Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > NON Siemens Brand (ODM Phones)
NON Siemens Brand (ODM Phones) Do you know that C62 is not a Siemens Manufactured !? here in this section we Throw all non Siemens-Benq related Threads like C62, CFX65, SF65, CL75, CL50, S40, U15, C30,Xelibri.
Old 11-05-2008, 06:55   #1 (permalink)
Member: 420658
Thanks Meter: 159
Lightbulb Upgrade from Single to Multi Boot for SG75/SXG75
Please read carefully! You can damage your handset!!
If you want update older SG75 or SXG75 to "newer" Firmware.
So you need QPST-->Software Download-->OBL Multi-image Tab
Copy all files in same folder:
obl.mbn
pbl.mbn
qcsbl.mbn
qcsblhd_cfgdata.mbn
oemsbl.mbn
oemsblhd.mbn
amss.mbn
amsshd.mbn
partition.mbn
See Screenshots. Files are in every 3GSwup. You need only to add obl,pbl,qcsbl + Header files.
Nameconvention in SXG75 3GSwup is most different. Here "Translation".
partition.mbn    = W5V0xx.qpart
oemsbl.mbn       = W5V0xx.qoemsbl
oemsblhd.mbn     = W5V0xx.qoemsbhd
amss.mbn         = W5V0xx.qapp
amsshd.mbn       = W5V0xx.qapphd
Attention!
Most early protos have only 64 MB instead 128 MB.
So you have not enough space to update CEFS...
Old 11-05-2008, 07:12   #2 (permalink)
Member: 420658
Thanks Meter: 159
Additional Infos.
Only use. If SW Build is too old for 3GSwup.
U can identify it in different ways.
1.
*#06#
Look on SW Build. Most not working on old proto/sample
2.
Call
Enter 6 x 0 and enter Call.
Look under Phone info. Most too short to identify correct...
3. Better use Tools like HWTP, QPST ....
U can see such SW Builds on SXG75 like:
W6250C-MMTO-1.4.33_8
This is latest known SVN 26
MMTO is sign for Multiboot concept.
MMTZ like in W6250C-MMTZ-1.2.30 is also working with 3GSwup. Maybe not all Versions...
But Danger! If u see MMSZ like in W6250C-MMSZ-0.3.301T
Then you need QPST! And all files I told! Or you kill SXG75 with 3GSwup...
EVER make NV item Backup before. With QPST or better NV Editor as *.QCN or *.BRT.
After override partition you need to Restore NV items!
Old 11-18-2008, 07:21   #3 (permalink)
Member: 903579
Amss.mbn the EF81 is it possible?
I was SXG75 W6250C-MMTO-1.4 33_3
Old 11-18-2008, 07:34   #4 (permalink)
Member: 420658
Thanks Meter: 159
Sorry. EF81 AMSS is NOT running on SG/SXG75...
This is SVN 22. You can use 3GSwup for SXG75 SVN 26 ( W6250C-MMTO-1.4.33_8 )
Best Regards
Old 11-18-2008, 07:51   #5 (permalink)
Member: 903579
Can I update SXG75 use amss.mbn of EF81?
My phone has already been updated to SVN26( W6250C-MMTO-1.4.33_8 )
Old 11-18-2008, 08:53   #6 (permalink)
Member: 420658
Thanks Meter: 159
NO. It is not working.
If u want learn more about "why". Take an look here:
http://forum.revskills.de/
Best Regards
Old 11-18-2008, 22:41   #7 (permalink)
Member: 420658
Thanks Meter: 159
For those. Who need more space.
FOTA was for Update over the Air... But never used.... BenQ realized this. Since E81 for example. So they changed partition.mbn.
This could be interessting for those. Who have Samsung NAND (64 MB).
Instead 128 MB Toshiba...
WARNING!
Partition Override needs ever ALL files. Then only this partition.mbn is to use for further Flashing... Because partition.mbn in handset and choosen partition.mbn must be identical.
For locked/frozen Mobiles. This is not an good idea without Backup. Because you kill your SIMSecure area...
This is really only for oldest Protos. To have around 30 MB free space instead 16 MB...
File Type: rar E81partition.rar (210 Bytes, 53 views)
Old 11-19-2008, 01:20   #8 (permalink)
Member: 903579
I would like to ask you can not upgrade any other packages to achieve the Chinese SXG75
Old 11-19-2008, 03:21   #9 (permalink)
Member: 420658
Thanks Meter: 159
Sorry minhao1.
At the moment only JAVA and special BREW Apps supports chinese Language.
Take an look here:
http://mobile.0110.cn/forumdisplay.php?fid=214&page=1
For full Language Support. There are missing few important internal BREW Apps. Located in AMSS.mbn.
We can't use E81C Firmware to copy missing parts to SXG75 or other...
E81, SF71 and M7 are BREW mobiles. With full chinese Support.
Maybe one day we find an solution...
Best Regards
Old 11-19-2008, 03:59   #10 (permalink)
Member: 903579
谢谢!
How to Upgrade from FII to FGold Seedy FuriousGold 1 05-13-2006 11:07
Is It Too Late To Upgrade From Furious1 To Furious Box? sutiee FuriouS II 12 04-26-2005 19:05
Is It Too Late To Upgrade From Furious1 To Furious Box? sutiee FuriouS II 1 04-25-2005 18:07
need step by step instructions to change my sl5c to sl55 to upgrade from fw9 to 16 anaeve E-Gold Based Phones 0 02-14-2004 08:45
3310 freezes in some menus after upgrade from 419 to 445 robbie Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 12-04-2001 21:43
Page generated in 0.39630 seconds with 9 queries
