Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| Siemens-Benq Flash Patching All about Flash patching/patches and Flash Modifications we can get it from here |
| | #1 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Jan 2004 Location: Sarajevo,B&H Age: 35
Member: 50599 Status: Offline Thanks: 0
| Error reports in some patches 1. Explorer right softkey Mark is now used on key * or #... But there is no option for mark all (previously long press of right softkey) now long press on * (or #) it is just toggling mark/unmark. Can it be solved? 2. Just a simple text viewer Sometimes (when no file is loaded) phone crashes when we select Read Memory.... |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2004
Member: 60520 Status: Offline Thanks: 0
| 1. Maybe it's possible to have both functions. I can have a look at that patch this weekend. 2. Easy bug, easy solution: don't select "Read memory", when no file is loaded. I mean, if you have some injury it hurts when you touch it. Result? You don't touch it... |
| | #3 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2004 Location: Romania Age: 32
Member: 67838 Status: Offline Thanks: 0
| Quote:
This is less important though, more important is that on slightly longer files (for those that you have to press Next to view the rest of) some portions of the text disappear. This SHOULD be fixed, since this is an issue that makes the patch less functional. | |
| | #4 (permalink) |
| As far as I know you stil aren't able to see non-english chars with JSTV? Riza had found a solution for that in his notepad-binary. Riza, maybe you can post the source of JSTV and also the new viewing routine (with non-english chars possible)? |
| | #6 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2002 Location: -[r0]- Age: 42
Member: 9891 Status: Offline Thanks: 0
| I did upload the JSTV: Just a Simple Text Viewer v3. Some previous bugs had been corrected. BUT, the UNICODE file support is deleted. For a better viewing, text file need to be converted to the ASCIIZ format, otherwise, some character may not be displayed correctly, especially for the long text file. ASCIIZ is a string which is ended with a single '00' char. Attached is a perl script to convert a plain text file to either ebk (ebook), or ebz (zipped ebook) format, which is supported by JSTV v3. Just type : "perl eb.pl" from your MS-DOS prompt to get some usage help. I also attach test2.ebk to be used as a font (ASCII Code) test file. Using that file, we can see that actually, UNICODE character is displayable in the patch. Just need a converter ... which I don't have it now ![]() rizapn |
| | #8 (permalink) |
| Perl maybe is my daily tools, but not for everyone in this forum ![]() So, I attach the eb.exe tools (still an MS-DOS based software, not a GUI ones, because sometimes, I really hate GUI, it make us "lazy") ... Just go to the MS-DOS Prompt in your Win32 OS, change the directory to where you put eb.exe, or put eb.exe in your PATH, and type "eb" <ENTER> ... Using this tools, you can "convert" a plain text file to become an EBK file (ASCIIZ text file to be read by the JSTV patch), or EBZ file, which is compressed with around 40% ratio. Example usage: eb z,1000,"The Story Ones" my_ebook.txt which will generate ebz files from plain text my_ebook.txt. Each ebz files has 1000 "JSTV pages", and the ebook title is "The Story Ones" (without the quotes) ... rizapn |
| | #10 (permalink) |
| @cyperghost: - hehehe... but, I don't think this Simple Viewer is comparable with microreader ... JSTV: Still need a converter for Non-English character file to become displayable with this patch. I also attach the sample files, which I think is containing Russian characters (sorry, if I make a mistake). Other character set which is displayable through JSTV is Arabic. But, the text display sequence is not 'correct' (from left to right, not right to left). |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| error in imei patch 1100 and lose credits | CellTronic | Universalbox | 3 | 06-30-2007 10:43 |
| error in imei patch 1100 and lose credits | CellTronic | Universalbox | 0 | 06-28-2007 23:04 |
| about language description errors in some Flashs in support | mourad_t | VygisToolbox | 0 | 06-12-2006 09:45 |
| Problem solved:if you get error in some commander! | haveri | Redbox | 2 | 05-08-2006 18:02 |
| Why Java patch doesnt work in some Siemens??. | dipu | Siemens-Benq RingTones and WallPapers | 3 | 10-15-2005 10:53 |
