Siemens-Benq Flash Patching All about Flash patching/patches and Flash Modifications we can get it from here |
08-11-2004, 19:08 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Ankara, Turkey Age: 50
Member: 69110 Status: Offline Thanks Meter: 0 | Loadable Ring Tones - Questions and Ideas Thanks for your smart patch. Here are some questions and bugs; can you make the patch selectable through application menu not through standard melody 5? there is no ring-tone when the audio-melody menu is not set to standart 5. when there is a call from a number for which a binary ring-tone is assigned by means of your patch, the melody is not repeated. the melody is played only once. |
08-12-2004, 04:53 | #3 (permalink) | |
Freak Poster Join Date: May 2003 Location: Russia, Ekaterinburg Age: 44
Member: 29316 Status: Offline Thanks Meter: 0 | Quote:
08-12-2004, 05:13 | #5 (permalink) | |
08-12-2004, 06:22 | #6 (permalink) |
Freak Poster Join Date: May 2003 Location: Tehran Age: 52
Member: 27936 Status: Offline Thanks Meter: 0 | @DeadManS thanks for this nice patch. I have a question? Can you make another ringtone like discreets instead of standard 5? for me the ringtone converter has english menu and everything is simple for converting mid to bin. thanks alot. it works fine. the nice thing is that assign anyringtone to any phone number v3a still works. we must disable the postcode parameter to use the bin file asa ringtone. |
08-12-2004, 06:37 | #7 (permalink) | |
08-12-2004, 07:07 | #8 (permalink) |
Member: 27936 Status: Offline Thanks Meter: 0 | @DeadManS you made Ringtone standard no5 the default ringtone and changed that to bin melody. but the old standard no5 ringtone is usefull for me and I missed it. can you change the default ringtone from standard 5 to another one like discreets for this patch? I found a problem in your patch. sometimes the incoming ring tone is just an annoying long Beeeeeeeeeep and sometimes it's a normal melody. I noticed it when I turn on my phone. after first incoming call the ringtone was ok. sometimes when I go to Audio/Melody folder for playing ringtone standard no5, only I hear a buzz. |
08-12-2004, 08:57 | #9 (permalink) | ||
Member: 29316 Status: Offline Thanks Meter: 0 | [quote]sometimes the incoming ring tone is just an annoying long Beeeeeeeeeep and sometimes it's a normal melody. Quote:
08-12-2004, 11:35 | #10 (permalink) |
Member: 29316 Status: Offline Thanks Meter: 0 | 2All: trythis version and write melody repeated or no? also wrote what melody use for LRT istead of standart 5? Uninstal previos version bin filesize must by <336bytes (in future i fix this) 030F74: F2FC2A2C DAE01ED1 1AAABA: C405EA02 00050300 0040D0E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE0040E03DE6FC0005E6F5E000E6F4 0040D0F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1CD1D7703600885E884E88DE88CEE00C 0040D100: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00D88D088C0E6FC0004E03DE6FE8522 0040D110: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FFE202DAD712D90804DB00DB0088F0 0040D120: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88E088D088C088B088A0889088808870 0040D130: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 886088508840E10CE6F70005D7400300 0040D140: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B9C7E6F70812E6F50004D7408303A9C7 0040D150: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400300B9C50871085146F514043DF5 0040D160: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E004E006E6F50E04E6F73D2CD7400800 0040D170: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A9C7E6F7402C0076D7400800A9C7F18C 0040D180: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 67F8F00047F8F0002D0A3C4407F83000 0040D190: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400300B985285146F507042D0C67FC 0040D1A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0F0007FC3000D7400300B9C528512871 0040D1B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 46F507043DE1DAE0E0D0E6F70005D740 0040D1C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0300A9C749C00D11E6F71C12E6F50004 0040D1D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7408303A9C7D7400300B9C508710851 0040D1E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 46F513043DF5DAE0E0D0984098509860 0040D1F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98709880989098A098B098C098D098E0 0040D200: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98F0F2FC2A2CDB00413A5C6D6964695C 0040D210: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 787878787878782E62696E00413A5C6D 0040D220: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6964695C6D656C6F64792E62696E00 Last edited by DeadManS; 08-13-2004 at 05:32. |
08-13-2004, 02:32 | #11 (permalink) |
No Life Poster Join Date: May 2004
Member: 66040 Status: Offline Thanks Meter: 14 | to Deadmans, after loading your new LTR, 1. i made a midi folder 2. i converted a midi file using the ringtone converter and renamed it xxxxxxx.bin based on the last 7 digits of the caller 3. i copied the bin file into the midi folder 4. i set audio->melody->all calls->standard 5 but there is no sound when a call is incoming. anything i did wrong? |
08-13-2004, 08:51 | #14 (permalink) |
Member: 66040 Status: Offline Thanks Meter: 14 | Sir, i tried your patch in #10 post and still has the same problem I set audio>melody>all calls>standard 5 but still i dont get any sound. could it be that my conversion from midi to bin is wrong? This is what i did: I open a midi file (165bites) and clicked on "convert", "midi to bin convert tool", added the midi file and converted it. Do i have to click on the bin settings? because I cant read anything on the bin setting window. |
Samsung Ring Tones ,Voice Ring Tones,Walpapers , Games & Software Enter Here | NadeemShahzad | Samsung Media, Games, Ringtones | 706 | 03-03-2012 18:28 |
idea ring tone need(with high sound quality) | maqsood | Nokia Multimedia | 20 | 03-12-2007 19:11 |
ring tone download ring tone | mehta | Sony Ericsson Media, RingTones, Games | 3 | 10-19-2005 18:49 |
Loadable Ring Tone bug | charlielao | Siemens-Benq Flash Patching | 0 | 03-18-2005 04:56 |
x100nohave ring tones or Games..any idea?? | GALAXY*gsm | Samsung Media, Games, Ringtones | 3 | 04-23-2004 20:52 |
