07-01-2007, 07:51 | #1 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Slovakia BA Age: 51
Member: 25110 Status: Offline Thanks Meter: 79 | using JAF cables on MTbox - it is possible? Thanks Foony |
07-02-2007, 04:28 | #7 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Earth Age: 49
Member: 10387 Status: Offline Thanks Meter: 3 | not work with jaf 7 pin cable, you need mod 7pin cable to 5pin, just put the 7pin cable rx2 pin(MT 5pint cable not use rx2) to vpp and release usb power pin(not use, 7pin cable is short to GND), and uncheck TX2line for flash |
07-02-2007, 05:33 | #8 (permalink) |
No Life Poster Join Date: Mar 2005 Location: S7°1x'xxx" - E112°4x'xxx"
Member: 128035 Status: Offline Thanks Meter: 317 | about VPP: http://forum.gsmhosting.com/vbb/showthread.php?t=267688 about error, usually because of too long mt-box 10 to 8 adapter, and too long f-bus cable, or resistance in bsi-gnd and bsi serial not correct. i'm not keep all my flashing log, but here's one, n70 after erased. 7 pins cable, VPP pin from rj45 connected to RX2 in phone. Code: VPP is DISABLED. Processing File: RM84_50705301.C0 Boot... rap3gv2_2nd.fg RAP3Gv3_algo.fg helen3_2nd.fg h3_sam_nand_gbbm.fg Erase RAP3 [00000000 - 0052B469] Erase RAP3 [006A0000 - 006BFFFF] Erase RAP3 [006DF000 - 006EFFFF] Erase RAP3 [00700000 - 007EFFFF] Erase APE [00000000 - 0000FFFF] Erase APE [00010000 - 0001FFFF] Erase APE [00020000 - 000203FF] Erase APE [00050000 - 03ECFFFF] Erase[68.92 MB]... Waiting response for 320 Sec...in 1.17s Flash[29.40 MB]...in 71.97s * * Processed file in 82.75 seconds Processing File: RM84_50705301.V12 Boot... rap3gv2_2nd.fg RAP3Gv3_algo.fg helen3_2nd.fg h3_sam_nand_gbbm.fg Erase APE [01AE0000 - 02AFFFFF] Erase APE [02B00000 - 03ECFFFF] Erase[35.94 MB]... Waiting response for 320 Sec...in 3.97s Flash[9.76 MB]...in 22.72s * * Processed file in 36.23 seconds * * * Phone flashing done in 2:13 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... V 05wk07v47/30-01-07/RM-84 (c) Nokia. IMEI: 12345610654321? Factory Default Settings... http://forum.gsmhosting.com/vbb/show...01&postcount=4 regards |
07-02-2007, 06:55 | #11 (permalink) | |
Member: 128035 Status: Offline Thanks Meter: 317 | Quote:
remember, 7 pins cable, VPP line in rj45 connected to RX2 in phone. but mt-box, VPP line in rj45 conncected to VPP in phone. but for "rapido", flash loader must communicate via tx2 line (rx2 in phone). sorry for my english, i can't explain better.. regards | |
07-02-2007, 07:14 | #12 (permalink) | |
Member: 10387 Status: Offline Thanks Meter: 3 | Quote:
DisableVPP, why do you need it , and when to use it: When flashing some phones, you can use VPP to speed up the flashing of the phone ( in some case twice faster). When to use VPP is determined by type of flash in phone, model of phone, loader used to flash the phone ... So this is a very complicated decision that MT-BOX makes automatically when you flash. Why do you need 'DisableVPP': MT-Box is the first flasher ( not produced by Nokia) that uses VPP and that is why it is so fast. The problem is that if MT-Box tries to use VPP, and the cable doesn't have VPP, or it is connected to wrong PIN the flashing will FAIL. NOTE the same cable may work with other boxes because they don't use VPP. So for those cases we've added this option. It will allow you to use the old slow method and flash the phone without using VPP. This option will be remembered by SW and next time you try to flash the same model it will be flashed with DisableVPP. To professionals that can repair their cables, WE STRONGLY RECOMMEND TO REPAIR THE CABLE AND FLASH WITH VPP. Slow Flashing: MT-Box sends flash data to phone very fast. As you can see this works on almost all nokia phones. This option is made for a few models that are very slow ( 7650 and some other WD2 phones ). When you use it, MT-BOX will transmit data 2-3 times slower, so the slow phone is able to recieve it. Why MT-Box needs this option, and other flashers don't?: - because all other flasher transmit slower then MT-Box even when it transmits in Slow mode | |
08-04-2007, 16:58 | #13 (permalink) |
No Life Poster Join Date: Apr 2002
Member: 10964 Status: Offline Thanks Meter: 285 | so what is the advice for mt users that have jaf cables? 1. use adaptor, use vpp (faster flashing) 2. for models with 'rapido' chip (N95, N76 etc) buy new cables with 10 pins (not using adaptor anymore) br sorinm |
i want to use jaf cable on mt box | shoaib82a | MT-BOX | 7 | 12-28-2009 04:19 |
Possible to use JAF cables on MT BOX? | aj4u | Nokia Base Band 5 ( BB-5 ) | 1 | 08-17-2009 01:33 |
It is possible to use polar in windows vista? :::ANSWERED::: | blackphantom | PolarBox 3 | 3 | 03-19-2009 00:46 |
It is possible to use pinfinder? | shuric | Chinese Cocktail | 3 | 07-14-2008 08:36 |
