03-15-2010, 18:09 | #1 (permalink) |
No Life Poster Join Date: Aug 2005
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | unlock nokia 5800 v31.0.008 w/ 2.34b not ok Phone is in: Local mode Model: RM-356 (5800 Xpress Music) V ICPR72_09w20.8/09-07-09/RM-356 (c) Nokia Production serial number C7D671584 Product code 0593493 Module code Basic production code 0586552 Flash code Order number 1111111 Long production SN 0 MCU SW V ICPR72_09w20.8/09-07-09/RM-356/(c) Nokia HW 1105 PCI RFIC 17141716 DSP ICPR72_09w19_1 APE SW Core V 31.0.008 APE Variant V 31.0.008V 31.0.008 31.0.008.235.10 APE Test rm356_ENO_A_09wk17v0.310_hi Retu 16 Tahvo 22 APE HW 256 APE ADSP SW 256 Content Pack 31.0.008_006_U472 IMEI: 35xxxxxxxxxxxxx WARNING: VPP pin is not connected, disabling VPP. V ICPR72_09w20.8/09-07-09/RM-356 (c) Nokia IMEI: 358xxxxxxxxxxxxx Operator: 2343000000000000 Operator Name: T-Mobile-One 2 One;United Kingdom Profile bits: 8000000000000000 Closed on Mcc Mnc: 23430F Counters 0/10, 0/3 Reading phone PMM to file Phone is in: Local mode Operation Completed V ICPR72_09w20.8/09-07-09/RM-356 (c) Nokia IMEI: 358xxxxxxxxxxxxx Operator: 8000000000000000 Profile bits: 2343000000000000 Closed on Mcc Mnc: 23430F 358279039609829 Searching loader RAPIDOv11_2nd.fg Status Successfull Found BB5SL20 Pin. Proceeding in StandAlone mode Sending RPL... C:\Program Files\GriffinTeam\MT-Box\rpls\358279039609829_sim.rpl NO NPC CERTIFICATE!!!! SKIPPED Certificate sent ============= Set FBus mode for info ============= NO SERIAL COMMUNICATION WITH PHONE NOT SENDING SIMLOCK AND SUPERDONGLE CHECK CABLE! VBat is 3.90V Vpp pin has 0.12V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 Phone Not powered Procedure completed in 25 seconds SL20 RPL Procedure Finished ============= Set Flash mode for info ============= Boot... Trying boot BB5 phone... Failed to find RAP3 2nd loader Phone Type: BB5 ------------------- SYSTEM ID Response: 7 blocks ------------- SYSTEM_ASIC_ID( RAP ): 000000010000022600010006400C192101031103 EM_ASIC_ID( RAP ): 00000296 EM_ASIC_ID( RAP ): 00000B22 PUBLIC_ID( RAP ): 1C3001063885005200C4093495316E6E5552C81E ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): CAEEBB65D3C48E6DC73B49DC5063A2EE ROM_ID( RAP ): 4B9B75103E691FF8 ============= Set FBus mode for info ============= VBat is 3.91V Vpp pin has 0.09V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone not powered ============= Set Flash mode for info ============= Boot... Trying boot BB5 phone... Failed to find RAP3 2nd loader Phone Type: BB5 ------------------- SYSTEM ID Response: 7 blocks ------------- SYSTEM_ASIC_ID( RAP ): 000000010000022600010006400C192101031103 EM_ASIC_ID( RAP ): 00000296 EM_ASIC_ID( RAP ): 00000B22 PUBLIC_ID( RAP ): 1C3001063885005200C4093495316E6E5552C81E ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): CAEEBB65D3C48E6DC73B49DC5063A2EE ROM_ID( RAP ): 4B9B75103E691FF8 ============= Set FBus mode for info ============= VBat is 3.91V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 ============= Set Flash mode for info ============= Boot... Using Tx2 Data line. Trying boot BB5 phone... RAPIDOv11_2nd.fg FAILED TO RECEIVE DEVICE CONFIGURATION! Failed to find CMT Flash loader( damaged flash chip/damaged RAP3 chip) Command reset failed, using HW switch. Phone Type: BB5 ------------------- SYSTEM ID Response: 7 blocks ------------- SYSTEM_ASIC_ID( RAP ): 000000010000022600010006400C192101031103 EM_ASIC_ID( RAP ): 00000296 EM_ASIC_ID( RAP ): 00000B22 PUBLIC_ID( RAP ): 1C3001063885005200C4093495316E6E5552C81E ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): CAEEBB65D3C48E6DC73B49DC5063A2EE ROM_ID( RAP ): 4B9B75103E691FF8 ============= Set FBus mode for info ============= VBat is 3.93V Vpp pin has 0.12V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 ============= Set Flash mode for info ============= Boot... Using Tx2 Data line. Trying boot BB5 phone... RAPIDOv11_2nd.fg FAILED TO RECEIVE DEVICE CONFIGURATION! Failed to find CMT Flash loader( damaged flash chip/damaged RAP3 chip) Command reset failed, using HW switch. Phone Type: BB5 ------------------- SYSTEM ID Response: 7 blocks ------------- SYSTEM_ASIC_ID( RAP ): 000000010000022600010006400C192101031103 EM_ASIC_ID( RAP ): 00000296 EM_ASIC_ID( RAP ): 00000B22 PUBLIC_ID( RAP ): 1C3001063885005200C4093495316E6E5552C81E ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): CAEEBB65D3C48E6DC73B49DC5063A2EE ROM_ID( RAP ): 4B9B75103E691FF8 ============= Set FBus mode for info ============= VBat is 3.91V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-356 (5800 Xpress Music) V ICPR72_09w20.8/09-07-09/RM-356 (c) Nokia IMEI: 358xxxxxxxxxxxx V ICPR72_09w20.8/09-07-09/RM-356 (c) Nokia IMEI: 358xxxxxxxxxxxxxxxxxxx Operator: 2343000000000000 Operator Name: T-Mobile-One 2 One;United Kingdom Profile bits: 8000000000000000 Closed on Mcc Mnc: 23430F Counters 0/10, 0/3 V ICPR72_09w20.8/09-07-09/RM-356 (c) Nokia IMEI: 358xxxxxxxxxxxxxxxxxxxxx Operator: 8000000000000000 Profile bits: 2343000000000000 Closed on Mcc Mnc: 23430F 358279039609829 Searching loader RAPIDOv11_2nd.fg Status Successfull Found BB5SL20 Pin. Proceeding in StandAlone mode Sending RPL... C:\Program Files\GriffinTeam\MT-Box\rpls\358279039609829_sim.rpl NO NPC CERTIFICATE!!!! IMEI: 358xxxxxxxxxxxxxxxxxx SKIPPED Certificate sent ============= Set FBus mode for info ============= VBat is 3.95V Vpp pin has 0.12V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode IMEI: 358xxxxxxxxxxxxxxxxxxx Delay one second. Simlock send - FAILED! SuperDongle send - NO DATA IN RPL!!! V ICPR72_09w20.8/09-07-09/RM-356 (c) Nokia IMEI: 358xxxxxxxxxxxxxxx Operator: 2343000000000000 Operator Name: T-Mobile-One 2 One;United Kingdom Profile bits: 8000000000000000 Closed on Mcc Mnc: 23430F Counters 0/10, 0/3 Procedure completed in 22 seconds SL20 RPL Procedure Finished V ICPR72_09w20.8/09-07-09/RM-356 (c) Nokia IMEI: 358xxxxxxxxxxxxxxx Operator: 2343000000000000 Operator Name: T-Mobile-One 2 One;United Kingdom Profile bits: 8000000000000000 Closed on Mcc Mnc: 23430F Counters 0/10, 0/3 V ICPR72_09w20.8/09-07-09/RM-356 (c) Nokia IMEI: 358xxxxxxxxxxxxx Operator: 2343000000000000 Operator Name: T-Mobile-One 2 One;United Kingdom Profile bits: 8000000000000000 Closed on Mcc Mnc: 23430F Counters 0/10, 0/3 |
Can’t unlock Nokia 5800 V31.0.000 [SOLVED] | fun | Genie Universal | 7 | 03-18-2010 19:33 |
When MXKEY support "New RAPIDO" phones like 5800 v31.0.008 or +, N96 v30.033 or +???? | puntodecontrol | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 12 | 02-26-2010 15:30 |
5800 v31.0.008 Supported for unlock ? | dannyogolo | Universalbox | 5 | 01-29-2010 10:16 |
5800 v31.0.008 unlock | davidjollie | Cyclonebox | 2 | 01-29-2010 08:10 |
5800 v31.0.008 unlock via logger & credits? | backbiter17 | Genie Universal | 5 | 10-23-2009 12:40 |
