Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > NON Siemens Brand (ODM Phones)
NON Siemens Brand (ODM Phones) Do you know that C62 is not a Siemens Manufactured !? here in this section we Throw all non Siemens-Benq related Threads like C62, CFX65, SF65, CL75, CL50, S40, U15, C30,Xelibri.
Old 03-06-2005, 23:47   #31 (permalink)
Member: 36035
Thanks Meter: 8
Originally Posted by ntt
how?
BR,
ntt
Try this another pc!
WBR
Old 03-19-2005, 14:29   #32 (permalink)
Siemens man's Avatar
Member: 3925
Thanks Meter: 22
hi man
your solution is 101% correct, i'm flashing my phone using milano buck up tool, select restore buck up, after my phone dead, after i can't connect to milano softs. allways say error. thank you for safe my f u c k
thank you
Originally Posted by Brka
@privateGSM ...
- Milano Backup Tool 4.1x .... do Clean User Data
- Milano Switch Tool 4.1x ... do "ST55 -> Switch to neutral"
- Milano Download Tool 4.1x ... do Full FLashing, MainFW+Map+LangPack
all problems solved
b.r.
ALexandar
Old 04-19-2005, 06:13   #33 (permalink)
webiso's Avatar
Member: 10580
Thanks Meter: 43
hi man
Originally Posted by Siemens man
hi man
thank you
l m rty may be 5 pcs and %1000 true and use this same all problem is finished
not : st 55 only and use milano dovnloader 3,40 and realy good
yes really
Old 04-19-2005, 07:15   #34 (permalink)
sunnyc's Avatar
Member: 49495
Sonork: 100.9 & 100.12345
Thanks Meter: 1,026
i am try more time with st.55 not work but its work with st60 100% pls help me with all info how to work with st55 thx...............
Old 04-19-2005, 10:35   #35 (permalink)
Member: 10964
Thanks Meter: 285
@BB-GSM ...
you should offer latest Milano Tools to board members ...
and btw. if u are such a pro. who didnt you wrote
how to edit .INI files in Milano tools, to make it working on USB or COM ports,
and also how to remove other ports, and leave just COM1 or COMx ?
here's attached .INI tool for Milano Downloader 4.1x
with only one COM ... com1 ... and baud rate 230400 ...
if u need special settings .... write a message here
with requests ... (com port, USB or COM cable, customer name etc.)
and i'll make INI file for you
b.r.
ALexandar.
hello alexander
thanks for your help
i used flasher,switch and backup tool for unlock st55 and st60
i modified ini files to get it working
problem is flashing speed and com ports
i would like to use prolific based cables to reduce time in flashing
usualy drivers for prolific use com3 and com4 (i set up my ports this way)
so i would like ini file witch use com3 or com4 at maximum speed posible
or if you can tell me something about USB cable i'll make one and just use that
thanks for help
sorinm
Old 05-18-2005, 19:42   #36 (permalink)
gsm-decode's Avatar
Member: 47441
Thanks Meter: 14
Any good link for st55 flasher and flash file european
Rgds
Old 06-11-2005, 10:33   #37 (permalink)
Cheater -Don't Deal with him-
Member: 21296
Thanks Meter: 328
Originally Posted by jokers5
My problem is solved.
How you did that? Share here, please.
I have upgraded my PC to Pentium 4 3.0 GHz Hyperthreading and now I cannot succeed to flash any phone. I always get Load Agent, Boot OK, then change Rate, and after that (after some seconds): Timeout Fail 8: BS_PMC_PLAIN. Anybody has a clue what is going? I have earlier flashed some sets, but with this PC it is not working. I am suspecting that it is a fast PC.
Apreciate any advice
Old 06-11-2005, 11:37   #38 (permalink)
Member: 10964
Thanks Meter: 285
@byteforce
i had some trouble using flasher untill i stoped other programs running in background like YM and other messengers (i use fast PC too with more than enough RAM).
hope it helps
Old 08-04-2005, 12:04   #39 (permalink)
zvk
Member: 141816
Thanks Meter: 2
how can i use usb cable for flash?
@BB-GSM ...
b.r.
ALexandar.
hi.i want to use usb cable for flash st60.i dont want to use com..but my pro ewerytime connect com 1 port opened.do you know how can i connect usb?
anybody know.
Old 08-19-2005, 17:13   #40 (permalink)
MR PROTEC's Avatar
Member: 86655
Thanks Meter: 385
@BB-GSM ...
b.r.
ALexandar.
very thx for your help but i want to ask you can i use this ini for com1 and baud rate 115200 in win 98 or must do something with me
thx again hero
wbr
Old 08-22-2005, 12:11   #41 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,784
yes, of course ...
com1, 115200
b.r.
Alexandar.
Old 08-22-2005, 16:58   #42 (permalink)
MR PROTEC's Avatar
Member: 86655
Thanks Meter: 385
@Brka
THXXX AGAIN M8
Old 08-28-2005, 21:47   #43 (permalink)
Member: 31952
"List idex out of bounds"
Only on PC with NTFS file system, not on PC with FAT32. No matter it is Win98 or WinXP.
Old 08-29-2005, 15:53   #44 (permalink)
Member: 75243
Thanks Meter: 6
i have sucsessfully repair my ST-60 3 month ago, but now my downloader say "LIST INDEX OUT OF BOUNDS". I try with another PC, the problem same. i try again in another PC the problem cannot be solved.
please tell me what the problem "List Index Out of Bounds" Thanks before
** I'am using Fat32 Windows 98SE **
Old 08-31-2005, 15:49   #45 (permalink)
BB-gsm's Avatar
Member: 75765
Thanks Meter: 722
@ comtelservice & metronetGSM
Use Newer version of Milano downloader!
Regards,
B
UPDATE: 23 MAY 2005. Siemens ST55/ST60 flasher added Infinity-Box Infinity-Box 10 04-28-2006 05:38
Quanta Calc - Panasonic A10x, X300, GD55, G5x, G70, Nec 101, 342i, Siemens ST55/60/50 zulea Panasonic (USB-Smart) 0 04-03-2006 16:46
Quanta Calc - Panasonic A10x, X300, GD55, G5x, G70, Nec 101, 342i, Siemens ST55/60/50 zulea Others (USB-Smart) 0 04-03-2006 16:44
Quanta Calc - Panasonic A10x, X300, GD55, G5x, G70, Nec 101, 342i, Siemens ST55/60/50 zulea Panasonic (USB-Smart) 0 04-03-2006 16:43
Page generated in 0.21194 seconds with 10 queries
