how to USE the unlock code for CL75 I have got these unlock codes for my CL75 locked on Virgin Mobile. Unlock/Lock Codes: Code for NCKKN is : **00012*76371547# Code for NSCKN is : **00022*76591347# Code for SPCKS is : **00032*77397347# Code for CKCCK is : **00042*78591347# Code for PCKKP is : **00052*76391547# Phone Code Reset/Repair: Code for NCKKN2 is : **00013*79737769# Code for NSCKN2 is : **00023*79211969# Code for SPCKS2 is : **00033*79617799# Code for CKCCK2 is : **00043*79211969# Code for PCKKP2 is : **00053*79737769# Can anyone help me on which code should i use and how should i load that code into the mobile to get it unlocked. thanks in advance moeen |
Put a Non-acepted sim card in the phone Start entering unlock codes as they are written above, after typing first code you should have a message like "Done" or "SIM MEP Failed" Go on entering the codes, and see the phone boots up after entering some codes (gennerally it needs 12 and 32 codes) :) If you have message "Wrong Password" after entering unlock/lock codes, then use Reset/Repair codes, Then type unlock codses :) So your phone is unlocked ! Regards, B |
IMEI: 356328003342396 NCKKN Code: **00012*16361591# NSCKN Code: **00022*12541591# SPCKS Code: **00032*13377591# CKCCK Code: **00042*14501591# PCKKP Code: **00052*12341591# NCKKN2 Code: **00013*71957374# NSCKN2 Code: **00023*71551574# SPCKS2 Code: **00033*71957394# CKCCK2 Code: **00043*71551574# PCKKP2 Code: **00053*71957374# Got those codes. When I type in first code it says invalid password. When I put second code it says SIM MEP lock failed. I tried putting all the codes and it always says SIM MEP lock failed. What to do? BTW I tried those codes by putting in non accepted sim card. Please guide. Also codes are generated by Martech box. |
