart BX Series RJ48 10 Pin Cable Compatible For Nokia N93i For MT Box IPMART ipmart WebShop 0 04-14-2009 08:50
NOKIA 5510 (3330) Data cable scheme needed!! medicmomcilo Nokia Hardware & Hardware Repair 0 02-25-2005 18:59
sgh 600 ic2 bus cable scheme! schmusli_one VLSI, Conexant, Skyworks and Old Models 2 08-02-2003 22:55
reset securecode 6310 whith f-bus/m-bus cable view Nokia Digital Core Technology 4 ( DCT-4 ) 0 05-23-2003 01:38
Page generated in 0.21258 seconds with 9 queries
