10-06-2007, 00:01 | #1 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Hungary, Pécs Age: 48
Member: 6142 Status: Offline Sonork: i dont use it Thanks Meter: 47 | Is it possible, that RPL is not good ? I got a dead phone for repairing,it has bad data: MEI: 352257012XXXXX Operator: FFFFFFFFFFFFFFFF Profile bits: FFFFFFFFFFFFFFFF Closed on GID1: 00101F Counters 0/10, 0/3 I generated RPL file, but when i write rpl, i gor this error: Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg BOOT OK... Send NPC Certificate Phone Type: BB5 ------------------- SYSTEM ID Response: 7 blocks ------------- SYSTEM_ASIC_ID( RAP ): 000000010000022600010006010C192101001101 EM_ASIC_ID( RAP ): 00000232 EM_ASIC_ID( RAP ): 00000352 PUBLIC_ID( RAP ): 29300103E3320058E53EDDE85E9BC95476EFC83C ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): BAF3A9C3DBFA8454937DB77F2B8852B1 ROM_ID( RAP ): 191EC665DFAAF68F --------------- Device ID Response: 3 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Amd, 0001 002F 0000 6921 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 ----------------- RPL Restore Certificate Status -------------------- RPL RAP3 Certificate sent SUCCESSFULLY Delay for 20 seconds... ============= Set FBus mode for info ============= Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-115 (Mojito ) V 05.50/20-09-06/RM-115 (c) Nokia. IMEI: 3522570129XXXXX Simlock send - FAILED! SuperDongle send - SUCCESSFULL!!! Is it possible, that rpl is not good or what is the problem? |
10-18-2007, 23:31 | #4 (permalink) |
No Life Poster Join Date: Nov 2005 Location: USA
Member: 197538 Status: Offline Thanks Meter: 97 | 911GT I got 2 RPLS for 6280 and both of them simlock failed super dongle success ... i mean there has to be a problem somehwere .. many people have this problem after server went down and both RPL's were calculated within 4 hours ... Wow i was susrpirsed but both bad .. now i have 3 RPLS that were bad simlock failed.. tried erasing .. flashing .. writing good PM without 134 field ..write RPL bu8t always simlock failed ... can u check the RPL if i send it to you ??? thanks Mike |
10-20-2007, 00:50 | #7 (permalink) | |
Banned Join Date: Jul 2005 Location: gsmcity Age: 42
Member: 159863 Status: Offline Thanks Meter: 4 | Quote:
br gsm_marrakech | |
10-21-2007, 17:39 | #10 (permalink) |
Member: 197538 Status: Offline Thanks Meter: 97 | Hi 911GT this is my 3rd RPL in a row for the same type phone .. 6280 .. with BAD RPL all simlock failed .. this cannot be a coincidence and way tooo many people complaining now ... i hve fixed almost 50m before and no problems and now all the RPLS problems .. please check for bugs in yr software ... maybe corruppted ask .. maybe bug ... ??? thanks Mike |
10-22-2007, 17:03 | #12 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @all users as i know there is NO BAD RPL. because one strong reason is RPL calc BY NOKIA ONLY. mt give error on Simlock send .. its means PHONE DON'T ACCEPT 308. mostally solve by test mode local mode. if same downgrade and rewrite.if same for writing sp area only you can use dss tool also because its free and support USB & mt format rpl. USB IS GOOD BECAUSE GIVE FASTER DATA WRITE ON TARGET AREA. so just try it.. link for it here |
10-22-2007, 17:18 | #13 (permalink) | |
No Life Poster Join Date: Jul 2004 Age: 42
Member: 72851 Status: Offline Thanks Meter: 28 | Quote:
Sir, Can you give me solution if superdongle failed? There is no way to write simlock data without superdongle data!! Like you say rpl are ok, that mean there a way to write those rpl which don't have superdongle data!! BR | |
is it possible that we can use that usb cable which coming with the all chies phone | shakil143 | SpiderMan | 1 | 11-19-2009 17:32 |
Is it Possible that the unlocking is after changing the firmware...(downgrading) | harim_1981 | Universalbox | 4 | 04-19-2008 06:55 |
is it possible that an unlocked DB2020 phone after full flashing get RE-LOCKED???? | ReyTech | Cruiser Suite | 1 | 05-03-2007 14:18 |
No RUSSIAN? flash for K500i! is it possible that it might support K700 flash file?? | AE177 | Griffin | 0 | 10-22-2004 00:02 |
is it possible that change cpu in 6210 | rifziyad | Nokia Hardware & Hardware Repair | 0 | 09-15-2002 18:09 |
