01-14-2008, 15:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: burning phones
Member: 9700 Status: Offline Thanks Meter: 62 | simlock problem 1234... IMEI FFFFFF Simlock I can restore imei by writting imei backup, imei ok. But I cannot write simlock backup because I need to make sx4 auth but sx4 auth is not possible with FFFF simlock then I want to ask if there is any way to solve this because I have sp lock backup In other bb5 phones I was writted full pm without 308 field and then I was able to make sx4 auth for restore my simlock backup but in this n73 I write full pm and simlock still FFFFF any help? could be my simlock backup bad readed or corrupted? I know that I can repair it with ask->rpl but please I want to know any alternative because I have backup if I can't solve this of course I will make ask-rpl (when service will works again) thanks wbr thecult |
01-14-2008, 19:59 | #3 (permalink) |
Member: 9700 Status: Offline Thanks Meter: 62 | almost thanks for you Sad answer but ... 134 field doesn't need sx4 but all other security fields from backup needs sx4 auth but I can't make sx4 auth because simlock is FFFF and my 308 backup doesn't change simlock state (as I said) this means my 134 field is corrupted or phone damaged before first downgrade? |
01-15-2008, 06:31 | #4 (permalink) |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | check while writing the 134 set should be in local mode... then also same means definitely before downgrading your security area will be damaged one only... then you need RPL |
phlips 535 simlock problem any idea!!!! | abbas | Redbox | 9 | 08-10-2004 07:21 |
A300 simlock problem | jagajutt | VLSI, Conexant, Skyworks and Old Models | 2 | 12-16-2003 12:13 |
Asking About Gx20 Simlock Problem | hkburberrys | Sharp | 0 | 10-09-2003 19:44 |
sagem mw3026 load-a-game simlocked problem | zombie | Infineon C16X M51 & ARM7 M52 BASED | 0 | 02-18-2003 20:20 |
GD93 simlock problem !!! | MPS | Panasonic | 2 | 02-04-2002 03:03 |
