08-24-2007, 14:48 | #1 (permalink) |
Freak Poster Join Date: May 2004 Age: 45
Member: 64680 Status: Offline Thanks Meter: 14 | Problem unlocking N95 I have N95 which had 0/10 counter (100% sure), then TP OK, TP FAILED x 10, now it has 10/10 counter. MT wants to authorize SX4 when try to write backup, but no success. I tried also to write backup and authorize with jaf, but still 10/10. Are you able to check whether my backup is ok? Regards, Tom ps spansion chip onboard |
08-25-2007, 07:31 | #3 (permalink) |
Member: 64680 Status: Offline Thanks Meter: 14 | Man - I'm using MT-Pro backup - it contains only 134 field. When I load the file in PMM tab, and I want to upload it to the phone - MT wants to authorize this (SX4). Regards, Tom |
08-25-2007, 08:05 | #4 (permalink) |
Member: 64680 Status: Offline Thanks Meter: 14 | MY FAULT! When MT asks "Do you want to write simlock data?" (or something like that) - we have to put "NO". I always pushed "yes", and that was my problem. Sorry for bothering. Regards, Tom ps what about my accounts that I described you in PM? |
08-28-2007, 19:23 | #6 (permalink) |
Freak Poster Join Date: Feb 2003 Location: England,Birmingham Age: 36
Member: 23511 Status: Offline Thanks Meter: 10 | i have similar problem but mine keeps saying failed to authorise sx4 when i try to write pm phone is ok comes on and in local mode also i followed the manual but when i write back keeps saying failed on each little part it tries to write back and says failed to authorsie sx4 |
08-29-2007, 17:19 | #10 (permalink) | |
Freak Poster Join Date: Jul 2004 Location: Tirana
Member: 71212 Status: Offline Thanks Meter: 10 | Quote:
i did following steps: 1.Connect phone. 2.Cable is usbmini phone in normal (tried and in local mode or test) mode (cable can read info in normal mode and local mode) 3.Load the PM file field ( load file, in Eeprom controls page). 4.Mark Section( resource) 308 (0x134) and press Write Selected More clear in the attached picture but it can't write the backup into the phone. Any help about the cable or the wrong field selection is approciate. Br. and thanks 911GT | |
08-30-2007, 14:19 | #13 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | man phone need to be in LOCAL MODE and to can read phone info if this is ok then you can write 134 fielad and he need to be writed WITHOUT SX4. if 134 is ok then you can authorize phone with sx4 if not you never can authorize phone with sx4. DO YOU UNDERSTAND FULL SITUATION???? IF SIMLOCK IS OK THEN HAVE A SX4 IF NOT AND SX4 FAIL |
08-30-2007, 17:03 | #14 (permalink) |
Member: 23511 Status: Offline Thanks Meter: 10 | mine is ok but when i do a check server status mine only shows / BB5_UNLC 1 and other peoples it shows NK_BB5_PM_AUTH 0 and mine does not it doesnt no let me authorise sx4 my 308 is fine please help simlock state is fine i will post log in a while |
08-30-2007, 17:59 | #15 (permalink) |
Member: 23511 Status: Offline Thanks Meter: 10 | Phone is in: Local mode Model: RM-159 (Aalto (EU) ) V 06wk41v23.4/17-04-07/RM-159 (c) Nokia Production serial number SHF993128 Product code 0547869 Module code Basic production code 0537959 Flash code Order number Long production SN 0 MCU SW V 06wk41v23.4/17-04-07/RM-159/(c) Nokia HW 5650 PCI RFIC 17141714 DSP dsprap_pb06w41v24 APE SW Core 11.0.026 APE Variant 11.0.02641.03 APE Test rm159_ENO_x_2007wk02v0.070 Retu 15 Tahvo 22 APE HW 1 APE ADSP SW 256 APE BT HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. IMEI: 352************ V 06wk41v23.4/17-04-07/RM-159 (c) Nokia IMEI: 352************ Operator: 0000000000000000 Profile bits: 2341500000000000 Closed on GID1: 23415F Closed on Mcc Mnc: 23415F Counters 10/10, 0/3 PMM Send File Sending SIMLOCK record... Warning: Failed to write 134:0001, 8192bytes. Use SX4 button to authorize Warning: Failed to write 134:0003, 1bytes. Use SX4 button to authorize Warning: Failed to write 134:0004, 1bytes. Use SX4 button to authorize Warning: Failed to write 134:0005, 10bytes. Use SX4 button to authorize Warning: Failed to write 134:0006, 1bytes. Use SX4 button to authorize Warning: Failed to write 134:0007, 1bytes. Use SX4 button to authorize Warning: Failed to write 134:0008, 1bytes. Use SX4 button to authorize Warning: Failed to write 134:0009, 40bytes. Use SX4 button to authorize Operation Completed |
problem unlocking n95s | Foneish | MT-BOX | 6 | 07-10-2008 01:37 |
Problem Unlocking N95 | imran_qasim | J.A.F. V-SPEC | 4 | 02-09-2008 12:28 |
Problem unlocking N95 | teerak2uk | J.A.F. Plus | 8 | 01-03-2008 10:16 |
Bad Problem Unlocking N95 | petermov | MT-BOX | 3 | 11-19-2007 21:06 |
Problem unlocking N95 | tito millo | MT-BOX | 4 | 11-09-2007 00:51 |
