NON Siemens Brand (ODM Phones) Do you know that C62 is not a Siemens Manufactured !? here in this section we Throw all non Siemens-Benq related Threads like C62, CFX65, SF65, CL75, CL50, S40, U15, C30,Xelibri. |
03-18-2004, 02:28 | #1 (permalink) |
Freak Poster Join Date: Jul 2002
Member: 13696 Status: Offline Thanks Meter: 0 | What's wrong ? C62 flashing Until try flashing C62 , flash programmer write: Initializing... Uploading flash algorithm... Waiting phone restart... I restarted phone but is still the same around. Interface is good, with 12V. Where is the problem ?? May it be XP problem ?? I'll will be try on 98 tommorow. best regards, Deepx |
03-18-2004, 02:58 | #2 (permalink) |
Freak Poster Join Date: Jan 2004
Member: 48492 Status: Offline Thanks Meter: 29 | id datacable is correct (2-GND, 5-TX, 7-RX, 9-12V) Installation: Install “flash_programmer_for_siemens_setup.exe” Copy “HD0503-058-M” and “HD0503-067-M” and "HD0503-073-M" (MUST BE WRITE BIG LETTER) into “C:\Program Files\microcell\Flash Programmer” folder. Settings: Select Options -> Settings ->C62 Set Baud rate to 115200 bit/s Select Root folder for software releases Choose Software release “C:\Program Files\microcell\Flash Programmer” Choose Language package Choose Customization package (international = AUTOLOCK) Phone flashing process Switch OFF the phone Plug-in flashing cable Press Flash button Press shortly power button br, nike www.free.soft.prv.pl |
03-18-2004, 03:13 | #3 (permalink) | |
Member: 13696 Status: Offline Thanks Meter: 0 | Quote:
I exacly did it before post In my mind, problem is XP. At morning I'll try make it all with win98. best regards, Deepx | |
03-18-2004, 08:46 | #4 (permalink) |
Member: 48492 Status: Offline Thanks Meter: 29 | use correct baudrate (115200 bit/s) ? orginal guide say "Set Baud rate to 460800 bit/s", 460800 bit/s NOT WORKIN` IN MY PC! br, nike www.free.soft.prv.pl |
03-18-2004, 20:09 | #5 (permalink) | |
No network after flashing U8500 with unlocked flash - What's wrong? | James_S | FuriousGold | 9 | 05-10-2008 13:56 |
What's wrong w950 flashing???? | BABAK NURI | Universalbox | 1 | 08-27-2007 22:02 |
Display doesn't work after flashing V3 - what's wrong? | James_S | Ultima Box Light | 6 | 02-06-2007 17:02 |
