Benq "S88" Usb Cable Pinout for XCSDTool_L1... Hi all... We need benq s88 usb cable pinout... "USB Cable 0520" |
need fbus cable for s88 (infinity box) plz help [email protected] |
Flash with orig usb cable not work:mad: something usb->serial adapter needs or what? This from orig siemens dokument: • XCSDTool USB Data Cable Setup User Guide Information how to install driver for the SW update cable. • XCSDTool Download Function User Guide Information how to download SW to the mobile phone • Driver for USB to serial cable (SW update cable with the adapter in it) It is in folder Win2K_XP • XCSDTool Level 1 V1.5.2 Program for download SW to the mobile phone • Software V 1.08 1. Download from IMS all relevant files to your hard drive and create folders like in IMS 2. Install the driver for the USB to serial cable (For USB driver installation use: “XCSDTool USB Data Cable Setup User Guide” document Driver for USB cable available under “Win2K_XP”) 3. Install XCSDTool Level 1 V1.5.2 (In folder XCSDTool V1.5.2 go to folder Disk1 and click on SETUP Application) 4. To learn how to use the XCSDTool use the “Download Function User Guide” Other: 2 Overview 2.1 Getting Start There are some base words described below should be known before using this tool. Baud rate and data cable This tool provides fixed baud rate 806400 (the fast speed we support now) for download procedure. The user should use the USB-to-RS232 data cable to perform fast download with 806400 baud rate. BootROM / Embedded download Where this kábel or shematic????????????? |
Hi, The original cable (same with DCA140), not working to flash. To flash you need to have pinouts configuration with the attached schematic. Maybe help you this information, br, dagos |
Very thanks. You've been doing one adaptor and writes the unsuccessful. |
schema Quote:
can u please post the schema again...i c u edited ur thread.. |
Can someone confirm, if this is true? Flashing with DIP-100? :confused: I'm not sure. http://www.faq4mobiles.de/forum/showthread.php?t=8621 |
Hmmm... With DIP-100 and XCSD Tool V1.5.2 still 100% not work for flash. With BenQ-Siemens XCSD154 Flashtool......I don't know. Plus ought try. |
I'm not sure. Because I don't have S88. But I know. That also with V1.5.5 nobody has successfully flashed. With Original cable. Maybe only the Driver for DIP-100 could be the solution??? @ Pufi164 Please. Activate your private message. Maybe I have something for you... SL... Regards |
My privat massage yet live. Since then I successfully flashen with furiousbox ftdi and benq M300 cable. |
Next stupid Question... Here the picture of DIP-102 looks like it has something big in the middle... http://shop.benq.com.tw/eshop3_b2c/t...%BDu&refresh=1 Is this the missing part and maybe here the Driver: http://www.benq.com.tw/products/mobi...nloads&dtype=D BTW.: EF71 has now 1.30 as selfupdate... |
what kind of experience??????????? |
http://www.phantomgsm.com/online-sto...products_id=95 BTW.: We have 1.34 RU somewhere... |
DIP-102 is the right cable to do it. One can build also a cable of his own; to get the connector (plug), one have to sacrifice the earphones - or to buy the original ones somewhere else (eBay?!): http://www.usp-forum.de/community/bo...t=20440&page=6 Firmware 1.34 and XCSD Download: http://blog.dh.cantamen.de/?p=7 |
