Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > NON Siemens Brand (ODM Phones)
NON Siemens Brand (ODM Phones) Do you know that C62 is not a Siemens Manufactured !? here in this section we Throw all non Siemens-Benq related Threads like C62, CFX65, SF65, CL75, CL50, S40, U15, C30,Xelibri.
Old 06-01-2007, 19:24   #1 (permalink)
.:bono:.'s Avatar
Member: 96141
language on sg75
hi all, i got a siemens sg75, in language menu i can see different language, but when i try to select one , phone said always (language cannot be changed now) it's a qualcom phone,
how to select a languaage on this phone?
br
Old 06-01-2007, 20:07   #2 (permalink)
Member: 420658
SG75 is the same S. like SXG75, EF81, EF82, SL91...
Check with BitPim or BMC brew/shared/ldb
Here are the f. Language files for T9.
Example:
722_DElsUN.ldb = German
German and English is ever in these phones... Normally.
T9 files from these phones are compatible.
For SG75 is one complete Firmware available...
If u want only T9 files? Ask me per PMessage.
Please. Check your Firmware.
*#06#
SW-Build:
HW-ID:
SVN:
Pleeaasse.
Regards
Old 06-01-2007, 20:31   #3 (permalink)
.:bono:.'s Avatar
Member: 96141
thanks for replay, i sent u a pm
i think i have t9 for french cause i can activete it but no french language
Old 06-01-2007, 21:25   #4 (permalink)
Member: 420658
For full language support you need over 40 Folder with res/fr with *.bar files.
Maybe they are lost somewhere...
But before you make some experiments. With Firmware or something else...
Better BACKUP your files. For instance with BitPim or BREW Mobile Commander:
http://www.bezysoftware.net/en/sxgc.html
I have no life experience with SG75...
Old 06-01-2007, 21:42   #5 (permalink)
.:bono:.'s Avatar
Member: 96141
thanks teacher!
originaly the phone have 4 files in brew/shared/ldb folder:
720_enlbun.ldb
720_eslbun.ldb
720_frlbun.ldb
720_enlbun.ldb
720_ptlbun.ldb
i can activate any t9 in the phone but can't change language; so i think i nead onely language.
u said that i have to copy ur file in every folder under brew/mod, do u mean in all alarmclock, browser, gpsone................?
Old 06-02-2007, 19:51   #6 (permalink)
Member: 420658
Correct. Example:
addressbook_res.bar for each Language, here are 13 versions of this file...
13*40=520 or only french... Then 40 files with correct path FR
Tell me if u was able to Backup your Filesystem... Because if I give you the Firmware. Some problems could appear...
I know now. That are also SVN 01 possible... But I have only SVN 00 as 3GSwup...
I know some user which killed their SG75... Better learn a little bit more about this phone. Before you damage it. It is an absolutly Prototype with very, very unfinished Software...
Again. SG75 is the Grandfather of SXG75, EF81, SL91... Same BREW stufff
Old 06-02-2007, 20:05   #7 (permalink)
.:bono:.'s Avatar
Member: 96141
Correct. Example:
hii, u are in time thanks
i can't see the adressbook folder
Old 06-02-2007, 21:18   #8 (permalink)
Member: 420658
Okidoki. Now it is clear. Someone Delete all directories...
This is normally no problem. You "can" Delete all what you can see.
But then is only English active.
You have lost your Language files.
No problem. We try to Restore them. I give you better first only an Backup...
Wait a "Minute"...
Old 06-03-2007, 14:54   #9 (permalink)
.:bono:.'s Avatar
Member: 96141
i can't copy or past anything, i see onely retrying data, please wait.......
is there any other soft?
thanks for ur time.
Old 06-03-2007, 16:09   #10 (permalink)
Member: 420658
Try www.bitpim.org ???
Better only file by file for testing! Not complete folder...
Or EFS Explorer from QPST...
But I told you to make an BACKUP before...
If u can read all files from SG75, then higher chance to write files...
IMHO other user use BMC with SG75...
Not sure...
1. BitPim
2. QPST EFS Explorer
3. BMC
Old 06-03-2007, 16:55   #11 (permalink)
.:bono:.'s Avatar
Member: 96141
bitbim doesn't support it and with QPST i can't write eny file or directory either.
Old 06-03-2007, 17:16   #12 (permalink)
Member: 420658
SXG75, EF81 is also unsupported. But works correct with BitPim.
Choose other CDMA and the right ComPort:
http://forum.modopo.com/showpost.php...0&postcount=36
In Theory. Not sure if SG75 not "unique" in this case...
I repeat. I never seen SG75 live... No real experience with this device...
Only few user on www.siemensmania.cz have this device and work with them...
In 30 Minutes I upload Firmware 00. But WARNING! At your own risk.
I suggest to do the same like with SXG75,EF81,SL91. It is also an 3GSwup...
Later more.
Old 06-04-2007, 15:50   #13 (permalink)
.:bono:.'s Avatar
Member: 96141
soft can't detect the phone, it hangs like that
i try to disactivate what u said in task manager, but still stuck.
How do i change the language on an l6 and which files are which languages?? majid2 Ultima Box Light 1 03-10-2007 11:57
language on v36xx or 3690? GsMen Old Legacy Motorola (EMMI) 2 10-27-2001 16:26
language on Nokia phones razhannjon Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 05-19-2001 12:56
language on Nokia phones razhannjon Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-16-2001 21:34
Flashing language on the new AMD chip? Ragstar x1x to x45/x50 0 03-17-2001 18:35
Page generated in 0.46825 seconds with 12 queries
