01-11-2007, 17:45 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Aqua Project Age: 47
Member: 115242 Status: Offline Sonork: 100.1581364 Thanks Meter: 1,638 | One more killed by MT Box pleas Griffin team Tell me the Solution after flashing phone can't on Low level format...fail Extract content...fail Complete massage is VPP is DISABLED. Processing File: rh19__06.310 Boot... ASIC ID: 1130 DCT4 u_2nd.fia u_st_i.fia 8412FB77C1BB66AAC4572E3502EB Configuration Info (9F): Number of Flashes: 2 01000000: SGS, 0020 88C0 0000 0121, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[8.00 MB]... erasing region [01000000 to 0100FFFF] erasing region [01010000 to 0154FFFF] erasing region [01680000 to 017EFFFF] erasing region [01EB0000 to 01FEFFFF] in 56.58s Flash[5.26 MB]...in 27.24s * * Processed file in 91.68 seconds Processing File: rh19__06.31.ucp_xa1 Low level format...fail Boot... ASIC ID: 1130 DCT4 u_2nd.fia u_st_i.fia 84DC7BF54E42FB87A2391E799B10 Configuration Info (9F): Number of Flashes: 2 01000000: SGS, 0020 88C0 0000 0121, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[1.19 MB]... erasing region [01550000 to 0167FFFF] in 9.45s Flash[0.44 MB]...in 2.11s * * Processed file in 50.04 seconds Extract content...fail Processing File: rh19__06.31a Boot... ASIC ID: 1130 DCT4 u_2nd.fia u_st_i.fia 84DC7BF54E42FB87A2391E799B10 Configuration Info (9F): Number of Flashes: 2 01000000: SGS, 0020 88C0 0000 0121, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[1.19 MB]... erasing region [01550000 to 0167FFFF] in 9.51s Flash[0.91 MB]...in 4.28s * * Processed file in 21.66 seconds * * * Phone flashing done in 3:46 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! |
01-11-2007, 17:50 | #2 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | what was original fault in the phone? i think u had bluetooth failure. Your phone failed to extract content pack UCP. try to reflow BT module first, also user RAM area. i think u have not used another device before this one. do not blame ur tools man ) |
01-11-2007, 18:17 | #3 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | This phone dont have a bluetooth! check cable! you dont have a test mode for extract content and local mode too. may be center pin of batery conector dont contact to cable. say for result |
01-11-2007, 18:32 | #5 (permalink) |
Member: 115242 Status: Offline Sonork: 100.1581364 Thanks Meter: 1,638 | the original fault was Restart phone some time I think u don’t understand my problem man I have problem in non bt models |
01-11-2007, 18:39 | #6 (permalink) |
Junior Member Join Date: Jan 2004 Age: 43
Member: 50776 Status: Offline Thanks Meter: 1 | I am understand you, but if you upgrade version on not supported for that phone he can give you local mode after flash MCU, and then he can extract content. For that is important, you canot upgrade v4.01 to 6.31 |
01-11-2007, 19:03 | #10 (permalink) |
Member: 115242 Status: Offline Sonork: 100.1581364 Thanks Meter: 1,638 | Sorry Mr. emird my problem can’t understand mr. Dave.W And Mr. 911GT i have same problem in 1110 i am flashing phone by easy cable but not success and what u saying in this situation |
01-11-2007, 19:08 | #11 (permalink) |
Major Poster Join Date: Jun 2004
Member: 70978 Status: Offline Thanks Meter: 0 | you try flash nokia rh50 in nokia rh-19? very high version,try 4.01 or 6.01 during software scan the local mode press and let go the button Power On. or phone have hardware problem |
01-11-2007, 19:48 | #14 (permalink) |
No Life Poster Join Date: May 2006 Location: U wont beleive Age: 43
Member: 275631 Status: Offline Thanks Meter: 408 | as far ur problem is consern....its a hardware problem.... all u have to do waz... reball cpu n flash... all would have bin fine.... next time try it...... n better use ufs for dct4 ... |
Nokia N79 RM-348 killed by mt box 2.11!! | svchost | MT-BOX | 3 | 03-14-2010 23:41 |
how to fix 7100s killed by mt-box on unlock | pol98 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-14-2010 13:56 |
Multi Box Nokia Tool Is More Strong Than Mt Box Or Jaf | sairat | Multi-box LITE | 0 | 01-20-2008 17:44 |
w300 killed by MT Box | masterross | MT-BOX | 1 | 11-13-2006 19:40 |
