06-26-2007, 10:44 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: romania-bm Age: 40
Member: 174315 Status: Offline Thanks Meter: 123 | problem with mt pro server all counter are to 0 , version is suported ok, but while unlocking it tells me to write simlock data in phone..i press no. after that it make the fbus counter to 10...even if before unlocking fbus counter was to 0. can you pls check..and tell me what to do? i attached here screenshots with reading with nemesis before and after unlocking. |
06-27-2007, 17:18 | #3 (permalink) |
Member: 174315 Status: Offline Thanks Meter: 123 | ok, thx for reply, 3 pieces unlocked ok. but i have 1 piece of nk 5200 that don't want to unlock..i tried upgrade, downgrade and still same problem. with original backup..fbus counter is 0..but after i try to unlock..it gives me: bb5bckup\355537010505578.pm nBackup file already exists! SKIPPING backup ================================= =================================== V 03.70/22-09-06/RM-174 (c) Nokia. IMEI: 355537010505578 Operator: 8000000000000000 Profile bits: 2080100000000000 Closed on Mcc Mnc: 20801F =================================== Using Account: xxxxxxxxxxx Connect... Resp: o/0110/hello there Login... OK, available count 206; busy, waiting... Server Response OK. =================================== Connect TPs V 03.70/22-09-06/RM-174 (c) Nokia. IMEI: 355537010505578 V 03.70/22-09-06/RM-174 (c) Nokia. IMEI: 355537010505578 V 03.70/22-09-06/RM-174 (c) Nokia. IMEI: 355537010505578 TPs OK TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED FAILED, ALL ATTEMPTS USED! Restarting phone Finished Restarting phone V 03.70/22-09-06/RM-174 (c) Nokia. IMEI: 355537010505578 V 03.70/22-09-06/RM-174 (c) Nokia. IMEI: 355537010505578 Canceling detect on User request.... and after that the fbus counter is back to 10. any other advices for me? thx in advance and much apreciated, atleast i succeded to unlock the other 3 pieces of 5200. |
06-28-2007, 09:41 | #5 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | hey man click on simlock ctate and post log!!!!!!!!!!!!!!!!!!!!! from 1st picture i see lock is not active or a i wrong????? if lock is not active then soft can do that "TESTPOINT FAILED" |
06-28-2007, 18:51 | #6 (permalink) |
Insane Poster Join Date: Mar 2007 Location: Romania, Baia Mare
Member: 472979 Status: Offline Thanks Meter: 82 | problem solved now..after over 6 times upgrade/downgrade and retryes...finally phone got unlocked. thx for support. @911GT phone was locked..not unlocked in first image. last field from nemesis window, LOCK ACTIVE ...NO will show you NO..not matters that phone is locked..or not locked. electrolandgsm's coleague |
problem for unlock nokia 7390 with mt-pro lite | yane | MT-BOX | 4 | 12-06-2007 17:00 |
Please fix N71 unlock problem with mt pro/mt lite! | hoang | MT-BOX | 4 | 09-22-2007 15:15 |
i have problem with unlock 5200 end 5300 with mt-pro | nio | MT-BOX | 1 | 09-17-2007 22:39 |
What wrong with mt pro server | alif30 | MT-BOX | 1 | 09-05-2007 11:20 |
simlock not initialised. n95 unlock problem with MT PRO | zenadia | MT-BOX | 1 | 09-01-2007 21:58 |
