Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > NON Siemens Brand (ODM Phones)
NON Siemens Brand (ODM Phones) Do you know that C62 is not a Siemens Manufactured !? here in this section we Throw all non Siemens-Benq related Threads like C62, CFX65, SF65, CL75, CL50, S40, U15, C30,Xelibri.
Old 06-30-2004, 13:26   #1 (permalink)
Member: 27606
Thanks Meter: 15
c62 network problem
no network,sometimes it finds it but not often,changed PA and antena contacts
Old 07-14-2004, 14:19   #2 (permalink)
domestik's Avatar
Member: 40118
Thanks Meter: 86
13 mhz crystal - 99%
Old 07-14-2004, 22:32   #3 (permalink)
Member: 68846
how does this crystal look like, where is it located?
thanx
Old 07-15-2004, 19:32   #4 (permalink)
Stoyan's Avatar
Member: 14868
Thanks Meter: 41
Can anyone confirm that solution?
And where is that crystal?
WBR Stoyan
Old 07-16-2004, 11:40   #5 (permalink)
Member: 27606
Thanks Meter: 15
where is it...................
Old 07-18-2004, 11:34   #6 (permalink)
domestik's Avatar
Member: 40118
Thanks Meter: 86
On this crystal written "13.000 TEW 427"
This problem with network is well known.
Old 07-18-2004, 18:15   #7 (permalink)
Member: 72579
Of course, crystal, I repaired couple C62 whit same problem, by replace 13 MHz crystal
Old 07-18-2004, 18:17   #8 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
for network problem.
you have to check your phone PA and antennna switch.
try soldering the antenna pin with conne cting wire to the board position.
try this , it work.ok.
bestman.
Old 08-02-2004, 22:30   #9 (permalink)
Stoyan's Avatar
Member: 14868
Thanks Meter: 41
Sorry, both solution not work for mine 3 phones.
puk,puk when connecting to network.
changed 13mhz , PA.... still the same
Old 08-03-2004, 15:12   #10 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,189
only RF IC is problematic ...
like on all SE platforms ...
luckily, RF IC is the same as on older ericssons
put from t610 and will work
or any other SE
b.r.
Alexandar.
Old 08-05-2004, 19:38   #11 (permalink)
Member: 27606
Thanks Meter: 15
are Pa and chrystal same like in some other phone
Old 08-06-2004, 17:52   #12 (permalink)
domestik's Avatar
Member: 40118
Thanks Meter: 86
Some of crystals from Siemens C35 can replace ones in C62. PA is ordinar RF3110B chip (LG1200,3000, Pan GD55 as I know)
Old 08-09-2004, 16:51   #13 (permalink)
Member: 27606
Thanks Meter: 15
I replace crystal,make new balls on cpu and still no network
Old 08-13-2004, 11:29   #14 (permalink)
Member: 77194
i have a siemens S40 handset that has display problem. when switched on the phone power on but no any display on the screen even charging signal when charging.
the set also does not power off except if i remove the battery.
kindly help
Old 08-24-2004, 14:46   #15 (permalink)
Member: 3470
Thanks Meter: 4
Hi All!
Thanks, 13MHz replace work ;-)
Regards
C62 network problem ok sevgigsm NON Siemens Brand (ODM Phones) 1 07-17-2005 16:22
C62 with network problems after flashing??? byteforce NON Siemens Brand (ODM Phones) 1 01-29-2005 16:30
c62 network problem sloper NON Siemens Brand (ODM Phones) 0 09-02-2004 17:26
c62 network problem pipopipin NON Siemens Brand (ODM Phones) 1 06-03-2004 12:28
Siemens (SE) C62 network problems jivkobg NON Siemens Brand (ODM Phones) 7 05-25-2004 17:23
Page generated in 0.41434 seconds with 8 queries
