Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > NON Siemens Brand (ODM Phones)
NON Siemens Brand (ODM Phones) Do you know that C62 is not a Siemens Manufactured !? here in this section we Throw all non Siemens-Benq related Threads like C62, CFX65, SF65, CL75, CL50, S40, U15, C30,Xelibri.
Old 02-12-2005, 21:36   #16 (permalink)
antonio148's Avatar
Member: 90268
Thanks Meter: 30
hi,
here is 2.71 .....Boa Sorte!
and post result ok?
Originally Posted by grzesiomet
hi Morfeus!
I still try to unlock C62 with v26 (originally it was v20 - I did upgrade before removing simlock )
I follow downgrade instruction, but after that my phone does not response. So I have to back to v26 with original soft. So in my opinion this procedure is not working When I tried to use logger that time, I had not correct codes - the same as for version 26
(I used flash programmer version 2.83 to downgrade (patched with hex editor) - I couldn't find version 2.71)
Please help with removing simlock - you sad you removed it from 2 phones - please share with your solution.
Do you have Flash Programmer v 2.71? Please give a link.
Many thanks in advance.
Old 02-12-2005, 21:49   #17 (permalink)
Member: 53988
Thanks Meter: 4
Originally Posted by Mr_GsmVIP
I downgrade to v20 with flash programmer 271
and phone is dead
boot is OK
i didnt flash customization file becaouse i didnt find it
rest is OK
please help me to repair phone ( and unlock ofcourse )
Regards
HOW CAN YOU FLASH C62 ; I MEAN WHICH CABLE AND POWER SUPPLY
I USE C62 FLASHER V83 AND I KILLED THREE C62:
CAN I REPAIR ??
PLEASE HELP
Old 02-12-2005, 21:55   #18 (permalink)
Spalato's Avatar
Member: 2236
Thanks Meter: 53
it is not working... there is no solution at the moment... stop destroying your phones with non-tested so-called "solutions"... Buy logs from someone and make money... it is the safest and fastest way...
Old 02-12-2005, 22:00   #19 (permalink)
Member: 53988
Thanks Meter: 4
can you please answer this
I USE C62 FLASHER V83 AND I KILLED THREE C62 version 16 i think
CAN I REPAIR ??
PLEASE HELP
Old 02-14-2005, 07:56   #20 (permalink)
Member: 107333
thx antonio148 for 2.71
I did try downgrade to v20, but no success.
I apply clearexitt****er and loaded v20, but phone was dead, but boot ok.
I tried download codes by logger, but log was identical as for v26.
To restore phone i had to apply v26 back.
In my opinion soft in the phone was still v26. When i used FP2.83 on this "v20" to load again version 20, system displayed info, that i cannot load lower version then in the phone
thanks and pls help if you have solution to go from v26 to v20 and remove simlock from the v26.
regards,
Old 02-15-2005, 19:23   #21 (permalink)
antonio148's Avatar
Member: 90268
Thanks Meter: 30
regards,
if is error code :6 you must edit file HD0503 in last line,: Flash write mode = from 4 to 3 here is in config folder .....work for me 100% .....now i have the last one dead c62 here is one more time error message: Waiting phone restart...
Uploading flash algorithm...
Flashing failed. Starting flashing failed (algorithm header not valid). Please try recovery flash). Please try recovery flash
wen i try recovery flash just recover at 25 30% and program says : phone do not respond
tks
Antonio148
Old 03-02-2005, 07:09   #22 (permalink)
Member: 122201
hello ! how unlock c62 ver 20 ?? plz help ...
Old 03-31-2005, 13:30   #23 (permalink)
protocolbg's Avatar
Member: 17637
Thanks Meter: 34
Is there free calculator for c62 without using cable???
Old 04-01-2005, 11:12   #24 (permalink)
ghosthacker's Avatar
Member: 68827
Thanks Meter: 125
hi to everybody
please i get this error:
Reading information from phone...
Recovering GDFS failed, error code: 66.
can someone help me???
10x in advance
Old 04-01-2005, 12:34   #25 (permalink)
Member: 68827
Thanks Meter: 125
Initializing...
Flashing failed. Starting flashing failed (algorithm header not valid). Please try recovery flash.
any idea please
Old 04-04-2005, 12:28   #26 (permalink)
hallo's Avatar
Member: 21365
Thanks Meter: 86
And like I said before...
....somebody write once that You can unlock v26 by downgrade to v20, read codes (phone can't power on actualy!), flash back to v26. I'm not try on v26 but try on v28 and get codes, but wrong. For You who looking for HowTo guide go here http://es.gsm-si.net/_upload/ file name RepairSimC62_do_v26
Cheers.
Old 04-18-2005, 22:57   #27 (permalink)
fonec's Avatar
Member: 11101
Sonork: 100.1641000
Thanks Meter: 1,783
for all c62 files
www.gsmegypt.org/support
Old 06-11-2005, 11:05   #28 (permalink)
Singh05's Avatar
Member: 69293
Thanks Meter: 19
Originally Posted by fonec
for all c62 files
All folders are empty there
Old 06-13-2005, 09:03   #29 (permalink)
hallo's Avatar
Member: 21365
Thanks Meter: 86
Here is...
...http://es.gsm-si.net/Siemens/RepairSieC62_do_v26/ files are just moved.
Cheers
Old 06-13-2005, 09:10   #30 (permalink)
SM4RTBOY's Avatar
Member: 92326
Thanks Meter: 205
DIRECT UNLOCK V25/26/28.. with gsmkey dongle..tested all versions by me.! work 100%
br
SM4RTBOY.
CAN FG UNLOCK C62...version C62? albarka network FuriousGold 2 10-13-2006 19:26
CAN FG UNLOCK C62...version C62 albarka network FuriousGold 1 10-13-2006 18:46
is usb cable c62, c55, c62 same ashvin SIEM Service Tools 2 05-25-2005 06:01
Siemens C62 V 1.017__Siemens C62 v28 T-Mobile support added. MicrostarGSM® Griffin 0 12-14-2004 10:40
New A60/C60/C62/MC60 loger from SST-GSM SST-GSM NON Siemens Brand (ODM Phones) 43 11-22-2003 21:28
Page generated in 0.56451 seconds with 9 queries
