10-03-2007, 13:16 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 46
Member: 88996 Status: Offline Thanks Meter: 86 | problem with 6300 rpl Box: CR V 1.001 256 Code: NK V 1.001 1047 SN: 0018eafb7f Nokia Unlimited: 1386 times started SonyEricsson Trial: 5 left, each max 15min IMEI: 357671017051084 SKIPPED Certificate sent ============= Set FBus mode for info ============= Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Test mode Scanning files, please wait... Done Model: RM-217 (Piccolo 900 ) V 04.70/24-01-07/RM-217 (c) Nokia. IMEI: 357671017051084 Simlock send - FAILED! SuperDongle send - FAILED! Using Tx2 Data line. Processing File: BB5Erase_uni_rap.bin Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00000000 - 007FFFFF] Erase RAP3 [00800000 - 00FFFFFF] Erase RAP3 [01000000 - 01FFFFFF] Erase[32.00 MB]... Waiting response for 320 Sec...in 69.19s Flash[0.00 MB]...in 0.00s * * Processed file in 78.61 seconds * * * Phone flashing done in 1:25 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! Selected Highest installed version: 04.70 Using Tx2 Data line. BB5 PM back Phone is in: Phone is not responding! Processing File: rm217__04.70.mcusw Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00000000 - 000006BF] Erase RAP3 [000006C0 - 0001FFFF] Erase RAP3 [00020000 - 0007FFFF] Erase RAP3 [00080000 - 000DFFFF] Erase RAP3 [00100000 - 001FFFFF] Erase RAP3 [00200000 - 0031FFFF] Erase RAP3 [00320000 - 0105FFFF] Erase RAP3 [01060000 - 01067FFF] Erase RAP3 [01068000 - 0107FFFF] Erase[16.38 MB]... Waiting response for 320 Sec...in 4.09s Flash[14.37 MB]...in 51.61s * * Processed file in 65.38 seconds Processing File: rm217__04.70.image_s Content area page size is 128K. Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [01600000 - 01FDFFFF] Erase[9.88 MB]... Waiting response for 320 Sec...in 5.03s Flash[3.88 MB]...in 17.20s * * Processed file in 33.95 seconds Extract content...OK Processing File: rm217__04.70.ppm_s Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [01080000 - 015FFFFF] Erase[5.50 MB]... Waiting response for 320 Sec...in 1.53s Flash[5.14 MB]...in 19.16s * * Processed file in 30.14 seconds * * * Phone flashing done in 2:36 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... V 04.70/24-01-07/RM-217 (c) Nokia. IMEI: 12345610654321? Factory Default Settings...OK IMEI: 12345610654321? Using Tx2 Data line. Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg BOOT OK... Send NPC Certificate Send HWC Certificate Send CCC Certificate stop here only |
10-03-2007, 14:01 | #3 (permalink) |
Member: 88996 Status: Offline Thanks Meter: 86 | sir after i uncheck get this info Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg BOOT OK... Send NPC Certificate Send HWC Certificate Send CCC Certificate Phone Type: BB5 ------------------- SYSTEM ID Response: 7 blocks ------------- SYSTEM_ASIC_ID( RAP ): 000000010000022600010006010C192101001101 EM_ASIC_ID( RAP ): 00000232 EM_ASIC_ID( RAP ): 00000353 PUBLIC_ID( RAP ): 0A90000FBC45005228F0EA3FB18146A7EFB10FF9 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): BAF3A9C3DBFA8454937DB77F2B8852B1 ROM_ID( RAP ): 191EC665DFAAF68F --------------- Device ID Response: 3 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Samsung, 00EC 2208 0000 6921 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 ----------------- RPL Restore Certificate Status -------------------- RPL RAP3 Certificate sent SUCCESSFULLY Delay for 20 seconds... ============= Set FBus mode for info ============= Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Test mode Model: RM-217 (Piccolo 900 ) V 04.70/24-01-07/RM-217 (c) Nokia. IMEI: 357671017051084 Simlock send - FAILED! SuperDongle send - FAILED! simlock can't send |
10-03-2007, 16:07 | #5 (permalink) |
Member: 88996 Status: Offline Thanks Meter: 86 | here is the log IMEI: 357671017051084 V 05.00/27-04-07/RM-217 (c) Nokia. IMEI: 357671017051084 Operator: FFFFFFFFFFFFFFFF Profile bits: FFFFFFFFFFFFFFFF Closed on GID1: 00101F Counters 0/10, 0/3 |
10-03-2007, 16:52 | #7 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | now put your phone on a local mode and write RPL again but when soft quest you for IMEI writing you need to click on "NO" button and post log again. If all is ok then you have a problem with this cable |
Problem with write rpl with N70 | kurdistan | Universalbox | 1 | 03-29-2008 21:44 |
Problem Write 6300 RPL!!!! | ..::M-GSM::.. | Universalbox | 0 | 12-29-2007 05:03 |
Problem with 6300 unlocking with new methode | Bloedman | UID - Box | 10 | 10-24-2007 08:24 |
Problems with 6300 installing usb driver... | Burnt Cobba | Universalbox | 1 | 09-23-2007 11:03 |
