Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 01-12-2006, 04:39   #1 (permalink)
Member: 105625
Thanks Meter: 44
Nokia 6111 supported?
Flashing 6111 works, but everything else fails, including reading info, or setting factory defaults. Is this model fully supported?
Old 01-12-2006, 07:57   #2 (permalink)
garick's Avatar
Member: 27078
I have flashed 3 phones without any troubles.
Which version do you use - 3.15 or older?
Old 01-12-2006, 12:49   #3 (permalink)
tostefo's Avatar
Member: 77941
Thanks Meter: 120
yes works OK.......100% supported.........check cable
Old 01-12-2006, 19:01   #4 (permalink)
Member: 105625
Thanks Meter: 44
If you mean MT-software it's 1.15. Phone firmware is 3.40. But as mentioned, flashing works fine - but all other operations failes. Did you try anything else than flashing?
Old 01-12-2006, 19:26   #5 (permalink)
MicrostarGSM®'s Avatar
Member: 18855
Thanks Meter: 1,938
what u mean by all operator fails ?
u mean it not getting network ?
Old 01-13-2006, 03:03   #6 (permalink)
Member: 105625
Thanks Meter: 44
operations, not operators
Meaning, everything else than flashing does not work.. Like Read phone, Unlock, Set factory defaults, etc. Gives the error "Phone is in: Phone is not responding, power on phone!".
Old 01-13-2006, 10:06   #7 (permalink)
Member: 18855
Thanks Meter: 1,938
1st can you phone power on ?
if yes then power on yur phone or the phone in test or local mode then click phone info
Old 01-14-2006, 04:52   #8 (permalink)
Member: 105625
Thanks Meter: 44
Yes, the phone is working, and i can power it on, but it only starts in normal mode, not local/test mode.
Old 01-14-2006, 13:34   #9 (permalink)
Member: 18855
Thanks Meter: 1,938
ok then what u do is
1.power on the phone
2.press phoneinfo
3.select the automatic action which flashing
4.then start flashing and post the log here
Old 01-14-2006, 13:47   #10 (permalink)
Member: 18423
Thanks Meter: 26
cable problem!
Old 01-16-2006, 04:10   #11 (permalink)
Member: 29907
what cable for this type ?
anyone to know , what cable same for this type ? or i must new buy
Old 01-16-2006, 09:18   #12 (permalink)
Member: 18855
Thanks Meter: 1,938
6111 is a diffrent cable which u can buy from your reseller
Old 01-22-2006, 18:54   #13 (permalink)
Member: 105625
Thanks Meter: 44
2.press phoneinfo
As mentioned - FLASHING WORKS!
It's other features like reading phone info/unlocking that does not working...
Can the cable be faulty, if flashing works fine?
New Products: Nokia 6111 Service Cables For Various Service Tools Tele-way Main Sales Section 0 11-23-2005 17:28
Page generated in 0.23335 seconds with 9 queries
