10-16-2007, 03:06 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 43
Member: 171470 Status: Offline Thanks Meter: 6 | pls help n95 unlock failed but failed now phone is start-up failed Phone is in: Local mode Model: RM-159 (Aalto (EU) ) V 06wk41v23.4/17-04-07/RM-159 (c) Nokia Production serial number MAI039175 Product code 0548986 Module code Basic production code 0530865 Flash code Order number Long production SN 0 MCU SW V 06wk41v23.4/17-04-07/RM-159/(c) Nokia HW 5900 PCI RFIC 17141714 DSP dsprap_pb06w41v24 APE SW Core 11.0.026 APE Variant 11.0.02611 APE Test rm159_ENO_x_2007wk02v0.070 Retu 15 Tahvo 22 APE HW 1 APE ADSP SW 256 APE BT HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. IMEI: 352255019351596 V 06wk41v23.4/17-04-07/RM-159 (c) Nokia IMEI: 352255019351596 Operator: 0000000000000000 Profile bits: 2343300000000000 Closed on GID1: 23433F Closed on GID1: 23486F Closed on Mcc Mnc: 23433F Closed on Mcc Mnc: 23486F Counters 0/10, 0/3 pls help me ! start-up failed start-up failed start-up failed start-up failed start-up failed start-up failed And I clean air, into the backup is like this |
10-16-2007, 05:06 | #4 (permalink) |
Member: 171470 Status: Offline Thanks Meter: 6 | CONNECT TPs V 06wk41v23.4/17-04-07/RM-159 (c) Nokia IMEI: 352255019351596 V 06wk41v23.4/17-04-07/RM-159 (c) Nokia IMEI: 352255019351596 V 06wk41v23.4/17-04-07/RM-159 (c) Nokia IMEI: 352255019351596 TPs OK UNLOCK SUCCESSFULL SUCCESSFULL V 06wk41v23.4/17-04-07/RM-159 (c) Nokia IMEI: 352255019351596 Operator: 0000000000000000 Profile bits: 2343300000000000 Open on GID1: 23433F Open on GID1: 23486F Open on Mcc Mnc: 23433F Open on Mcc Mnc: 23486F Sim Status: Not locked V 06wk41v23.4/17-04-07/RM-159 (c) Nokia IMEI: 352255019351596 Operator: 0000000000000000 Profile bits: 2343300000000000 Open on GID1: 23433F Open on GID1: 23486F Open on Mcc Mnc: 23433F Open on Mcc Mnc: 23486F Sim Status: Not locked but also phone start-up failed contact the ratailer |
10-16-2007, 10:01 | #6 (permalink) | |
Member: 171470 Status: Offline Thanks Meter: 6 | Quote:
i try to write full pm(removed 134) but phone also start-up failed I wipe the handset space, write back r3c of documents, telephone started failure, write pm is the same | |
10-16-2007, 10:27 | #7 (permalink) |
Member: 171470 Status: Offline Thanks Meter: 6 | Processing File: RM-159_12.0.014_PR.C0R Boot... CONNECT PHONE to USB and Power ON phone! Pooling for phone... FAILED TO BOOT PHONE!!! Make sure that phone is connected. Using Tx2 Data line. Processing File: RM-159_12.0.014_PR.C0R Boot... CONNECT PHONE to USB and Power ON phone! Pooling for phone... FAILED TO BOOT PHONE!!! Make sure that phone is connected. Switched to service cable FBUS Using Tx2 Data line. Processing File: RM-159_12.0.014_PR.C0R Boot... RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg OMAP2420 UNISTORE-II-1.5.1 ALG teflon_sam_nand_xsr151_m1.fg Erase RAP3 [00080000 - 007AA0C5] Erase RAP3 [00000000 - 0005FFFF] Erase RAP3 [00880000 - 00FDFFFF] Erase APE [00000200 - 0000AFFF] Erase APE [0000B800 - 000AFFFF] Erase APE [00000000 - 00001000] Erase APE [0000D800 - 0000EA00] Erase APE [00080000 - 000BFFFF] Erase APE [000E0000 - 0045FFFF] Erase APE [004C0000 - 0073FFFF] Erase APE [00A40000 - 0633FFFF] Erase[110.86 MB]... Waiting response for 320 Sec...in 3.50s Flash[60.33 MB]...in 134.25s * * Processed file in 148.92 seconds Processing File: RM159_12.0.013_025_U01_uda.fpsx Boot... RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg OMAP2420 UNISTORE-II-1.5.1 ALG teflon_sam_nand_xsr151_m1.fg Erase APE [06340000 - 0FA3FFFF] Erase[151.00 MB]... Waiting response for 320 Sec...in 4.39s Flash[33.68 MB]...in 63.78s * * Processed file in 81.34 seconds Extract content...OK Processing File: RM-159_12.0.014_PR.v12 Boot... RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg OMAP2420 UNISTORE-II-1.5.1 ALG teflon_sam_nand_xsr151_m1.fg Erase APE [04C40000 - 0633FFFF] Erase[23.00 MB]... Waiting response for 320 Sec...in 0.97s Flash[16.18 MB]...in 26.24s * * Processed file in 38.31 seconds * * * Phone flashing done in 4:53 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... V 06wk41v31.1/09-07-07/RM-159 (c) Nokia IMEI: 12345610654321? Factory Default Settings...OK Boot... Using Tx2 Data line. RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg teflon_sam_nand_xsr151_m1.fg BOOT OK... Send NPC Certificate RAP3 Certificate sent SUCCESSFULLY ============= Set FBus mode for info ============= VBat is 3.95V Vpp pin has 1.28V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-159 (Aalto (EU) ) V 06wk41v31.1/09-07-07/RM-159 (c) Nokia IMEI: 352255019351596 |
pls help n95 8gb phone start-up failed contact the retailar | aseer1 | Nokia Base Band 5 ( BB-5 ) | 3 | 05-15-2009 15:22 |
@ CINEK plz help n95 startup failed after unlock | EMINEMGSM | JAF No Tp Unlocker by Cinek | 17 | 03-07-2009 08:18 |
n95 unlock fail by BB5King pls help | lamlam | Nokia Base Band 5 ( BB-5 ) | 2 | 02-11-2009 17:57 |
n95 unlock failed plz help interessing error | ali.baydur | BB5KING | 1 | 12-25-2008 22:07 |
Please Help N95 Unlock Failed | cellectro | BB5BOX | 41 | 11-03-2007 10:43 |
