Siemens-Benq Flash Patching All about Flash patching/patches and Flash Modifications we can get it from here |
03-11-2005, 04:36 | #1 (permalink) |
No Life Poster Join Date: May 2004
Member: 66040 Status: Offline Thanks Meter: 14 | ICD v2.2 small question ;Group is 3 characters stored in the PostCode, starting at position #5 ;for example: S1--VIP (S1 for other patch, VIP is ICD Group). ;filename for group is A:\Images\icd_XXX.bmp where XXX is a group name I made a file A:\Images\icd_glb.bmp, then edited my addressbook and put "GLB" on the postcode, and checked the VIP part. When that contact calls, the icd_glb.bmp doesnt show. How do i do it correctly? Thanks. |
03-11-2005, 10:08 | #2 (permalink) | |
No Life Poster Join Date: Oct 2003
Member: 42457 Status: Offline Thanks Meter: 1 | Quote:
But what I don't understand (and I didn't try now) is how we can do animated pictures? | |
03-12-2005, 01:00 | #3 (permalink) | |
Member: 66040 Status: Offline Thanks Meter: 14 | @cyper: Animated pic is easy. Just create a bmp file less than 3,646 bytes. for example, we make a bmp width = 101, height = 160. If we want 4 pictures that moves consecutively, we divide the height by 4. so each picture should be width=101, height=40. The y coordinates of the each pic will be y=0, y=41, y=81, y=121 within the original bmp file that has a width=101 height=160. After we make this picture, use hexeditor and we do this: Quote:
Thanks for the POSTCODE answer. It works Last edited by charlielao; 03-12-2005 at 01:46. | |
03-14-2005, 10:28 | #11 (permalink) |
Member: 42457 Status: Offline Thanks Meter: 1 | Yes I also tested yet and it works but I had the problem with DSM "Direct send Message" (v1 and v2). It's quite a good patch but it let's my phone freeze after I want select a number So last way out - remove! |
FAM v3 i ICD v2.2 | GoLL@B | x4x, x5x Flashpatching | 8 | 11-04-2005 14:19 |
