NON Siemens Brand (ODM Phones) Do you know that C62 is not a Siemens Manufactured !? here in this section we Throw all non Siemens-Benq related Threads like C62, CFX65, SF65, CL75, CL50, S40, U15, C30,Xelibri. |
09-02-2004, 09:25 | #19 (permalink) |
Crazy Poster Join Date: Jun 2003
Member: 31446 Status: Offline Thanks Meter: 1 | in my cause i have bad duplexes, who already solved this problem? can we repair them? Who have service manual with shematic of duplex? Replace with new i can but we have too much phones and we haven't new to buy... |
01-18-2005, 11:34 | #22 (permalink) |
Junior Member Join Date: Jul 2003 Location: Russia, Smolensk Age: 51
Member: 33644 Status: Offline Thanks Meter: 0 | in service manual level 2.5 no information about network problem. Network problem may be: crystall 13 MHz RF IS bad solder RF IC bad Duplexer is bad (no solution, no duplexer like C62) and problem with metal surface by internal side of back cover. and many many another problems )))) |
02-03-2005, 16:28 | #23 (permalink) |
Junior Member Join Date: Oct 2003 Location: Bulgaria
Member: 41027 Status: Offline Thanks Meter: 0 | the problem 100% is in audio ic ,replace it ang use from ericsson t28 the audio(multi) modul,but make new balls ,because with the olds doesnt work,after you will see... in the 95% of the c62 network problems are from this modul |
02-05-2005, 08:48 | #25 (permalink) |
Member: 41027 Status: Offline Thanks Meter: 0 | ok.. first... there is no duplex in this phone,,there is a antena swich,RF processor and a PA, when you rehoting the phone iis going, because all phe phone going hot.... and after few minutes it is the same,,, ok. just change the audio modul ...in the diference of t28,here the modul is not necesery about the contrast,like in the T28 is important.... post a gain after |
02-05-2005, 09:48 | #26 (permalink) |
Freak Poster Join Date: Aug 2003 Location: Bulgaria Age: 45
Member: 37317 Status: Offline Thanks Meter: 8 | hi @all that have c62 with netwrok problems. I have had many pieces of that phone and every time the problem is different (most of the cases rehoting of RF or ant. switch was giving me the desired result). Resently I had few pcs that freaked me out - I changed everything that is responsible for the network and nothing - at last just changing the mcu gave me stable network. so, the conclusion is that this phone is c.r.a.p b.r. |
02-05-2005, 17:14 | #27 (permalink) |
Member: 31446 Status: Offline Thanks Meter: 1 | mariokura what detail of rf part between PA and antenna switch? may be there is problem with my bad english? i have repaired a lot of c62 with network problem and 1 of 10 have realy bad duplex. On my question i got answer, thx Denis-hunter |
02-09-2005, 00:51 | #30 (permalink) |
Insane Poster Join Date: Apr 2003 Location: Beograd Age: 46
Member: 27463 Status: Offline Thanks Meter: 3 | This is my tip.When a siemens c62 the phone not register to network or signal is weak,i take off the external antenna connector and short with a wire antenna line Regards |
C62 network problem ok | sevgigsm | NON Siemens Brand (ODM Phones) | 1 | 07-17-2005 16:22 |
C62 with network problems after flashing??? | byteforce | NON Siemens Brand (ODM Phones) | 1 | 01-29-2005 17:30 |
c62 network problem | sloper | NON Siemens Brand (ODM Phones) | 0 | 09-02-2004 17:26 |
c62 network problem | pipopipin | NON Siemens Brand (ODM Phones) | 1 | 06-03-2004 12:28 |
Siemens (SE) C62 network problems | jivkobg | NON Siemens Brand (ODM Phones) | 7 | 05-25-2004 17:23 |
