NON Siemens Brand (ODM Phones) Do you know that C62 is not a Siemens Manufactured !? here in this section we Throw all non Siemens-Benq related Threads like C62, CFX65, SF65, CL75, CL50, S40, U15, C30,Xelibri. |
10-09-2004, 17:03 | #20 (permalink) | |
No Life Poster Join Date: May 1999 Location: RU
Member: 83 Status: Offline Thanks Meter: 1 | Quote:
Most problems are going from that. | |
10-13-2004, 12:01 | #23 (permalink) | |
Junior Member Join Date: Feb 2004 Location: Russia, Orel Age: 40
Member: 54104 Status: Offline Thanks Meter: 0 | Quote:
I fix this problem! I flash all phones, submitting on 9 pin 5 volt, but some phones are not flashing, the program gives out a mistake: Block verification failed for block 1, error code: 6. Then I submit on 9 pin 9 volt and phone are normally flashed. Probably, some flash chips demand the greater pressure of a feed. Sorry for my bad english! | |
10-13-2004, 18:15 | #24 (permalink) |
Major Poster Join Date: Oct 2004 Age: 43
Member: 85993 Status: Offline Thanks Meter: 0 | i have try f;ash my c62.....it "success"... BUT yhe phone now "HANG"....no response...just blank any idea???? do i have to change flash chip???? change 4 to 3????? anyone know the meaning??? |
11-17-2004, 17:37 | #26 (permalink) |
Junior Member Join Date: Oct 2002 Location: Estonia Age: 44
Member: 16649 Status: Offline Thanks Meter: 0 | and which pins are correct for TX and RX for flashing C62? I have same problem. I used pin 7 for TX and pin 5 for RX. It seems i can flash the phone, but i can't read information. Then i used other pins, (3,4) i was able to read info, but couldn't flash phone. Please, i need advice... I tryed to connect pin 3 with pin 5 and pin 4 with pin 7... I still get same errors: Flashing software failed. Block verification failed for block 1, error code: 6 Last edited by SaNcH0; 11-17-2004 at 18:18. |
11-18-2004, 01:04 | #27 (permalink) | |
Freak Poster Join Date: Dec 2000 Location: Burkina Faso , Bobo Dioulasso Age: 53
Member: 2920 Status: Offline Thanks Meter: 21 | Quote:
-Pin 2 =Gnd -Pin 3 & 5 are connected to TX -Pin 4 & 7 are Connected to RX -Pin 9 is connect to a External +9V DC , of course the External GND is grounded with Pin 2 ! Use Flasprogrammer 2.83 , Edit the HD0503.Ini file , change flash mode from 4 to 3 | |
C62 Flashing Problem | babbu | FuriouS II | 1 | 09-12-2005 08:39 |
C62 Flashing Problem Need Help Please | vinz4ever | NON Siemens Brand (ODM Phones) | 0 | 04-26-2005 20:01 |
c62 flashing problem | malkjos | NON Siemens Brand (ODM Phones) | 0 | 01-08-2005 16:52 |
C62 flashing problem | vlezlee | NON Siemens Brand (ODM Phones) | 15 | 01-07-2005 22:30 |
C62 flashing problem | CANAKKALE | NON Siemens Brand (ODM Phones) | 1 | 08-05-2004 17:18 |
