Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > NON Siemens Brand (ODM Phones)
NON Siemens Brand (ODM Phones) Do you know that C62 is not a Siemens Manufactured !? here in this section we Throw all non Siemens-Benq related Threads like C62, CFX65, SF65, CL75, CL50, S40, U15, C30,Xelibri.
Old 05-27-2008, 16:30   #1 (permalink)
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1594535
Post All Siemens, BenQ Siemens Pinouts Request [Only Here]
Benq-Siemens AF51, A31 cell phones cable connector pinout
3 Tx
4 Rx
5 GND
7 Ign
Siemens A35, A36, A40, C25, C35, C45, M35, M35i, M50, ME45, MT50, S25, S35, S45, SL-42, SL45, 3118 cell phones cable connector pinout
1 GND - Ground
2 SELF-SERVICE in/out Recognition/control battery charger
3 LOAD in Charging voltage
4 BATTERY out Battery (S25 only)
5 DATA OUT (TX) out Data sent
6 DATA IN (RX) in Data received
7 Z_CLK - Clock line for accessory bus. Use as DCD In data operation
8 Z_DATA - Data line for accessory bus. Use as CTS in data operation
9 MICG - Ground for microphone
10 MIC in Microphone input
11 AUD out Loudspeaker
12 AUDG - Ground for external speaker
Siemens sl42, sl45 and sl45i and some others should have audio L, R and Gnd somewhere in these 12 pins (for their stereo mp3 player). Suggested that audio L is pin 2, audio R is pin 11 and audio Gnd is pin 12.
Siemens A52, A55, A56, A60, C55, C56, C60, C65, CF62, CT56, M55, MC60, MT55, S55, S56, S57, S65, SL5C, SL55, SL56, 1168, 2218, SX1 cell phones cable connector pinout
1 Vin Power Charging Vbus in in x65, SX1
2 Gnd GND usb GND in x65, SX1 USB cable
3 Tx TX / USB D+ usb D+ in x65, SX1
4 Rx RX / USB D- usb D- in x65, SX1
5 CTS CTS Data Line For Accesory. Used as a cable detect in Siemens x65-x75 models. Short to pin 2 GND to force cable detection.
6 RTS RTS Data Line For Accesory or serial cable
7 DCD DCD Clockline For Accesory
8 Audio P AUDIO L
9 - AUDIO GND
10 Audio N AUDIO R
11 GND Mic GND (EXT MIC.)
12 EPP EPP 1 (EXT MIC.)
Pins 5,6,7 should be shorted by 10KOhm resistors to pin 2 in x65, SX1 USB cable
Siemens C30, M30 cell phones cable connector pinout
1 GND
2 C-BUS
4 Battery +5V Ext
5 Data Out
6 Data In
7 GND
8 GND
11 +5V (Test)
12 RX
13 TX
14 GND
Siemens C62 cell phone pinout
1 Vcharge +5V?
2 Gnd
5 Tx
7 Rx
9 +12v
Siemens CX75 pinout
1 POWER I/O for charging the battery and for supplying external accessories by reducing standby-time
2 GROUND Digital Ground
3 TX / D+ Out for Serial-Interface, I/O for USB-Interface full-speed 12Mbis/s
4 RX / D- In for Serial-Interface, USB-Interface full-speed 12Mbis/s
5 DATA / CTS I/O Data-Line for accessory-bus, use as CTS in data-operation
6 RTS I/O use as RTS in data-operation
7 CLK / DCD I/O Clock-Line for accessory-bus, use as DTC in data-operation
8 STEREO1_OUT Analog Out, driving ext. left speaker to Pin 9 with mono-headset. Pin 8 and Pin 10 differential mode
9 PHANTOM_BUF_OUT Analog Out, mid voltage, in stereo-mode reference to Pin 8 and Pin 10, in Mono-mode not used
10 STEREO2_OUT Analog Out, driving ext. right speaker to Pin 9 with mono-headset. Pin 8 and Pin 10 differential mod
11 GND_MIC Analog In, for external microphone
12 MICEA_AC Analog In, external Microphone
Siemens S10 S11 S1088 cell phones cable connector pinout
1 LOAD Charging voltage IN
2 BATTERY Battery OUT
3 DATA IN Data received [S6, S8pin=2] IN
4 ANTENNA Antenna -
5 ??? -
6 ??? -
7 MICG Ground for microphone IN
8 GND Ground -
16 GND Ground -
15 EARPHONE Earphone -
14 MIC Microphone input. Some sources report this pin as TX!? -
13 AUD Loudspeaker OUT
12 ??? -
11 DATA OUT Data sent[S6, S8pin=15] OUT
10 ??? -
9 ???
Siemens S40 cell phone pinout
5 GND
6 TX
14 RX
Siemens S6/8/C10 cell phones cable connector pinout
7 RX <--
9 GND ---
15 TX -->
Siemens SL-10 cell phone pinout
1 GND
2 Tx
3 Rx
Old 05-27-2008, 16:35   #2 (permalink)
Member: 123458
Sonork: 100.1594535
Siemens ST55 cell phone pinout
1,2 connected in cable?
3 audio pair with pin 15
4 V+ charge 4,5,6 joined (checked)
9 RX Rx may be at pin 10
14 TX Tx may be at pin 15
15 audio pair with pin3
16,17,18 GND 16,17,18 connected (checked)
The charging pins are correct and checked, with a self made charger
BenQ S660C Ripcurl, P30 pinout
1 L Signal GND
2 R Signal Rx
3 Ground Signal Tx
Benq A38, A500, C71A, CF61, CL71, E61, EF61, M100, M220, M300, M305, M315, M350, M580, O2X1i, O2X1b, O2XLI, O2X2i, O2X3, S700, S88 cell phones interface connector pinout
1 GND
5 Rx
6 Tx
Benq O2X4, S80, S82 cell phones interface connector pinout
1,2 GND black
7 USB Data + green
8 USB Data - white
10 USB +5V red
Benq O2X7 cell phone interface connector pinout
1 GND connected to pin 6 (in cable)
7 Rx
8 Tx
Benq-Siemens EF81 cell phones cable connector pinout
1 TX/D+
2 RX/D-
5 GND
7 +5V optional
Fly-Bird S570 connector pinout
1 GND
5 Tx
6 Rx
The Following User Says Thank You to shahzaadbutt For This Useful Post:
Old 05-27-2008, 16:36   #3 (permalink)
Moderator
dagos's Avatar
Member: 416908
...or for the other phone models go to: http://pinouts.ru/pin_CellularPhones-A-N.shtml ; http://pinouts.ru/pin_CellularPhones-Nokia.shtml ; http://pinouts.ru/pin_CellularPhones-P-W.shtml
dagos
Old 05-27-2008, 17:10   #4 (permalink)
Member: 123458
Sonork: 100.1594535
is it not better that directly here in forum?
Old 05-27-2008, 17:51   #5 (permalink)
Moderator
dagos's Avatar
Member: 416908
...I don't insert link to the other forums
Best regards,
dagos
All SonyEricsson Pinouts Request [Only Here] shahzaadbutt Sony Ericsson 61 04-14-2013 17:44
All LG Pinouts Request [Only Here] shahzaadbutt LG 195 04-09-2013 09:17
All Philips Pinouts Request [Only Here] shahzaadbutt Philips 7 03-11-2010 15:18
All Mitsubishi Pinouts Request [Only Here] shahzaadbutt Mitsubishi 12 12-26-2008 16:49
All Alcatal Old & New Phones Pinouts Request [Only Here] shahzaadbutt BF, BG, TH, BHx Series 7 06-04-2008 18:54
Page generated in 0.30848 seconds with 11 queries
